HeadsUpDisplay that shows ICE on /off for G2 Prius ?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cDxA, Oct 14, 2025 at 3:59 PM.
  1. cDxA
    cDxA New Member
    25
    Is there an aftermarket HUD that is able to show when the car goes from ICE to EV ?
    If not, how hard would it be to hook up a dash mounted LED that comes on when the ICE is on ?
    I can't always hear or feel when the ICE is on, and this would be a non distracting way to know.
    I'm posting a lot recently, so instead of creating another thread, I'd also like to ask what you guys prefer for a MPG gauge, and why.
    The ScanGauge, or something else ?
  2. dolj
    dolj Senior Member
    8,363
    4,264
    Wellington, New Zealand
    Both of those functions are natively on the MFD's Energy Monitor screen.
    cDxA and BiomedO1 like this.
  3. BiomedO1
    3,240
    1,714
    SacTown, Ca
    Yep; simply change your default display options.:rolleyes:
    You can still buy that stuff, if that money is burning a hole in your pockets. A better excuse would be to give the car the ability to do hands-free phone.:):eek:o_O:whistle:
    cDxA likes this.
  4. xw20_driver
    xw20_driver Junior Member
    73
    36
    PNW
    Someone a while back posted about this. I picked up a P10 Pro OBD2 HUD. It connects to the OBD2 port under the dash and has multiple display options and data. I have it set to speed (mph/kmh), rpm, coolant temp, and oil temp. When ICE kicks on it displays the rpm and when in EV mode, rpm reads 0.
    cDxA, bisco and VelvetFoot like this.
  5. Mendel Leisk
    41,064
    Maybe a gen 2 thing? Our gen 3 I find it unmistakable, both due to sound and feel.
    BiomedO1 likes this.
  6. BiomedO1
    3,240
    1,714
    SacTown, Ca
    Is there an engine oil temp sensor on a gen2? I know there's an oil pressure sensor. You sure that other temperature sensor isn't for the EV coolant system? That should be running cooler than the engine coolant sensor.
    Just asking; not that familiar with a gen2.
  7. bisco
    51,624
    i could easily feel/hear it in gen 2 and 3
  8. cDxA
    cDxA New Member
    25
    I'm deaf in one ear and partially so in the other.
    As I get to know the car better, I may be able to feel the difference.
    Regarding the MFD, I can't see it easily, since it is located in the middle of the car instead of in the driver's line of sight.
    The plastic screen is also heavily fogged over.
    Even if it was in the line of sight, it would still be distracting, so I was thinking of adding in a dim ( blue ) LED light that is in my peripheral vision.
    It was suggested that I could easily do this simply by connecting the LED to one of the fuel injector wires.
    As the ICE comes on, the light would go on.
    bisco and Mendel Leisk like this.
  9. xw20_driver
    73
    36
    PNW
    No clue. The instructions call it oil temp but I have no idea what data it is reading from OBD2.
  10. ChapmanF
    17,841
    Possibly the temp of the transmission oil. It would be easier to be sure if the app showed the ECU address from which that PID is retrieved.
  11. VelvetFoot
    VelvetFoot Member
    279
    71
    New York State
    2026 Prius
    Wouldn't that be from a different module than the shown choices?
  12. BiomedO1
    3,240
    1,714
    SacTown, Ca
    There isn't an engine oil temperature sensor on any of these Prius's, is there? I would understand putting them on a turbocharged engine.
  13. BiomedO1
    3,240
    1,714
    SacTown, Ca
    It doesn't matter, it's just watching the network traffic and plucking out certain data identifiers. Each OEM is suppose to follow/use agreed tags for basic ICE sensors.
  14. BiomedO1
    3,240
    1,714
    SacTown, Ca
    IMHO; FIND SOMEPLACE ELSE to hook-up; the fuel injector is too sensitive a component to run a tap off of. Put in the time and effort to fix your foggy screen. That blue lamp is going to be really distracting driving at night; if you can get it bright enough for daytime operations.
  15. VelvetFoot
    VelvetFoot Member
    279
    71
    New York State
    2026 Prius
    ICE is not transmission.
  16. BiomedO1
    3,240
    1,714
    SacTown, Ca
    You totally missed the point of this thread and want to argue semantics, which leads me to believe that you don't know how a common system data bus works.o_O:whistle:
    You do you.........
  17. ChapmanF
    17,841
    It would be hard to know what queries the device is actually making, unless its documentation contains those details, or somebody has a CAN sniffer to use.
    Anyway, as the ICE does not have an oil temperature sensor, there's kind of an open question where the device's reading for "oil temperature" is coming from. I wondered maybe the transmission oil, given that there is a sensor for that. Further affiant saith not.
  18. xw20_driver
    73
    36
    PNW
    I went with the cheap obd2 P10 display. It's small, simple to install and remove, displays not only RPM but ICE coolant temp and other interesting data, and was relatively cheap (paid $11). I mainly wanted it for coolant temperature data and to see when ICE was running to help with gliding. Before, I was using Hybrid Assistant android app with a bluetooth OBD2 dongle. HA captures more detailed data and report. Either way, I feel like the obd2 data bus already has the signal you need.
    You can install an analog RPM gauge for your Prius. link
