Timing Cover Gasket replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Regulus, Oct 9, 2025 at 3:12 PM.
  1. Regulus
    Regulus Junior Member
    28
    sylvania,ohio
    I had my 2012 Prius C (166,000 miles) at the Toyota dealership for an oil change yesterday. They noticed a small puddle of oil under the rear end and showed me the photo of it. But I haven't seen oil on under my since I brought it home from the dealership.
    The total cost of the repair is $3660, including $2710 for the labor. It's a 15-hour repair so the labor is $180.67 per hour. The parts are about $300. Is the cost of this repair reasonable? Should I delay the repair until I see oil under the car?
    #1 Regulus, Oct 9, 2025 at 3:12 PM
  2. Leadfoot J. McCoalroller
    8,029
    7,507
    Pennsylvania
    2018 Prius c
    It's a reasonable price for a dealer to fix that. An independent garage can usually do it for about 2/3rds or less.
    Thing is, you probably don't need to fix it at all. It is a fairly common leak point on this model, but nobody ever lost much oil through it. It's just not a big deal for most.
    The oil loss rate is not likely to increase over the remaining useful lifespan of the car. Wait until yours proves itself different with a puddle.
    Regulus and ETC(SS) like this.
  3. ETC(SS)
    7,087
    ^ That.
    The fact that the dealer is trying to get you submit your car to nearly $4,000 worth of open heart surgery to fix a minor oil weep is telling.
    -what it would be telling ME is that the 'change dealer' light just illuminated..........
    Regulus likes this.
  4. rjparker
    9,933
    6,127
    Sounds like the dealer is pulling the engine to change the timing cover gasket.
    I would get a second and third opinion until you found a price less than $1200. If not live with it but check the oil every two fill ups like your wallet and engine depended on it.
    Regulus likes this.
  5. Mendel Leisk
    41,051
    Before doing anything I'd want to see for myself. The "timing cover gasket" is more succinctly termed "timing chain cover gasket", and the gasket is a bead of specific goop, sometimes called form-in-place gasket. It's on the "front" of the engine, which is the end with the pulleys and belts, the passenger side.
    You can get a half decent view from above. Better would be to jack up the right/front corner (or the whole front end with a floor jack), remove the right/front wheel, disconnect and flex back any plastic panel, and have a look.
    FWIW, I recall gen 3 owners getting this done, at dealership, for $1700 USD.
    Also, apart from cosmetics, it's not that serious, especially if it's a minor leak.
    Attached is gen 2 timing chain info, from Repair Manual. Prius c should be similar. It does not appear to require engine removal.
    Regulus likes this.
  6. rjparker
    9,933
    6,127
    The real downside of an oil leak is if you forget to check your oil and cause the "no oil" light to flash. That can take out the engine. Another downside is oil covering everything making other problems harder to find and work on.
    At some point oil gets on the catalytic converter and starts smoking.
    A timing cover oil leak does not simply drip down. Instead it gets thrown everywhere as you drive making pinpointing the exact location difficult unless you clean everything perfectly, run it without driving for a few minutes and then inspect. Even then some angles are tough to see without a good mirror or camera.
    Leak on cleaned timing chain cover after 2 minute initial startup. Oil is flowing from left to right on lower section of cover facing firewall.
    #6 rjparker, Oct 10, 2025 at 1:35 PM
    Regulus likes this.
  7. Regulus
    28
    sylvania,ohio
    Thank you all for the advice. I have checked for oil on my garage floor a couple times since, and still no leak. I'll keep an I on it.
  8. Regulus
    28
    sylvania,ohio
    When I pull the lever to open the hood it makes a spring sound but does not pop up at all. I tried prying it up with a screwdriver, no luck.:unsure: What can I do to open the hood?
  9. Regulus
    28
    sylvania,ohio
    ^^Never mind. I found a youtube video where the gentleman uses a stick to push the spring.
  10. Leadfoot J. McCoalroller
    8,029
    7,507
    Pennsylvania
    2018 Prius c
    A suction cup is easier on the paint.
    Maybe lube te weatherstrip gasket on the front edge so it doesn't stick down next time?
    Regulus likes this.
  11. Mendel Leisk
    41,051
    hopefully not a broken hook release cable, check it's operation before closing the hood.
  12. ETC(SS)
    7,087
  13. Regulus
    28
    sylvania,ohio
    Thanks again everyone. I took it to a garage this morning and the gentleman said it's not a leak, it's just seeping. And recommended that I not worry about it. He said I could drive it across the U.S. if I wanted to. And he said I need to spray some WD-40 to fix the hood problem, or just pound on it a few times and it will pop up.
  14. Mendel Leisk
    41,051
    A leak versus seep? I'd want to see.
    If the hood is not opening, I'd want to know why, don't think WD40 and pounding is a long term solution.
    At least you've figured out a work around for popping the hood, it's not readily apparent, can be awkward or impossible with different models.
  15. ChapmanF
    17,835
    Following a recommendation I saw on here, I went to a Honda dealer for a tube of Shin Etsu grease that I apply now and then to the rubber weatherstrips, does a fine job of keeping them pliable and keeping the hood and hatch from sticking down.
