Wheel noise -- bad bearings or something else?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by itrontz, Dec 7, 2021.
  1. itrontz
    itrontz Junior Member
    NYC
    I recently had all brake pads and rotors replaced on my 2010 Prius (75,000 mi). When the mechanic took it for a test drive, he said it sounded like the bearings in both rear wheels were bad.
    I had my wife drive around while I sat in the back seat. There is indeed a rhythmic noise coming from each wheel when it gets above 35 mph, and it gets faster along with the speed of the car. It’s not a growl but it’s definitely noticeable. From the front seats you don’t hear any noise from the front wheels, only the back wheel noises.
    I jacked up the car a few inches with the car off and in park and on each rear tire there was no play when I tried to tug on the wheel, in neither the 3-9 or 6-12 positions. I also spun the wheels around and heard a metal-on-metal scraping noise, as well as a little rattling in the passenger side wheel.
    Sounds like the mechanic is right, but before I take it in for an $800 job, could it be anything else? Could the new brakes be causing any of these noises? The brakes seem to work fine.
    Below are links to videos of me spinning each wheel, and to a recording (ignore the video image) of what it sounds like from the back seat. It's a recording of a recording but you can still make out the rhythmic noise.
    Thanks for your input PC community!
  2. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    Hard to tell from a recording, but the scraping sound while spinning the wheels sounds like normal brake noise to me. During actual driving, the pads are normally pushed back a little by vibrations, so they don't rub as much as when spinning by hand.
    Unevenly worn tires can sound very much like bad wheel bearings. Even my experienced Toyota mechanic was not sure what it was, when I had noises. The only way to find out for sure before disassembling, was to swap the tires with new ones or used ones which are known to be good. In my case, it once turned out to be the tires, and another time it really was the bearings.
    Also could be flat spots or bulges on tires, balancing, out of round or wobbly rims, a bad shock absorber ...
  3. Mendel Leisk
    41,011
    The mechanic might have screwed up the rear caliper piston orientation when reassembling. It's very easy to do. There's a cross-pattern on the face of the piston that MUST be oriented like a letter X, and BE WELL SEATED THUS:
    (Repair Manual extract attached)
    I would suggest you raise the rear and try spinning the wheels. There's normally "slight" drag, but they should easily spin 2~3 revolutions:
    rogerdpack likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,380
    5,019
    Pacific Northwest, USA
    Yeah... I'd have the mechanic confirm their work based on Mendel's post... If the noise wasn't around before the mechanic worked on it I'd be reluctant to think it's the bearings until they get really bad and way noisier. And if you can get a noise from the wheels when car is jacked up I'd think that decreases the odds of it being a wheel bearing.
  5. itrontz
    NYC
    Thanks all...My wheel spins sound a lot like the one in Mendel's video, though there was also a slight rattling, as if something were loose, on the passenger side.
    I might just keep an ear on it and see if it gets worse. Car otherwise drives and brakes just fine. Tires look fine (they are regularly rotated)
  6. Paladain55
    Paladain55 Active Member
    402
    162
    The South
    I'm calling it now. Slide pins. My bet is they need grease.
  7. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
    Any update? :)
  8. priumium
    priumium Junior Member
    57
    Sweden
    Those slide/glide pins are the worst cultprit for friction created due to not floating at all. I even removed one that was bent and unable to move…
    Lubricant here is a touchy subject, but I use only thin layer of silicon grease when cleaned and/or replacing.
  9. ChapmanF
    17,783
    I don't know that there's anything touchy about it, just that like anything else, readers are entitled to know what Toyota's recommendation is. Toyota (for whatever reason, I don't know, I don't work there) specifies a "lithium soap based glycol grease"; if you get it from them, it's called Rubber Grease and it's red. 08887-01206 is the part number if you buy a whole tube, but that's often unnecessary because whenever you buy their caliper rebuild rubber kit there's a little packet of the right stuff in it.
    They do specify silicone greases (a couple different ones, even) for use on other parts of the brakes. They have diagrams with different-style arrows showing which parts of the brake get which kind of grease. (The diagrams have been posted here before.)
    My own experience, somehow, has never borne out the slide pins being "the worst culprit". When I have worked on dragging Prius brakes, I've most often found sticking of the pad ears in the "fitting kit" clips, and even found a piston simply failing to return (not seized, easy to move, but simply missing the 0.3 mm or so of return it's supposed to have when the pressure is let off and the internal rubber seal returns to its resting state) more than once, and that's more times than I've found a slide pin to be the culprit.
    Other than moving each slide pin a little bit in and out on each brake inspection, I generally don't even find one needing attention unless something has damaged its rubber boot and let salty water in.
    I wonder sometimes if "slide pins" aren't a bit like "fuses"—the parts out of a whole coordinated system that happen to be the ones most people have heard of, so they get posted about that much more, which feeds back into the cycle. Sort of like in so many posts about the car doing something funny electrically, no matter what the something funny is, the first post is likely to ask where's the fuse to change to fix it.
  10. priumium
    57
    Sweden
    Well, experience difference here likely depend on environment we live in… I disagree, ”most people” have never heard of slide pins.
    On gen2 the rear ones are notorious to get stuck up here, likely why gen3 added a rubber ring. But on mine they were still very stuck - with no boot damage..
    Just gave some tips based on my own experience with priuses in cold and salty Sweden. I know of Toyotas preference for Lithium grese, but our dealer recommended just use silicone grease when I asked five years ago, and they still move smooth on every winter tire swap.
  11. ChapmanF
    17,783
    The Toyota "rubber grease" differs from typical "lithium grease" ... while the thickener is a lithium soap, the base is a glycol, and the grease overall is kind of a transparent red. I don't think I would just describe Toyota's preference just as "lithium grease"; it seems more specific than that.
    Again, I don't have a strong opinion myself as to what people should or shouldn't use; my strong opinion is that when people come to PriusChat looking for info, the actual Toyota recommendation ought to be included in the info they get—along with whatever else people might be personally into.
