Genuine Toyota gen 2 catalytic converter for sale?
Discussion in 'Gen 2 Prius Main Forum' started by Ianmeister, Oct 5, 2025.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    Hey all! So I live in Idaho now, and hybrid cars are smog exempt here. That being the case I pulled my Toyota original catalytic converter and shelved it for a rainy day. So this has me wondering what the market is for them these days? Anyone interested?
  2. PriusCamper
    PriusCamper Senior Member
    13,055
    5,304
    Pacific Northwest, USA
    There was a time you'd get $1600 cash real quick for them... But most of that went away when they busted up all the crime rings focused on them. Also, most states created laws requiring chain of custody documentation on selling them to rare metal extractors. As in that Cat you have has 2 grams of Rhodium, 2 grams of Platinum and 2 grams of Palladium. Do a search on current value of those metals and you'll realize the potential value. But process of extracting those metals is sketchy...
    On a more practical level, if at some point you just want to get rid of it and ensure its gifted to a low income person in need, I know someone that would be grateful to pay a modest price because a Seattle Toyota Stealership installed an aftermarket cat during the theft epicdemic in early 2000's and charged her thousands and it already failed a year after the 3-year warranty expired and she worries alot about the catalytic converter error code and it'd be nice to eliminate those text messages and the drive over to clear the code routine of it all from my life.
  3. ETC(SS)
    7,350
    This forum has a 'for sale' section that you might try.
    You live on free soil but you're close enough to some who are not to make a sale worth while.
    The G2's are like WW2 vets.
    Heroes all - but not many of them are left and so the demand for an actual working OEM cat is falling off rapidly - and remember....YOURS is used.
    You may have yanked it out of your car right after you drove it off the lot. or it may have 250,000 miles on it.
    Or?
    It might be stolen.
    WHO is to say?
    I'd try the for-sale section of this forum first.
    Good Luck!
    xw20_driver and Merkey like this.
  4. Hayslayer
    Hayslayer Active Member
    461
    265
    2g each may be optimistic, but they're not worth anywhere even close to the values they had during the pandemic when Rhodium went to ~30k or so/ounce.
    Current prices: 31 grams per troy ounce
    Rhodium: ~6900/ounce=about 222/gram
    Platinum: ~1650/ounce=about 53/gram
    Palladium: ~1350/ounce=about 44/gram
    So best case if 2g per metal, precious metal value is now $638 after processing.
    At the peak during pandemic, a set of Gen 2 cats were going for $1800+ on ebay, for scrap value.
    Currently, a good original Toyota Gen 2 OEM exhaust pipe, is likely worth much more to an owner living in a CA emission state who has a P0420 code than to any scrap dealer.
  5. xw20_driver
    xw20_driver Member
    101
    53
    PNW
    Is this the same cat you pulled 2 years ago from here??
    April 30 2023:
    PriusCamper and bisco like this.
  6. PriusCamper
    13,055
    5,304
    So grateful for the way folks on PriusChat always remember stuff like this so people don't get ripped off buying junk!
  7. Tombukt2
    13,408
    2,415
    I don't understand the looks like it was packed with sand business what in the heck does that mean iftuayve
    Was case turn.pipe up and sand runs out????. Or the bricks broken is more likely?
  8. PriusCamper
    13,055
    5,304
    I'm not saying I know what happened to this cat... But... Some people use rebar to unclog a cat... Also when you extract the precious metals you pound the honeycomb material into a sand like consistency before starting the process of extracting the rare metals.
  9. Ianmeister
    316
    319
    Meridian Idaho
    no it’s not.
  10. Tombukt2
    13,408
    2,415
    Yeah I do that all the time bust up the brick vacuum it out knock It All out put the original cat container back in the car now it look and in place Wella use a circuit board to turn light off forever . That boards in between lower 02 sensor and entry plug buried .
