Breaking the Right Rear Quarter window
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Arkay, Oct 11, 2025.
  1. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    I hope someone can give me some advice.
    Someone broke the right rear quarter window of my 2013 Plugin Prius and then folded the right rear seat.
    I am trying to figure out
    1. Which part to use (VIN has DP in the 7th, 8th places). I think it is 62710-47130, but I could be wrong.
    2. How do I close it up so I don't have the thief come back in and, this time, remove the battery pack?
    3. That little piece of glass is $215. . Where can get a less expensive alternative?
    4. And yes, I'll probably try to figure out how to do the actual work.
    The insurance deductible is $500. I don't have much incentive... to go that route.
    Thanks
  2. BiomedO1
    3,581
    1,856
    SacTown, Ca
    That looks like it's a simple piece of glue-in glass.
    1. What you can do now is measure or template out the dimensions of the glass. Go to home depot or Lowes and cut-out that shape in a 0.25 inch board and buy a 18 inch two by 4. Run a long rounded head bolt through the center of the glass board and 2by4. Tighten it down on the inside. The outer surface should be fairly smooth.
    2. Think about adding a motion & glass breakage sensor to your alarm system.
    Good Luck......
    Arkay likes this.
  3. ChapmanF
    18,155
    The right rear might have a radio antenna included, maybe why the price is surprising. Are there some wires near what's left of the old one?
    Maybe consider a sign asking thief to break the left one instead?
    #3 ChapmanF, Oct 11, 2025
    Arkay likes this.
  4. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    I wish they were that cooperative. They do more damage than the property they steal.
    I didn't see any wires, though. I cut a piece of ply to the shape and attached a steel wire to the inside. Then I tied the steel wire to the seat headrest posts.
  5. bisco
    51,899
    great macguyver!
  6. BiomedO1
    3,581
    1,856
    SacTown, Ca
    Just be aware that headrest simply pulls out. Some has a release button at one of the post base.
  7. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    Got it. Went back and checked to make sure that all the angles workout. Mine has a button, and if someone pulls on the ply, they will be applying tension that pulls the seat back, not forward.
    If they get to the button, then they are already in.
    Does anyone have any advice on how to install the window when it arrives? I saw the PDFs (see attached), but have a hard time understanding their diagram, let alone their explanation.
  8. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    I was finally able to install a window I got from eBay. Unfortunately, it did not have the antenna. I decided to not complain and install it anyway. Here are a few things I did.
    1. Used a simple wrecking tool to pry out the glass gently.
    2. What was left was the shattered glass stuck to a rubber molding ( right word?). Check the first image.
    3. I used gentle, persistent, and time-consuming elbow grease to slowly pry out the glass pieces off the rubber.
    4. There were still tiny pieces of glass stuck to the rubber; i removed the pieces by running my boxcutter over them.
    5. Applied 3M Glass glue:
    6. Stuck the bay glass on it. I had spent some time removing the old rubber.
    7. Used Packing Scotch tape. DO NOT USE Tape like Gorilla Tape, as they leave a residue. Don't ask me how I know.
    Now to find an FM antenna.
    The second image sort of shows what I did.
    bisco and Mendel Leisk like this.
  9. ChapmanF
    18,155
    Ah, so there was an antenna. :(
    I do think the main FM antenna is still in the stalk at the rear of the roof. The one on the quarter window would have been a diversity antenna. I suppose saying that gets me on some kind of list these days, but so help me, that's what it's called.
  10. Arkay
    Arkay Junior Member
    26
    Mountain View
    2014 Prius Plug-in
    Thanks!!! I'll probably use a $10 antenna if the reception suffers. No point in fixing it.
