Underhood +12V for DRL's
Discussion in 'Gen 4 Prius Technical Discussion' started by MrFixer, Oct 13, 2025.
  1. MrFixer
    MrFixer New Member
    UK
    2020 Prius
    Excel
    I bought a pair of Chinese-made LED Daytime Running Lights for my 2021 Prius. Fitted them into the bumper and they look good. The issue is that I need a source of +12V under the hood to power them up when the car is in the READY state. I really don't want to run a wire through from the passenger compartment. The only appropriate power I can find is the supply to the engine computer and I don't really want to tap into that. Any suggestions?
  2. BiomedO1
    4,019
    2,109
    SacTown, Ca
    The 2021's already has DRL's installed, controlled by the headlamp stalk - at least here in the states.
    You can use a relay to the battery and tap your current DRL wire near your headlamps for a signal.
  3. MrFixer
    MrFixer New Member
    UK
    2020 Prius
    Excel
    Thanks for the reply. My car has no DRLs as standard and I have not noticed a DRL wire. Any idea of location of DRL wire and/or color code please?
  4. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Sorry, don't know. These cars are on international platforms which some countries require DRL, so it's prewired and may require installing a fuse into the circuit.
    I found a DRL kit on Amazon, which has a wiring harness, which indicates that there is a tap under the hood somewhere near the front bumper. You'll need to consult a UK wiring diagram for your car.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Wire the DRLs directly to a hot power source (empty fuse slot, tap a high amp fuse, etc) using a relay with the ECU fuse (tapped) to switch the power to your lights.
    The relay's coil only draws current in the millivolt range, so there shouldn't be any problem with using that circuit.
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    One problem with using a fuse that supplies an ECU for a relay, detailed above, is that the ECU will power on periodically and run some diagnostic checks(?).
    I know this because it does it on our 2010 Camry and 2016 Corolla, causing the foglights to illuminate for a few minutes, then turn off.
    I installed a current sensing relay between the main relay used to switch power to the foglights on the Corolla and it keeps the foglights off. For some reason, it doesn't work on the Camry, so we just live with the foglights coming on every now and then. It's good that the foglights are LEDs, so not much current draw from the battery.
  7. PAW
    PAW New Member
    Herndon, Virginia, USA
    2022 Prius
    This does not directly solve your problem but may provide some insight: "Clearance lamp wiring" on a 2022 LE | PriusChat
