Question about oil change timing and Oil maintenance light
Discussion in 'Gen 3 Prius Main Forum' started by taxce, Oct 16, 2025 at 1:42 AM.
  1. BiomedO1
    3,251
    1,717
    SacTown, Ca
    :cool:;):p But it's true!! You really start smelling; even when you don't notice it.:Do_O:ROFLMAO::whistle::LOL::giggle:
  2. Templeton
    Templeton Member
    245
    70
    usa
    2024 Prius Prime
    SE
    Yes, I think so (about the 100 gallons)
    We get gas so rarely, recording it and keeping track of cumulative gasoline purchased is super easy. And when we drive in HV mode, we are on highways, so the ICE is running near nonstop. So I think that an oil change every 5k HV miles (so approx every 100 gallons of gas) seems like a great way to baby the engine, but yet also not toss out lots of perfectly good synthetic motor oil.
    BiomedO1 likes this.
  3. Mendel Leisk
    41,069
    We’re doing about 3k kms per year now, on our 2010.
    I change oil/filter every spring.
    Did both coolant circuits yesterday, second time now, by the 5 year interval.
    And a week back, in conjunction with snow tires, did the brake fluid. Second time I’ve done it, and dealership did once as well, in conjunction with a recall.
    about 65k miles on it, lol.
  4. ASRDogman
    ASRDogman Senior Member
    7,470
    3,877
    What does Toyota say about when to change it on the Prime? Isn't the prime the one you can go
    40 miles before the engine kicks in?
    I could see where it would be difficult to determine the Miles traveled with the motor running.
    So depending on home much you drive it in 1 year, you might only change the oil/filter once a year....
  5. BiomedO1
    3,251
    1,717
    SacTown, Ca
    Toyota doesn't make a distinction. I fill-up once a month (approx. 8 gallons) so that's 96 gal/year x 50 miles/gallon = 4800 miles actual on the ICE. I don't have any standing idle time, because the winters out here isn't that cold and no snow sticks around. So I'm comfortable doing 12-15 month oil changes or every other maintenance flag (10K mile).
    FWIW; I got a gen4, so just a 25 mile battery range.
