Easiest Way To Keep Track Of MPG?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by VelvetFoot, Sep 29, 2025.
  1. VelvetFoot
    VelvetFoot Member
    272
    71
    New York State
    2026 Prius
    Wondering what the easiest way to keep track of mpg?
    I used to just write calculated mpg and dash mpg on the printed receipt, and keep a stack of them, but around here nowadays, most seem to be out of paper.
    I've seen Fuelly.com . That seems to have promise. Downside could be that all your hard work disappears if they dry up and blow away. Possible to download a local backup?
    Perhaps a spreadsheet? I don't think my laptop came with one. I'd have to hunt around for one.
    I'm thinking maybe take a picture of the pump info, and then a picture of the dash meter, if that's the right word. The meter would have miles and its own calculation for comparison. Then maybe input into Fuelly, spreadsheet, etc.
    Thoughts/experiences?
    edit: The Fuelly FAQ does say you can export a .csv file from the app.
    #1 VelvetFoot, Sep 29, 2025
  2. xliderider
    xliderider Senior Member
    8,139
    3,274
    Honolulu, HI
    Fuely, AKA aCar app user here. It works very well for tracking fuel economy.
    It also can be used for reminders for oil changes (time or distance), documenting maintenance/service, costs of parts, part numbers, etc.
    VelvetFoot likes this.
  3. bisco
    51,623
    i used to write it in a small notebook in the center console. i don't think anything could be simpler
    fuzzy1, VelvetFoot and PrimeDan like this.
  4. xliderider
    8,139
    3,274
    Honolulu, HI
    You still need to calculate the mpg, unless you are just recording the optimistic mpg from the display.
  5. bisco
    51,623
    yes, miles/gallons
  6. VelvetFoot
    VelvetFoot Member
    272
    71
    New York State
    2026 Prius
    I put a little notebook in my pile of waiting-on-the Prius stuff.
  7. BiomedO1
    3,231
    1,713
    SacTown, Ca
    A half-sheet or smaller spiral notebook. Shove a cheap pen in the spiral and tab-off a third of the pages for maintenance. Keep in the center console or glove box.
    I've got one of those in all my cars. Frequently used maintenance part numbers on the front or rear cover, making trips to the store faster and easy.
    My backup is Quickbooks, but I'll need to generate a report for that.
  8. winnertakesteve
    147
    45
    Toronto ON
    2025 Prius Plug-in
    SE
    its basically impossible to track meaningful mpg numbers with the plug in prius, right? as far as i can tell, any hybrid-driving distances just get averaged in with the ev-driving distances, so things like tank averages would take an exorbitant amount of effort to document, right?
    i just set my dash display to be per-drive, and observe my individual trip numbers to get a general sense of how i'm doing relative to other trips.
    BiomedO1 likes this.
  9. fuzzy1
    10,344
    RE: small paper notebook option
    That calculation is very very easy. Easier than learning a new app.
  10. VelvetFoot
    VelvetFoot Member
    272
    71
    New York State
    2026 Prius
    Perhaps just enter it once on Fuelly, as in real time, at the gas station?
    When I had my TDI, I used to write the info on the paper receipt, but a lot of them don't seem to work anymore.
    I'd collect a bunch of those receipts, and then not do anything with them.
  11. Mendel Leisk
    41,058
    Everytime I fill up, at the top of the gas receipt I write:
    [odometer](trip meter)[Toyota's BS mpg meter]
    At home, in a spreadsheet, I copy bottom line down one, overwrite the previous date, liters, odometer and in-dash entries. The spreadsheet substracts the previous odometer reading from the latest, updates the trip cell with the difference, and with the litres value calculates liters/100km (Canadian alternate to mpg). It also updates the error (%) field, and does a conversion to mpg.
    Up at the beginning there's a few fields, summarizing "lifetime average's""
    The Fuelly link works, but for me that's just for fun, not sure it'll always be there, and don't want to count on it. At least for me, Fuelly badge does not seem to be updating properly of late.
    VelvetFoot and otatrant like this.
  12. VelvetFoot
    VelvetFoot Member
    272
    71
    New York State
    2026 Prius
    Up to now, I've always used the trip miles and then zeroed it out at the pump.
    I guess the Prius zeros the trip (or tank) out on refueling.
    As I said though, around here a lot of the pumps are out of paper most of the time.
    Recently move into Apple world, and have no spreadsheet, word processing programs, etc, that I know of.
    Being retired, I haven't found the need. Maybe I should look into it. :)
    Fuelly does let you download your info.
  13. Mendel Leisk
    41,058
    No.
    That has happened to me, occasionally, just go in and tell them what pump I’m at, they print it.
    apples gotta have spread sheet options. How are you finding apple for computing? After presumably being windows? We’re windows pc’s and iPhones, kinda getting groin pull.
  14. VelvetFoot
    VelvetFoot Member
    272
    71
    New York State
    2026 Prius
    I really like them. The interoperability is fantastic. Seamless, mostly. I have MacBook Pro and IPhone now. Resisting watch and don't feel need for iPad.
  15. xw20_driver
    xw20_driver Junior Member
    72
    35
    PNW
    I use a spreadsheet saved to Google Drive Sheets so I enter data from the phone. Someone on the interwebs shared the template ages ago and I adopted it 9 years ago and stopped jotting down mileage on receipts. Each tab tracks the year and calculates the annual average.
  16. xw20_driver
    72
    35
    PNW
    Mendel Leisk and VelvetFoot like this.
