Reverse polarity issue 2009 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by arlofleenor, Oct 6, 2025.
  1. arlofleenor
    arlofleenor New Member
    My 2009 Prius died after having not been driven for a week or so. This was an almost brand new battery. All attempts to charge it have resulted in a "reverse polarity" indication even though the polarity is correct. Must be a shorted battery, but seems weird for a new battery... any advice?
  2. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    Return the 12v battery for warranty replacement.
  3. Tombukt2
    13,336
    2,401
    If you plug up the charger to another battery and correctly connect the leads red to plus black to minus and so on does the charger fail on that battery if yes maybe the charger.
  4. Hayslayer
    Hayslayer Active Member
    459
    264
    Yes, please post photos of the battery as it sits installed in the car and the charger.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Use a digital multimeter to measure the actual voltage at the battery terminals.
    Have you used this charger before? Does it work correctly on another battery?
  6. Hayslayer
    459
    264
    Someone goofing around and swapped the red/black plastic sleeves on the charger clamps? Similar to post #5, except turn on the charger and measure the voltage on the charger. Red to Red and Black to Black and the voltage should be a (+) value. If it's negative, then the sleeves are probably reversed.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,789
    832
    Southern California
    Many chargers will not put any voltage on their clamps unless they have already determined that the battery to which they are attached has the right polarity and has at least the minimum voltage that the device supports. So it isn't possible to measure the voltage on the charger unless it is attached to a "good" battery.
    I second "use a voltmeter on the battery".
    Note, car batteries dropping dead shortly after being put into service or being DOA is a thing. We had a Bosch battery once which came with a reasonable voltage but either died the first time it had to supply cranking amps or was already broken before that.
  8. Hayslayer
    459
    264
    I guess it just depends on how new the charger is.......some of us old timers still own things that work for more than a few years.
