AWD vs FWD
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 14, 2025.
  1. HamiltonPrius
    HamiltonPrius Member
    210
    98
    Parts unknown in Virginia
    2026 Prius
    Which trim level on a Prius has a higher trade in / resale value…a AWD or FWD model? I would think it’s the AWD model for the simple fact it’s a more expensive car by $1,400 to begin with. Is the answer as simple as that or when it’s time to sell the car depreciation sets in and the difference in the original selling price equals out?
    #1 HamiltonPrius, Oct 14, 2025
  2. Moving Right Along
    Moving Right Along Senior Member
    732
    588
    In general, anything that makes a car more expensive is going to add something to its resale value. The amount any individual option adds will shrink over time with depreciation, but there should still be some kind of premium on an all wheel drive Prius as opposed to a front wheel drive, even after a decade or more.
    But if you don’t actually need all wheel drive and you’re considering whether or not to buy a car with it, the option is never going to be worth as much as you paid for it. That’s the nature of car prices, with very few exceptions.
  3. HamiltonPrius
    210
    98
    2026 Prius
    Actually I’m torn between 2 cars. The one XLE doesn’t have AWD the other does. But the car with the AWD is a much better deal, it’s actually a fantastic deal!
    I don’t want the AWD, I would rather get the better gas mileage from the FWD car but the overall deal for the AWD car might be too good to pass up.
    #3 HamiltonPrius, Oct 14, 2025
  4. Winston Smith
    Winston Smith Active Member
    407
    283
    OH
    2024 Prius
    LE AWD-e
    The Prius is a ton and a half car on weirdly skinny tires. Put all of a couple hundred hp through only two of those in slippery conditions and you will get outrageous understeer. I've found AWD occasionally helpful, though it does not eliminate understeer.
    The AWD weighs something like 140 pounds more than the 2wd, so I'm sure there is some penalty, but it isn't the penalty associated with mechanical AWD systems that may induce huge inefficiencies when not in use. If the EPA formula yields a 2% drop in efficiency, I wouldn't dispute that, but I would dispute your ability to notice the difference outside of very controlled conditions. I see greater differences in efficiency if I turn on the climate control. The difference between routes and driving styles will dwarf the 140 pound weight penalty.
    The car below is AWD.
  5. BiomedO1
    4,159
    2,179
    SacTown, Ca
    If your talking about resale; It's whatever the local market will bear. AWD doesn't command a much higher price than a FWD in the southern states. High trim cars will be priced similarly to those of low trim cars; again whatever the local market will bear. You may get a few hundred extra for that few thousands in extra options - but nobody really cares on a depreciated car. Take whatever offered or leave.........
    Just my two cents......
  6. Mendel Leisk
    41,913
    The AWD imposes additional maintenance if I’m not mistaken. A periodic fluid change?
    BiomedO1 likes this.
  7. BiomedO1
    4,159
    2,179
    SacTown, Ca
    Yep, slightly heavier and a mpg penalty. That couple of mpg starts adding up as you rack up the miles.
  8. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    No reason to leave it on "weirdly skinny tires". I switched to a wider option early in the game.
    douglasjre likes this.
  9. Mendel Leisk
    41,913
    Not everyone has deep pockets, and it does grate, buying a brand-new car, and near-immediately starting to replace stuff.
    #9 Mendel Leisk, Oct 14, 2025
  10. VelvetFoot
    VelvetFoot Active Member
    1,231
    480
    New York State
    2026 Prius
    195's are skinny?
    edit: Although I will say that 195 55 16 's were harder to find/more expensive to find for my MINI.
  11. RollingPanda
    RollingPanda New Member
    24
    Fort Worth Texas
    2025 Prius
    Limited AWD-e
    I was in the same situation. I when I was looking for my used prius, I found a few xle which were all fwd and then I found a 2023 limited awd which was priced several thousand cheaper with lower miles. It was a no-brainer for me. I enjoy the limited for the vented seats, power rear hatch, powered seats, memory seats, the larger entertainment screen, and the JBL speakers.
  12. HamiltonPrius
    210
    98
    2026 Prius
    I settled on the FWD over the AWD. This choice saved me money on the purchase price and I will get a little better gas mileage. I look at that as a win-win. I was looking for the best mileage I could get. I already gave up enough mileage going with the 19 inch tires and wheels. I love how the tires and wheels look on the car. I just didn’t want to sacrifice anymore mileage for the AWD.
    Tideland Prius and Gokhan like this.
  13. Hammersmith
    Hammersmith Senior Member
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just for perspective, assuming 15k miles per year and using the current US average gas price of $3/gal, the cost difference between FWD and AWD works out to be about $45/year.
    Winston Smith likes this.
  14. reservoirblue
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    Agreed. But spending an extra $ 500.- on what I consider a reasonably priced new plug-in hybrid (2024 Prime) at 34500.- was OK with me.
    douglasjre and Gokhan like this.
  15. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    What did you switch to?
  16. Mendel Leisk
    41,913
    We’re driving about 3k kms (yup) per year, it sometimes occurs to me we could pick most anything.
  17. Winston Smith
    407
    283
    OH
    2024 Prius
    LE AWD-e
    If you drive it for 750 years, it pays for itself.
    douglasjre and BiomedO1 like this.
  18. BiomedO1
    4,159
    2,179
    SacTown, Ca
    It's the maintenance cost that's going to kill you. If you stick to the thin OEM tires and need to replace one that's half worn; how will that AWD computer react to that? Can you get away with just replacing two on the same axle or would you need to replace all four. Some AWD systems are more sensitive than others. I don't know about Toyota system, but I know for a fact that Volvo AWD required 'shaving' that new tire or replacing all four to keep the traction computer from 'swanking'.
  19. reservoirblue
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    Pirelli P Zero All Season 215/55R17 94V Performance Tire- 94.- per tire at Amazon at the time
    douglasjre and VelvetFoot like this.
  20. Mendel Leisk
    41,913
    That's a good size: theoretical OD 26.3" versus 26.2" for the stock 195/60R17, and 26.7" for the other stock 195/50R19
    VelvetFoot likes this.
