My HV battery is at 8 bars and reads 62% charge on Hybrid Assistant phone app
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 25, 2025.
  1. ski.dive
    ski.dive Active Member
    963
    242
    Hutchinson Island,FL. Mt. Snow,VT
    Is 62% charge still a decent percentage for the hybrid battery with 8 bars?
    51,719
    oh ya, you're good to go for the long run. think about it, you've lost 38% in 17 years. that's only 2%/yr.
    qmanqman likes this.
  3. ChapmanF
    17,928
    Is the 62% shown in HA a state-of-charge reading, or some kind of life-of-battery estimate?
    My guess was it was state-of-charge, and sounded just fine to me. The actual % charge range the car tries to stay in is no lower than 40% and no higher than 80% (with rare exceptions), and the car tries hard to be right around 60% in the middle nearly all of the time (so it has energy to give you if you mash the go pedal, and also has room to store energy if you use the brake).
    The bar graph on the dash does not cover a full 0% to 100% charge range, but is more like zoomed in to the 40% to 80% range the car likes to use. A 62% actual state of charge will be shown somewhere in the upper range of the bar graph.
  4. Hayslayer
    Hayslayer Member
    367
    207
    I'm pretty sure the Gen 2 MFD only has 8 bars total for displaying Hv battery status.
    If SOC is ~40%, only the bottom 2 bars will be on and will be purplish.
    If SOC is ~>40 and <~62% up to 6 bars will be lit and will be bluish
    If SOC is >~62% through ~80% the 7th and 8th will come on and all bars will be green.
    8 bars and 62% SOC sounds off a bit to me. At 62%, it should be either 6 blue bars or barely hitting 7 green.
    This is also based on Techstream readings, not HA. Idk the accuracy HA, but you would think it reads directly from the car ecu.
    Brian1954 likes this.
  5. ski.dive
    963
    242
    CORRECTION-
    I have 6 blue bars not 8 blue bars
    6 blue bars-reads 62% charge on Hybrid Assistant phone app
  6. ChapmanF
    17,928
    Sounds just about right.
    I suspect, too, that the scaling between actual SoC and number of bars displayed is fixed, and so won't really be something that tells you anything about battery health.
  7. dolj
    dolj Senior Member
    8,391
    4,271
    Wellington, New Zealand
    According to a post I read a long while ago, there is a measurable overlap between SoC and the bar displayed. I don't think that changes the second half of the sentence, though.
    Here is the graphic I harvested from that post, as I found it interesting.
  8. ChapmanF
    17,928
    Interesting. What I meant by 'fixed' could include that: to have hysteresis, there'd be different SoC points when going down vs. going up for changing to the next lower or higher bar, but I suspect that's all in the ECU firmware from the factory and doesn't, for example, change over time to reflect battery aging.
  9. qmanqman
    qmanqman Active Member
    422
    143
    CO
    I believe the bottom to top range of the 10 bars is 40-80%. With 10 bars total that would mean each bar is 4 percent. So five bars should be 40% + (5x4%) = 60%
    So ya, sounds about right
  10. dolj
    dolj Senior Member
    8,391
    4,271
    There are only eight bars on the Gen 2 Energy Monitor Screen.
    Five bars is 52% to 57.5%.
    Six bars is 55% - 66.5%.
    Each bar is not linear; there is overlap between bars. Complete information is shown in the graphic in Post #7.
    #10 dolj, Oct 8, 2025
  11. qmanqman
    422
    143
    CO
    Not in my world . . . loll
  12. dolj
    dolj Senior Member
    8,391
    4,271
    Could you remind me of the data you collected to support that assertion?
  13. ChapmanF
    17,928
    Maybe "each bar is not linear" just wasn't a perfectly clear way of saying it. "There isn't a linear scale from %SoC to number-of-bars" would be a longer, fussier way of saying it, but sometimes a little fussiness helps keep everyone on the same page.
    The nonlinear scaling from %SoC to #bars is easy to see in the image from #7—and also the hysteresis (the way the number of displayed bars will change at a different %SoC when going down than when going up).
    One of those cases where the picture may not be worth a thousand words, but probably does need more than five.
