P0a72-515 engine error code help
Discussion in 'Gen 2 Prius Technical Discussion' started by Spencer MaeCroft, Oct 6, 2025 at 6:58 PM.
  1. Spencer MaeCroft
    Spencer MaeCroft New Member
    Monday
    Indiana
    I have a 2008 Prius that has an intermittent warning light on the dash with error code P0a72-515. I downloaded the diagnostic papers for this error but just wondered if anyone else has encountered this error and found a solution.
    I’ve also read that the inverter is a low issue part and often times not the actual issue so I wanted to test out other potential problem sources before replacing the inverter.
  2. Tombukt2
    12,730
    2,276
    This is where there's a phase problem on the output generator motor or something like that right I wouldn't inverter itself could finar phasing . Would think that would happen actually at the motor generator ?
  3. ChapmanF
    17,826
    I hope when you downloaded "the diagnostic papers" you mean you got the section for that code from the Toyota repair manual. This link might work (though when I open it the spaces look funky on the last couple pages—still readable though).
    The code reports a problem with the current sensor reading for the V phase connection of MG1.
    The current sensors (two of them, a main and a sub) are located inside the inverter housing. In gen 3 there's an "MG ECU" right inside that housing too, but in your gen 2 there isn't: the sensors are inside the inverter housing, but they are wired to the HV control ECU under the dash. You can see how the troubleshooting instructions tell you to check that wiring and those connections first, and if you find the problem there, you just fix it.
    You can see that inverter replacement (huh, I guess they didn't sell the sensors separately?) is only the last step, only if you didn't already find the problem with the wiring or connections.
  4. Tombukt2
    12,730
    2,276
    Easy job then . At least no messing inside trans and plentiful .
  5. Spencer MaeCroft
    Monday
    Indiana
    I appreciate the reply. Yes I meant the Toyota repair guide. I checked the connections from the inverter to the HV control module under the dash and everything looked good as far as I could tell. The connections passed the voltage tests but I don’t have a milli-ohm tester for the resistance checks.
    I read that an actual issue with the inverter is very rare in this car but then again this error code doesn’t seem super common either so maybe it really is an issue with the inverter and it needs to be replaced. I feel like this might be my best next move.
  6. ChapmanF
    17,826
    I don't see any need of a milli-ohm tester for the P0A72-515 troubleshooting steps.
    When a wire measurement "good" value is given as "Below 1 Ω", that's just telling you it should be a wire, and not broken. The nearest handy multimeter can tell you that. When a between-wires measurement is supposed to be "10 kΩ or higher", that just means those wires are meant to be isolated from each other, not shorting. Again, any simple multimeter is good enough for that.
    If there turns out to be nothing wrong with the wiring, that would seem to leave the current sensor itself. I would wish for a chance to replace only that ... you can get it separately in gen 3, but maybe you can't in gen 2.
