Cannot fill more than 2 to 3 gallons in 2008 Gen 2 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Giri, Oct 9, 2025 at 3:33 PM.
  1. Giri
    Giri Junior Member
    Had been to Prescott where temperatures were 40 deg and in AM the fuel gauge strats blinking. Itried to fill in Costco and within 2.5 gallons it tripped off. I was able to add another 1/2 a gallon. Back in Phoneix, temps were 80's and I still was not able to fill more than 2 gallons. I pulled the hose and slowly filled and after multiple tripping I was able to fill 4.9 gallons and the fuel was full till the neck. I had to shake the vechicle to let fuel go in by shaking the car by rocking it.
    What could be the issue. Do I need to change the fuel tank itself or will change in Charcoal canister or vale or EVAP Valve will do the trick.
    Has anyone done a step by step Do it your diagnosis and can share
  2. pasadena_commut
    pasadena_commut Senior Member
    2,490
    743
    Southern California
    Was the fuel gauge still blinking when the tank was full to the neck?
    Once the car has been driven 100 miles or so return to a station where you have previously filled the tank without issue. Using the same pump, fill the car. Problems? (Some model gas pump handles do not work well with the Prius. It won't fill with one of those, but that also won't make the gauge indicator flash.)
    Scan for codes.
    This might help (probably not):
  3. Hayslayer
    Hayslayer Member
    345
    188
    Well, I guess this means the tank is as full as it's going to get, bladder good or bladder bad. What did the gauge show? was it still blinking? If so, you have a sender unit problem and possibly now a charcoal cannister problem if fuel leaked into it from being so full. The fuel gauge will also blink if you had a loss of 12v power, until it recalibrates itself, which is usually within an hour, but does vary sometimes. A loss of power on the 12v system will also cause your radio station presets to go away and the automatic raise/lower feature of the driver window will stop working until you reset it. What's the status are those items?
  4. ChapmanF
    17,829
    You'll probably benefit from reviewing this post (and the outcome of the thread it appears in).
