Toyota safety sense
Discussion in 'Gen 5 Prius Technical Discussion' started by HamiltonPrius, Oct 11, 2025.
  1. HamiltonPrius
    HamiltonPrius Active Member
    224
    110
    Parts unknown in Virginia
    2026 Prius
    Hello, I have a XLE on order and I have a question. Does my Prius come with rear automatic braking? I believe it has front auto braking but not sure about the rear. The salesman said it did but I’m not sure he’s right. Can someone clear this up for me?
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Hi. I'm waiting on an LE and was curious.
    It sounds like you're looking for: "Front and Rear Parking Assist with Automatic Braking (PA w/AB) *"
    Per the Toyota web page, it looks like the XLE has it, but not the LE, alas.
  3. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    If I recall correctly, no-one has ever found an LE without that "available" option.
  4. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    You're correct.
    I just looked at my build sheet and it does have that $35 option. $319 for floor mats, though? Outrageous. :)
  5. HamiltonPrius
    224
    110
    2026 Prius
    Thanks for the responses….What I’m asking and probably didn’t explain myself fully is……if I back my 2026 Prius XLE up and it gets close to an object will the car automatically brake so it doesn’t hit whatever is behind me?
  6. HamiltonPrius
    224
    110
    2026 Prius
    VelvetFoot, what model year do you own?
  7. HamiltonPrius
    224
    110
    2026 Prius
    VelvetFoot, I have you beat, my XLE is coming in with this option ……
    Preferred Accessory Package w/ All-Weather Floor Liners
    Comprehensive package of preferred protection accessories. Includes….
    First Aid Kit
    All-Weather Cargo Mat
    Rear Bumper Applique
    Cargo Net: Spider
    PIO $483.00…ugh
    VelvetFoot likes this.
  8. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    It's a '26, approaching the Panama canal.
    The next question is what does $1,195 get you? Lol.
    HamiltonPrius likes this.
  9. HamiltonPrius
    224
    110
    2026 Prius
    Ok …..sorry for all the posts but I did a little more checking and it looks like it is available as an option as VelvetFoot said.
    So that leads me to ask another question…can the Front and Rear Parking Assist with Automatic Braking be added as a software update since all of the sensors are already on the car?
  10. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Yes.
    No-one can say, because no-one's ever had a car with it not fitted. It's standard on the XLE, and always fitted to the LE despite being "available".
  11. HamiltonPrius
    224
    110
    2026 Prius
    From what I read it’s a $35 option….not standard equipment but I could be wrong
    Can you post a link that states it’s standard on the XLE?
  12. HamiltonPrius
    224
    110
    2026 Prius
    #12 HamiltonPrius, Oct 11, 2025
  13. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    No, as others said, it is standard (not optional) on all Gen 5 Prius HEV/PHEV vehicles that have been made, regardless of whether it is shown on the window sticker or vehicle specs or not.
    I have it on my Gen 4 Prius Prime Limited PHEV, and it automatically braked while reversing in several occasions. So, it works.
    #13 Gokhan, Oct 11, 2025
  14. HamiltonPrius
    224
    110
    2026 Prius
    Toyota’s Prius build page states on the LE it’s a $35.00 option. So you saying their official site is wrong?
  15. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    How can you state that so definitively? Do you have proof of an LE or SE without the $35 option that still has F/R Park Assist w/ Auto Breaking or are you just making assumptions?
  16. Gokhan
    6,715
    2,672
    Paramount CA
    Correct. Many LEs/SEs were sold without that option, but they all had the parking sensors.
    There has been no report of any LE/SE that came without that option and didn’t have the parking sensors.
    My best guess is that Toyota never sourced bumper covers without holes for Gen 5, and they had to install parking sensors on all cars as a result, regardless of the option. Originally, the $35 option, which is silly, given how expensive these sensors are and how difficult to calibrate them is, was omitted on the window sticker despite the cars having the parking sensors, but chances are that all LEs/SEs these days have this option included on the window sticker as well.
  17. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It appears to be more than just software. The basic sensors are the same, but I'm seeing 3 different part numbers for the clearance warning computer.
    It appears like:
    89340-47100 - LE/SE - without auto braking?
    89340-47160 - all trims - with auto braking?
    89340-47170 - LTD w/ Panoramic View Monitor and Advanced Park(auto park)
    I'm seeing an LE without the $35 option coming to one of my local dealerships sometime in the next month. I can't guarantee anything, but I'll try to make a trip there after it comes in and see if I can get access to it for a couple minutes. If it still has park assist, it should have settings for it in the options menu. I'll look at the menu in my LTD first to confirm what options should be there to compare.
    #17 Hammersmith, Oct 11, 2025
    KMO and Gokhan like this.
  18. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's not sensors, it's the computer. (see my post above)
  19. HamiltonPrius
    224
    110
    2026 Prius
    Can’t the sensors be installed but not activated unless one pays for the $35 option? Kind of like the digital key? The digital key is an option you pay $275 for the privilege of using it for 1 year and then it goes away without a subscription.
  20. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If I'm correct about the computer, it would be about $185(new) if you did the job yourself. You'd need the replacement computer and then install it on the passenger side inside the dash. I'm not seeing any different wiring harnesses listed between the LE with or without the parking assist, so it appears to be a straight swap without any additional wiring needed.
    (I may have the part numbers for the computers reversed, so definitely don't order without some confirmation.)
