Shake cold start
Discussion in 'Gen 3 Prius Technical Discussion' started by Renovatio07, Oct 5, 2025.
  1. Renovatio07
    Renovatio07 New Member
    Norman
    I happen to have my data logger on for live data when I turned the car on and had a shake/engine rattle this am. 202000 miles currently part of EGR cleaned front piping and complete cleaning of the intake manifold along with spark plugs replaced 199000. I am the second owner I bought it from auction local trade in. Possible small decrease in coolant hard to say. I can post the data but there are 320+ data points. Just need you all to pick which ones you want to see then I will post the data at the time of the shake thank you.
    IMG_3075.png IMG_3081.png IMG_3082.png IMG_3083.png IMG_3084.png IMG_3085.png IMG_3086.png IMG_3087.png IMG_3088.png IMG_3089.png IMG_3090.png IMG_3091.png IMG_3092.png IMG_3093.png IMG_3094.png IMG_3095.png IMG_3096.png IMG_3097.png IMG_3098.png IMG_3099.png IMG_3100.png IMG_3101.png IMG_3102.png
  2. ASRDogman
    ASRDogman Senior Member
    7,575
    3,906
    Head gasket.... If you read over PC, you'll find this is a common thing....
  3. Renovatio07
    Norman
    I understand head gasket is an issue along with egr etc…But I am unaware of some catching the engine rattle with data. This is more of the ability of seeing the beginning of the issue at hand. I have seen EGR system is the cause of the issue or like you said head gasket fails and leaks coolant. Just seeing if people want to see the continuous health of the engine as it declines.
  4. bisco
    51,901
    were there any trouble lights? sometimes it's just unburned hydrocarbons. keep an eye on the coolant
  5. Renovatio07
    Norman
    No warning lights at any point with ownership since June 2025
