What is this part?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MattFL, Sep 28, 2025.
  1. ChapmanF
    18,503
    Yeah, my 2010 didn't come with an air compressor, not even of any kind, and I had tried the small portable kind before and been frustrated. Hence
    with the capacity to air up tires easily, or operate small tools. (Or larger tools, with breaks to rebuild pressure.)
  2. MattFL
    MattFL Member
    187
    55
    To close the loop, it was indeed the part that fits over the 12V battery. Thanks everyone for the replies!
    bisco and Air_Boss like this.
  3. bisco
    52,351
    perfect!
  4. ChapmanF
    18,503
    I wonder why they changed from the 2010 one-piece thing to this version with the separate carpeted piece over top. Could those little recesses in the top of this part be made to hold some kind of accessory thingies?
  5. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Same for the 2012+ v, which has a structural foam plank atop the battery area, without a PVC supporting structure.
    #25 Air_Boss, Oct 14, 2025
  6. ChapmanF
    18,503
    Funny—what 2010 has is pretty much the carpeted plank with the supporting structure, just as a single part.
    Air_Boss likes this.
  7. MattFL
    MattFL Member
    187
    55
    There is a flat carpeted plastic part that goes on top of this piece, to make the whole rear area flat.
  8. ChapmanF
    18,503
    Right. The puzzling thing is that in 2010 the whole thing was just one piece, the structure was flat and carpeted on top, to make the whole rear area flat.
    Then they changed to two pieces, a flat carpeted piece sitting on top of a separate structure piece, and I was wondering why they made that change.
    I noticed your structure piece has some small recesses in the top, so I wondered if maybe in some markets or some trims there are small accessories to be stored there, covered by the flat carpeted piece.
    Air_Boss and MattFL like this.
