Speakers 20-20khz
Discussion in 'Gen 4 Prius Audio and Electronics' started by Buggs1a, Sep 13, 2025.
  1. Buggs1a
    Buggs1a Junior Member
    112
    Are there any speakers for 2020 Prius thst go 20 hz to 20 kHz? I won’t buy new speakers that all seem to show crappy freq range like 60-18 kHz or so. And subs even show 45 hz or even worse.
    I’d prefer door speakers at 20-20 or at least not so crappy like 45-60 hz.
    For a sub I’d want one 10 inch ported 20 hz. Not crazy power tho im not into that. Just normal Electronic.
  2. ChapmanF
    18,454
    It wouldn't surprise me if the drivers listed with "crappy freq range" were just advertised more honestly than some more "impressive" ones. Maybe it's easier to get good reproduction in a car cabin by using what drivers are available and setting EQ empirically?
  3. Buggs1a
    112
    Eq takes away from the intent. I do t change it. It’s always set 0.
    I find it pathetic if a so called sub goes to only 45 hz. That’s not sub. Sub is sub bass. Low. 45 ain’t that. And for door speakers to only do 60 hz is pathetic too.
  4. ChapmanF
    18,454
    Depends on whether you think 'intent' is about what you're hearing in the space where you're listening, or just arbitrarily what some driver might produce in lab conditions.
  5. Mendel Leisk
    41,824
    Maybe listen to online tone generators. One example:
    Online Tone Generator - Free, Simple and Easy to Use
    My perceptual limits is around 50~7900 Hertz
    But I'm in my 70's; I think the high-end in particular goes as you age.
    addendum: some revision to top end, in red. Just barely discernible
    #5 Mendel Leisk, Sep 14, 2025
    GoodOldBob likes this.
  6. ChapmanF
    18,454
  7. Mendel Leisk
    41,824
    Sine: (baseline)
    Square: similar, somehow "cleaner"?
    Sawtooth: significantly muted
    Triangle: slightly muted
    Turning each on/off helps, to differentiate from ambient noise, tinnitus, imagination.
  8. ChapmanF
    18,454
    Mathematically, a square wave is a sine wave at the fundamental frequency (here, 7500 Hz) combined with sine waves at all odd multiples (3 ✕ 7500 = 22500 Hz, 5 ✕ 7500 = 37500 Hz, and so on), with each n✕frequency sine wave having 1/n the amplitude.
    A triangle wave has the same components, but dropping off faster (each n✕frequency sine wave having 1/ the amplitude). The sawtooth is composed of all the integer multiples (not just the odd ones), dropping off at the same 1/n rate as a square wave.
    Those are infinite series which, as you can see, quickly exceed the frequency limits of the equipment reproducing them (which is why nothing will ever produce a perfectly-square or perfectly-triangular or perfectly-sawtooth wave).
    Starting with 7500 Hz as the fundamental kind of means your equipment's limits are already exceeded at the 22500 Hz frequency✕3 component (the second extra component of the sawtooth wave, and the first of the square or triangle). I suppose you're hearing the triangle muted and the sawtooth even more muted, because you're not really hearing the higher-frequency components, but only that the fundamental has become less of the total loudness.
    It might be interesting to seek for the highest frequency where you can clearly hear different tone qualities in the different waveforms. With a 4000 Hz fundamental, for example, the equipment can probably reproduce the 3✕ and (just barely) 5✕ in the square and triangle, and the 2✕, 3✕, 4✕, and 5✕ in the sawtooth. It might be that you do perceive some of those higher frequencies as making tone-quality differences, even if you're not conscious of hearing them directly. (Or maybe not. I'm not an audiologist, and an audiologist would probably know.)
  9. Mendel Leisk
    41,824
    Depends too: pc with ear plugs, vs iphone, vs surround sound system. I should try on the latter.
    Again, turning the sound off/on helps, and turning your head, shifting al little.
  10. Buggs1a
    112
    I want to get door speakers where I don’t need a sub. I want them to be very good.
    But I’d get a sub anyway since I doubt there’s any door speaker at 20hz or even 30. I’d get a 10” ported sub and I’d be fine with 100 watts as I don’t listen loud.
    #10 Buggs1a, Sep 18, 2025
  11. bisco
    52,286
    sounds like a plan
  12. Buggs1a
    112
    How does this work? 10” ported sub. Can I connect it to my system? Need as in necessary get an amp? How do you give sub 80hz xover? I know car toys and crutchfield. But curious in here for info if possible.
    I’d like a 10” ported sub with maybe 100 watt amp to it crossed at 80 hz. So 20hz to 80hz.
  13. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    There's plenty of subs out there with integrated amplifiers and adjustable low-pass filters. There's nothing really special about the audio system in the Prius or any other Toyota- so the most convenient way to do it is with the common off-the-shelf stuff you can get from the regular suppliers.
    The most difficult thing with a sub is where to put it. Acoustically, it doesn't matter much, but if it is in the cabin it is always going to be in the way of something, cargo-wise. Or loose and rolling around, which also isn't fun.
    I put better speakers and a better head unit in our 2018, and it was a nice improvement. It's not high-powered, there's no sub, and I couldn't tell you how flat the response is because I don't have a mic good enough to test that. But it sounds much better than what the car came with, so I quit while I was ahead.
  14. Buggs1a
    112
    I forgot about powered subs. But the touch screen I don’t see how it can be replaced. You lose a lot of the or all of the Prius stuff. And that’s way too big of a job.
    wouldn’t even be able to connect a powered sub to the system unless it had a sub connection which I’ve never heard anything on.
  15. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Some powered subs are designed for cars that have difficult-to-replace head units like the Prius, because there are many of them.
    You just supply them a copy of the speaker-level audio and they do the rest.
  16. Buggs1a
    112
    Thanks for chatting.
    Can my HU in the 2020 L Eco be replaced? Hmm.
    I could get a sub first. But hmm not sure what to say. Well it’d be in the back. I don’t put anything there so no cargo. No need for crazy vol. just a nice good clean 10” or whatever 20-80 hz.
  17. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    I know that's a more difficult replacement than mine was- there aren't as many replacements available. But it can be done.
    As far as powered subs go? It's really not hard. $250-600 gets you the device, you wire it to power and remote power-on signal, route a copy of the speaker outputs to it, and enjoy more bass. It's still a bit of work to pop interior panels off and route the wires through, but as autosound installations go it's pretty lightweight.
    Crutchfield has a whole line of 'em and they're really pleasant to deal with. Very good at after-sales tech support.
  18. Buggs1a
    112
    Don’t look like they’ve got powered subs. No link to any. 2020 Prius. Has options for stuff that fits the car but no powered sub in the sub link and only sealed subs 99.9%
  19. Buggs1a
    112
    Crutch field is a pos company they’ve treated me horribly and I’ve even filed a bbb complaint long ago which did nothing. Bbb is a joke too. Bad one.
    So I’d only go to car toys. But not anytime soon.
  20. Buggs1a
    112
    I’ll figure this on my own.
