So at some point my combination meter went dead and I had it repaired it recently went out again and now my power button sometimes doesn’t shut off the car unless I put the key in the slot and hold down the power button the 12v is a factory s46b24r true start from 4/21 Thoughts?
If you just order the part from Texas hybrids you'll have a reasonable warranty in the car will work just like it did Factory. And you won't be redoing it
