Brake master cylinder and booster pump
Discussion in 'Gen 3 Prius Technical Discussion' started by ShutterSpeed, Oct 8, 2025.
  1. ShutterSpeed
    ShutterSpeed New Member
    Alabama, United States
    hi all!
    having an issue with my 2011 Prius where the 12v battery is consistently dead. I mean no lights, chimes or anything, dead. Swapped in a new 12v and it started like a charm but was dead again the next day.
    Now at a hybrid tech (not dealership) they are saying it’s the brake master cylinder and booster pump assembly that is running too often (that buzz when the car turns on/off or when mechanical brakes kick in). Could that be a cause for parasitic draining?
    I’ve seen the recalls and issues with this bit on many forms but I can’t seem to find anyone else running into this issue draining the 12v while the car is off. Hoping someone can confirm before I spend $3000 on the repair.
  2. JC91006
    JC91006 Senior Member
    16,825
    8,600
    if the brake actuator were bad, there should be a code. That would be the real confirmation.
    I think the battery you put in is not a good battery or it wasn't fully charged when you installed it. I would probably return it and get another one.
    I don't think the actuator would run long enough to drain a good battery
  3. ShutterSpeed
    The tech said that it was going on every few seconds after shut off and that’s the cause of the parasitic drain. The logic makes some sense to me but I can’t find a single other example of this issue on these forums or anywhere else online. :/
  4. rjparker
    10,436
    6,544
    There are simple tests for parasitic draws with a series ampmeter. Know how big of a draw you have first before spending money for parts. Parasitic draws are somewhat common and are often aftermarket gps, radios or obd2 devices.
    Measure and report back. If your mechanic did not suggest testing go elsewhere.
    Brian1954 and ShutterSpeed like this.
  5. ChapmanF
    18,484
    It's easy to hear the brake pump running, so that's an easy check for whether it could even be the culprit.
    In a good unit, it should run hardly at all when the brakes aren't being used, like, you'd have to leave the car turned on for an hour or so to hear it run again.
    Many people keep driving with obviously leaky units with the pump running as often as every ten seconds or so, with nobody using the brake—which, despite being something like a hundred times worse than a good unit, often won't have set any trouble code yet.
    If it kept on doing that, every ten seconds, all night while the car was off, I could easily see that draining the battery. The thing is, I don't think it does continue to run indefinitely with the car off. I think it may keep running like that during the first minute or two after turning the car off, and of course will begin again as soon as the driver's door is opened the next morning. But for the bulk of the time the car is off, I think the brake system does shut down.
    So that's why I would be skeptical of the brake pump explaining the overnight battery drain.
    ShutterSpeed likes this.
  6. VelvetFoot
    VelvetFoot Active Member
    1,161
    459
    New York State
    2026 Prius
    Barring a legitimate test, if you had a wireless security camera you could point it at the car in the garage overnight. My cheap Roku cameras can be activated by sound, but I guess you'd have to test to see if it actually works.
  7. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Right, even with a leaky actuator, the brake pump shouldn't discharge the battery while the car is shut down (i.e., not "READY") with the driver's door closed, unless something's wrong with the door switch or brake switch
  8. h00ktern
    h00ktern Member
    135
    40
    Going through the same, precise, scenario.
    Short answer, have the battery load tested at the place you bought it from. My new battery was in fact bad and required warranty replacement - after two weeks. It was bad from the beginning.
    Additional info: I wasted five hours this morning, doing a full on module sleep and parastic drain test, only to see my car will sleep at only 0.001-0.003 amp draw. If not asleep, and the brake booster motor runs, there's like a 5.x amp while it runs.
    I wish I just load tested the battery to start with. Only good thing is the time spent gave me some insight into my cars situation. I'll be looking for an OEM parts supplier that isn't going to rape me on prices, to swap out the master cylinder & brake booster to finish this chore.
    Safe trips,
    Dave
  9. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    ALWAYS charge "new" batteries before installing it. They sit on the shelve for months at a time.
    Slowly discharging....
