Gen2 OBD2 app review
Discussion in 'Gen 2 Prius Technical Discussion' started by mr_guy_mann, Apr 25, 2022.
  1. priumium
    priumium Member
    104
    26
    Sweden
    Perhaps in the year 2050 OBD3 data readers over BT8 are built in and everyone can read them with their phones. Go EU go… :)
    #241 priumium, Sep 15, 2025
  2. priumium
    priumium Member
    104
    26
    Sweden
    (Just wanted to mention that the amount of Sensors/PIDs available in Car Scanner PRO with the G3 profile is absurdly high. The page never stops scrolling, it’s info overkill. :)
    I now also have a Gen3 PHEV 2014, aswell as two Gen2. Fascinating cars indeed. :giggle:
  3. A.J
    A.J Junior Member
    57
    Worldwide
    Does the Carscanner free version suppose to read Electric Water pump rpm?
    Mine is not showing anything and want to be sure if it means fault. Prius 2010 Gen3 with Carista OBD
  4. VelvetFoot
    VelvetFoot Active Member
    534
    172
    New York State
    2026 Prius
    On a side note, I asked the Car Scanner developer a question about whether it works with CarPlay (it does) and he got back to me the next day. Same with the OBD Fusion app developer, which also works with CarPlay.
    priumium likes this.
  5. rjparker
    10,083
    6,255
    Car scanner on gen3 does not work properly on water pump rpm. I have notified the developer several times and he claims it does. Testing is clearly an issue. They do have a point editor in the latest version but I have not tried it.
    I use two other higher dollar scanners when necessary. Car Scanner excels as an easy to use phone app with better graphics configurability than my other more elaborate scanners.
    Its interface is stored in the glovebox and ready to go for codes and most gen3 hybrid data. Of all data, coolant temps are essential which I monitor fulltime with a P10 obd2 display. That device also has early warning audible alarms setup for coolant among other things.
    #245 rjparker, Oct 9, 2025
  6. A.J
    A.J Junior Member
    57
    Worldwide
    I see, because it seems it sees the inverter water pump RPM but not the combustion engine water pump RPM. I will also submit request to the DEV
  7. rjparker
    10,083
    6,255
    The inverter rpm does not change in realtime using car scanner. The best test for either is bidirectional control followed by rpm. With coolant temp as priority. Don't run with high coolant temp especially if flashing your light.
  8. Tombukt2
    12,902
    2,317
    A buddy of mine buys pallet sale bull crap he gave me a yellow boxed gearwrench vci adapter. Looks like the thing retails for $140 bucks but cheap or free lemme tell ya this thing has lots options services functions . I know it's not gear wrenches proprietary so it's something they bought or it's another manufacturers but I don't know who maybe some will know.. Ive never seen. But it can do... Lots almost every standard etc . Has model coverage all over world . I've tried on multiple weird vag vehicles very capable . Bleeds brakes caliper wind down etc. it is pretty cool with a very easy to use interface and lotsa options pretty cool device .
    VelvetFoot likes this.
  9. Tombukt2
    12,902
    2,317
    Not being racist but you want the white one all white no colors on it at all the original
  10. VelvetFoot
    534
    172
    New York State
    2026 Prius
    Is this it? No update fees?
  11. rjparker
    10,083
    6,255
    There is a reason the $2k and higher scanners work and the sub $200 units have all kinds of incompatibilities which vary among vehicles. The software, testing and ongoing improvements. Most of the brands use one or two software engines with Launch being one of the best platforms. The gearwrench unit is a clone of a similarly priced Xtool unit at the same price point.
  12. Tombukt2
    12,902
    2,317
    That is the exact one and as far as I can tell there are no fees everything download updated I don't see any subscription adds or asks . I do not see anything in literature and I've used on Chevy and Toyoda and seen all the services in their menus
  13. otatrant
    otatrant Active Member
    321
    196
    San Francisco
    2023 Prius Prime
    XSE Premium
    What about VCX Diagnostics available from China? 40man on tundras.com forum posted about using their hardware with a version of Techstream they provide. Here is a link to one of his posts.
  14. VelvetFoot
    534
    172
    New York State
    2026 Prius
    Just scoping things out, on the surface for now, but that thread is two years old.
  15. otatrant
    321
    196
    San Francisco
    2023 Prius Prime
    XSE Premium
    Techstream 18.0 is supposed to have all 2023 Toyota models per their site here. The 5th generation Prius came out in 2023. I haven't purchased one but have come pretty close. I think the cheapest OBD diagnostic tool for Toyota is the VCX-SE which is about $180 on aliexpress. The one I think I would purchase would be the VCX DoIP which is about $300 and has ethernet, usb type-a and type-b as well as a more robust housing.
    I have seen several posts on a couple forums that the company has very good customer support and they respond pretty quickly. If I remember correctly it may require an internet connection and a PC for them remote in and set the software up if you can't get it working.
  16. Tombukt2
    12,902
    2,317
    You might want to look at X horse site again they the folks who make the vvdi key tool their vci cable is now 40 ish buc . It's rt their on site to view even returnable. I've posted the link before . Seems the VCI problem has been worked out as you see everybody has one now that works apparently .
    otatrant and VelvetFoot like this.
  17. Tombukt2
    12,902
    2,317
    Well that's great I knew somebody here would would have spent a lot of time with scanners like Sherwood Coke in Fla. I do not spend any time with if it's possible to not . My real tech software from dealer has been well as perfect as I guess it gets the sp 200 made me shelve the toughbook for an in pocket tool . This GW thingy looked familiar on menu . And so far is capable . 8 SE no asks for monthlies so far . For me it was given to me by friend who buys pallets he get car shiet brings it right over here . He don't wanna be bothered. Usually I don't either . But I will take a look.
  18. pasadena_commut
    pasadena_commut Senior Member
    2,586
    767
    Southern California
    This one is $111
    Xhorse XDMVJPGL MVCI PRO+ J2534 Cable New Version Multi-Vehicle and Multi-Protocol
    there is another variant for $88 but it is out of stock. Could be the price difference is entirely from tariff's. I have given up keeping track of those since they seem to change day to day. Probably goes up when Trump is constipated and grumpy and down if he has had a "good day".
    otatrant likes this.
  19. Tombukt2
    12,902
    2,317
    I think it's UHS supply that is the X horse dealer they have a 40 dollar cable one to USB A I think like the original red that came w tech.
  20. Tombukt2
    12,902
    2,317
