Automatic parking brake activation sound
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Oct 4, 2025.
  1. mannymendez25
    mannymendez25 Member
    61
    35
    Miami
    2020 Prius
    I have the automatic parking brake feature active when turning off the car, however, it seems to be annoyingly loud. When I park my car, get out of the car, lock the car, get the mail, bring in the garbage cans and all of a sudden, after all that time, I hear what seems like the parking brake activating. Is this sound normal?
  2. Mendel Leisk
    41,047
    Might be the evap system doing something, that has always been thus.
    Assuming you’re parked on level ground, right after getting out try giving the car a push, if it won’t budge a foot or so, the parking brake is set.
  3. ChapmanF
    17,832
    Can you record the sound?
    The parking brake, I would expect to get applied right as you park and turn the car off, not some time later.
    The fuel evap system self-test probably happens way later—not sure about gen 5, but in gen 3 it's five hours after turning the car off (sometimes longer depending on temperatures). It sounds sort of like a small fan running for several minutes near the back of the car. I'm guessing that's not what you're describing.
    Gen 3 has a brake system self-test that takes place 90 seconds after turning the car off. Sounds kind of like click-squish-click-squish-clickclick. Sometimes also with the sound of the pump running. Gen 5 might have something like that too, though the brakes changed a lot from gen 3 to 5, so I'm not sure what details carry across.
  4. mannymendez25
    61
    35
    Miami
    2020 Prius
    I believe I can disable the automatic parking brake feature. I live in Florida and the only hills we have here are parking lot ramps. LOL. I really don't need it. I will disable and see if the noise continues.
    PrimeDan and VelvetFoot like this.
  5. bisco
    51,607
    mine sounds like a noisy zipper
    Tande likes this.
  6. ChapmanF
    17,832
    A noisy zipper zipping when you park / turn the car off, right, not some get the mail and bring in the garbage cans later?
    Tande likes this.
  7. bisco
    51,607
    just when i press park. car can still be ready. and it only activates on a slope over so many degrees, i'm not sure how many
