How to Remove Prius Gen 5 UFO (Vehicle Proximity Notification System - VPNS) Sound
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Prius Gen5 Lover, Aug 12, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,228
    2,236
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 actually has a pretty pleasant door chime. More musical than the typical annoying chirp/beep.
    PrimeDan and VelvetFoot like this.
  2. VelvetFoot
    VelvetFoot Member
    282
    71
    New York State
    2026 Prius
    Has anyone unplugged the harness at the avas controller?
    The might be a chance that an error would be displayed.
    I wonder where it might be?
  3. mingc
    mingc Junior Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    So, Grandma got ran over by the reindeer because it had disabled its notification speaker. Who knew? An Early Merry Christmas to one and all! :D
  4. VelvetFoot
    VelvetFoot Member
    282
    71
    New York State
    2026 Prius
  5. VelvetFoot
    VelvetFoot Member
    282
    71
    New York State
    2026 Prius
  6. Hammersmith
    2,228
    2,236
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That's the computer that controls the speaker, not the speaker itself. Darn near 100% chance that'll you'll get errors if you remove a computer.
  7. VelvetFoot
    VelvetFoot Member
    282
    71
    New York State
    2026 Prius
    I thought if it was easy to get to, try unplugging the connector. I read one possibly relevant post on a Rav4 forum. Its controller is easier to get to though. Just killing time. I'll see if I can live with the racket first.
  8. Hammersmith
    2,228
    2,236
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If it was a part that was only on North American cars, that could maybe work. But all Priuses worldwide have that computer installed. And it's the same part number worldwide(one for HEV and one for PHEV). I've got to believe the main ECUs are expecting to talk to that computer and will start sending error codes if it's unplugged.
    But if you're okay with error codes, why not just unplug the speaker in the grille? It would do the same thing and be a lot easier to get at. And if you follow the instructions at the beginning of the thread, you can rig it to not throw an error. You'll lose the exterior chimes, but you'd lose that anyway if you unplugged the computer that controls the speaker.
    VelvetFoot likes this.
  9. VelvetFoot
    VelvetFoot Member
    282
    71
    New York State
    2026 Prius
    I'm not. I thought I read a post where the guy removed the connector to the controller and it didn't throw a warning. But if you have to take the whole dash apart to get to it, forget about it.
    Almost seems to be a common thread-the DCM module is also hard to get to. There are what, at least 10 or so modules? On my 2000 TDI, it was pretty easy to get to the engine ECM to swap it out with one with modified mapping. I think that was pre-CAN BUS. I'm way behind on this stuff.
    PrimeDan likes this.
