Does anyone use Techstream to run the oil pump?
Discussion in 'Prime Main Forum (2017-2022)' started by ZachAZ, Oct 7, 2025.
  1. ZachAZ
    ZachAZ New Member
    Tucson, AZ
    Just curious, and I know it's not necessary, but does anyone use a Techstream to activate the oil pump to prime the system after an oil change? I was thinking, I believe it's an electric pump, you could turn it on to fill the oil filter housing before you drive it. Kind of like filling your oil canister before spinning it on.
  2. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    That would be news to a lot of us
    BiomedO1 likes this.
  3. ZachAZ
    ZachAZ New Member
    Tucson, AZ
    Okay, that makes sense then. I'm just an idiot. I thought I saw somewhere the 4th gen had an electric pump. Honestly, I'm glad it doesn't. Thanks for your quick reply!
  4. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Fuel & coolant pumps are electric, and thus controllable by Techstream for diagnostics, but the oil pump is still mechanical for reliability's sake.
    Welcome aboard!
    otatrant likes this.
  5. VelvetFoot
    VelvetFoot Active Member
    1,129
    446
    New York State
    2026 Prius
    Probably steering pump as well.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,264
    870
    Monument, Colorado USA
    Yea it's fine not to fill a new oil filter with oil before installing it.
    In older big diesel engines, you do want to fill up the filters because they are so big, the lack of oil pressure while they are filling isn't good. The filters in diesels are much bigger than gasoline engines.
    You do want to lube up around the filter with oil before inserting it and, also, check to ensure the old filter's rubber seal isn't stuck up on the engine. (I've never seen Toyota filters do this but I did have a Fram filter do this, years ago, in my Chevrolet Z-24.)
  7. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    There is no steering pump. The steering assist is electric, but they don't use the electricity to pump fluid- they just use it to move the mechanism directly.
    VelvetFoot likes this.
  8. VelvetFoot
    1,129
    446
    New York State
    2026 Prius
    Interesting, thanks.
  9. notspam3
    notspam3 Member
    78
    Toronto
    2024 Prius Prime
    XSE Premium
    would be cheaper to let the dealership do all your oil changes than get the subscription and device
  10. BiomedO1
    4,018
    2,109
    SacTown, Ca
    If you want to fire up the engine after an oil change; put the car in ready mode then hit the front windscreen defrost button. That will force the engine-on; You won't have to deal with the witch-doctor dance to get the car into maintenance mode.
    Hope this helps.....
    ZachAZ and VelvetFoot like this.
  11. ChapmanF
    18,454
    For sure, if your dealer works incredibly cheap, or if you hideously overspend on the subscription or device.
