Fitting mobility 12volt AGM battery.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Britprius, Mar 3, 2013.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,670
    791
    Southern California
    Commenting on an old post, but here goes anyway. That Duracell battery has very large terminals and the bolt used to attach the OEM battery clamp is too long. It isn't shown in any of the pictures but I imagine that half of that terminal and the extra inch (?) of bolt past the nut are hanging out in full view once the red snap on cover is in place (if it can even snap on). The part which on the OEM battery covers the positive post completely. This strikes me as potentially unsafe. There is a very good reason car manufacturers cover up the 12V positive post as thoroughly as possible. While nothing untoward will happen in normal usage, life could get quite exciting if any conducting object happened to contact that exposed metal at the same time it was also in contact with a ground. For instance, a dropped ratchet with an extension and a socket, with the socket landing on the hold down bolt for the clamp.
  2. pasadena_commut
    2,670
    791
    Southern California
    I had some questions about the BLRFM12_55 battery and wrote to the manufacturer ExpertBattery. Their customer service for this was first rate, and they answered all of my questions promptly. However, their last message was interesting enough that I'm going to share it here:
    I'm afraid the points they make most likely pertain to many of the batteries discussed in this thread. It doesn't mean these batteries won't work for a while, or even many years, just that they will not work as long as they would in the environment for which they were intended. A UPS battery, for instance, typically spends its entire working life in a (nearly) vibration free and temperature controlled environment. It also doesn't mean that using these alternative batteries will not end up being less expensive than using the pricey Toyota OEM batteries. However, it does suggest "for the best results" vibration resistance should be given considerable weight in battery selection.
    The problem with the Prius, at least my Prius, constantly charging the battery at 14.1V (in READY if virtually any "extra" current is used, even Fan speed 1 or turning on the running lights) is discussed here:
    Oddity with 12V battery voltage measurements andtranmission | PriusChat
    and it turns out several people have discovered this over the years. This issue will affect any installed battery, so it isn't a deciding factor for or against any particular model. However, it implies that since the car is likely to shorten the life of any battery by overcharging it, one might as well use a less expensive battery rather than pay more for a "longer life" which will not be obtained. Will the lack of mechanical rigidity take out a battery like the BLRFM12_55 before it is charged to death by the car (or succumbs to Southern California heat)? I don't know. Wish I did.
  3. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    As I have stated in your other thread, where you focus myopically on this particular behavior in your car, I do not see this same behavior in either of my Prii. You cannot, therefore, extrapolate your observation across all Prii to conclude that they all excessively overcharge the battery and destroy them.
    From my reading of the "several people [who] have discovered this over the years", it seems, mostly, that they do not drive their Prii enough for the car itself to maintain the battery properly, end of story.
  4. pasadena_commut
    2,670
    791
    Southern California
    The higher voltage in READY results when any current draw above the base for that power state is encountered. Turn on the running lights, it goes to 14.1 V, turn them off, it drops to 13.6V. Same thing with the fan, rear defroster, and so forth. The auxiliary battery isn't the cause of this voltage change, although a weakened auxiliary battery can result from it. Well, if the battery itself needs charging the current it draws while doing so will also trigger the transition to the higher voltage. I don't think the converter in the inverter cares what part of the car is drawing this current though, only that it does. I also don't know what fraction of Prius's do this. That it isn't reported more could be because very few drivers leave a voltmeter plugged in or the diagnostic screen on the MFD on while driving. Or some Prius may break this way. The repair manual is no help, as far as I can tell it is absolutely silent about what the "12V" voltage should be under these various conditions.
  5. dolj
    dolj Senior Member
    8,450
    4,291
    Like I said, I don't see this jumping to 14.x any time a small load is introduced. It goes up sure, depending on what is switched on. but it might go up 0.2 V from where it is at best.
    The only time I see 14.x volts is if the battery is significantly low in SoH (70% or less), and I use this as an indication that I need to get the battery on the charger.
  6. pasadena_commut
    2,670
    791
    Southern California
    As I post this the 55Ah battery linked above is $184 and the Walmart Everstart Platinum S46B24R (45Ah) is $178. Most of the S46B24R batteries from different brands and sources are listed for over $200 though. The Walmart battery has a 4 year warranty, twice that of the "highest warranty in the industry" of the 55Ah battery. (For whatever the battery warranties might be worth, which has historically not been much. We can be pretty confident Walmart will be around in 4 years, somewhat less so for "Chrome battery".) Whatever their other merits, the Walmart battery is a direct fit, so no need to finesse the installation. The Mighty Max UB12550 is still listed as $120 on Amazon and is the biggest bargain of the bunch. Assuming it holds up in use.
    This Toyota dealer is selling OEM cheap ($189) for some reason, might be old stock? Or maybe it is the 35Ah one. The picture shows the posts reversed, so maybe it isn't actually S46B24R. Pick up only in San Antonio, TX, so not a source for everyone.
    Battery 12V #00544-21171-325 | Autoparts.toyota.com
    Edit: 30 minutes later the link is showing a price of $135 for the Chrome Battery. Strange. It is a lot more attractive at the lower price.
    #606 pasadena_commut, Oct 27, 2025
  7. PriusCamper
    PriusCamper Senior Member
    12,800
    5,185
    Pacific Northwest, USA
    They used to be called "expert battery" and when I clicked on link it was only $135 and no core deposit. You got your glasses on?
    Also, I bought a battery from walmart for an old Toyota truck a little over a year ago and the price they post is not honest.
    Once you pay taxes, hazardous waste fees and cored deposit and some other weird stuff (depending on what state you live in) you'll likely be up over $250 with your walmart purchase.
    Buying a battery online is way easier and way cheaper. As for what holds up in a Prius, the only problem with that is weak sauce charge amps to 12v.
    #607 PriusCamper, Oct 27, 2025
  8. pasadena_commut
    2,670
    791
    Southern California
    They look like different companies.
    17823 Commerce Dr,
    Westfield, IN 46074,
    [email protected]
    (317) 564-4278
    vs.
    [email protected]
    6437 Alondra Blvd. Paramount, CA 90723
    +1 (562) 630-3002
    Oddly technical support for Expert Battery is (216) 452-7437, which is in Ohio. Not quite Indiana, but closer than California.
    I have no idea why the price changed. User error is always possible, the high price might have come off the wrong tab or something like that.
    The "name brand" battery makers charge more for their 55 Ah batteries. An Interstate DCM0055 has a suggested price of $215 and an MK M40-12 SLD M is around $185. (Couldn't find the MK M55-12 SLD M for sale anywhere). It would be nice if the big companies that make batteries for Interstate, Toyota, DieHard, and so forth would identify themselves, or better yet, sell directly, but that isn't how this industry works.
  9. PriusCamper
    12,800
    5,185
    I wonder if Expert battery was acquired by Chrome battery? And yea... There's too many middleman in the battery sales business. Also alternatively Jack sells a Sodium 12v: The ultimate 12v auxiliary battery with JK Active-Balance Bluetooth BMS - NexPower Energy
