Small oil leak ~ see photo ~ 2015 V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Xriva, Oct 15, 2025.
Tags:
  1. Xriva
    Xriva Junior Member
    NE PA
    2014 Prius v wagon
    Considering buying 2015 Prius V with 160K miles . . . with oil accumulating in area shown in photo.
    Looks wet but not spraying nor dripping.
    any thoughts ~ wondering how this problem might age if not fixed.
    Ty,
    Kevin
  2. PriusCamper
    PriusCamper Senior Member
    12,749
    5,157
    Pacific Northwest, USA
    Not a deal breaker, but getting it all cleaned up and knowing how much is leaking is the next step... The Toyota Stealerships make a fortune off of unsuspecting customers fixing this one even though it usually is such a minor leak it just needs monitoring, not repair.
  3. rjparker
    10,139
    6,300
    It's a common leak point which will get worse slowly coating everything on that side of the engine.
    In a few cases it can be the oil pressure switch leaking through the switch. Replacing is relatively easy from the passenger wheel well but the usual cause is the timing cover sealant to the block.
    Do not try to tighten the pressure switch or the aluminum case may crack.
    This was my leak just behind and slightly up from the oil pressure switch. It required resealing the timing chain cover.
  4. Mendel Leisk
    41,430
    I "think" that's the timing chain tensioner? Gasket leaking.
    (or the oil pressure sensor, per @rjparker)
  5. PriusCamper
    12,749
    5,157
    You can tighten the bolts a quarter turn or so while you're in their cleaning without cracking anything. it might help.
  6. rjparker
    10,139
    6,300
    Do not tighten Pressure switch.
    Since you are in Pa at least you have a good diagnostician available. Watch this video.
  7. Xriva
    Xriva Junior Member
    NE PA
    2014 Prius v wagon
    Wow ~ a Big THANK YOU to everyone who replied
