2006 Prius Oem Filter?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nate00, Oct 16, 2025.
  1. Nate00
    Nate00 Junior Member
    2002 Prius
    Hello everyone I just got the 2nd oil change with valvoline restore and protect on our gen 2 and its helped reduce consumption. Only 1 quart in about 5k miles with 190K miles so its a lot better than 2.5 quarts burnt like before, also lots of hwy miles now.
    Current filter installed is a 90915-YZZD1 is that fine to use on it? The toyota website is telling me 90915-YZZN1 please let me know!
  2. Tombukt2
    12,902
    2,317
    I'm sure the numbers change several times over whatever so Toyoda tells ya probably correct. 8 run a 3600 on all my Gen 2 whoops
  3. Nate00
    2002 Prius
    Its a bigger filter and the dealer told me its not the right fit….
  4. dolj
    dolj Senior Member
    8,430
    4,285
    Wellington, New Zealand
    How did you arrive at fitting the 90915-YZZD1?
  5. Nate00
    2002 Prius
    Picked off the shelf and incorrect toyota website saying it could fit
  6. BiomedO1
    3,500
    1,818
    SacTown, Ca
    The D1 filter has about twice the capacity of the N1 filter. I believe the D1 is used on the 2.7L and V6 Toyota engines. The diameter of the D1 filter is also larger. The sealing o-ring of the D1 is the same as the outside diameter of the N1 oil filter - not sure if it's going to seal if your car calls for a N1 oil filter.
    There's also the question of at what pressure does the oil filter bypass valve open, if the filter gets plugged. Do they all pop open at the same oil pressure? Is the small displacement engine oil pump capable of generating enough oil pressure to open the bypass valve? While having a larger capacity oil filter is nicer to have, those basic questions above needs to be addressed.
    #6 BiomedO1, Oct 18, 2025
  7. Tombukt2
    12,902
    2,317
    Good been running em for years now in all the toys here screws rt on . No it's not made for . Oh shucks
  8. Nate00
    2002 Prius
    So you’ve used these on your gen 2 prius? No issue?? I have the N1 now so maybe just replace for peace of mind…
  9. Tombukt2
    12,902
    2,317
    It's all I have in the shop fits all my toyoda's so I use it it's on all that are here now 06 07 08 Prius sienna van 02 Corolla 1z.
  10. Tombukt2
    12,902
    2,317
    Makes oil changes very easy
    priumium likes this.
  11. BiomedO1
    3,500
    1,818
    SacTown, Ca
    It's nice to know that they fit, but I wouldn't do that if the car is still under a power-train warranty. That's fair grounds to void that warranty; installing wrong parts on the engine.
    Just my two cents.......
  12. Tombukt2
    12,902
    2,317
    Yeah well that may be I hope to never have to have a vehicle in warranty personally that's for others if ya will
  13. bisco
    51,843
    love a new car every few years (y)
  14. Tombukt2
    12,902
    2,317
    Nope I do not the older the better the tried and true haulers. That's why I haven't plunged aanything into electrics . They got a good ways to go before I even really start looking at them
  15. Nate00
    2002 Prius
    So overall the consensus is that if I run this D1 filter for 5k would I be fine? Or should I just swap it out for the N1 filter? Thanks!
    PS- Valvoline Restore and Protect VRP has reduced consumption on ours to about 1 quart in 5k versus 2.5 quarts the past 2-3 oil changes.
    xw20_driver likes this.
  16. pasadena_commut
    pasadena_commut Senior Member
    2,586
    767
    Southern California
    If the filter fits it should be fine. There is a video on YouTube somewhere where they tested a bunch of filters and it includes the Toyota OEM one. Found it:
    See also
    Is the Prius oil filter as bad as this one? | PriusChat
    In the thread I hypothesized that the Toyota filter is optimized for flow rate and capacity, so it doesn't clean as fast, but should get there eventually. In the test video they don't say how many times they run the fluid through on the filtering test, but show a small fixed number (apparently 5). For the capacity test they keep adding dust until the pressure differential goes up by 8 psi. Filter test at 5:40, capacity test at 6:40. The capacity of the Toyota OEM filter is much larger than the others. The only way to make sense of that is that it filters slowly. So it does poorly in the initial filter test (limited number of passes) and well in the capacity test (very large number of passes).
    Either that or it continues to filter poorly and their capacity measurement is garbage. That would happen if particles continue to pass through unfiltered forever and the "huge capacity" has miscounted dust still in the oil as having been absorbed in the filter.
  17. BiomedO1
    3,500
    1,818
    SacTown, Ca
    If your using Valvoline R&P, stick with the D1 filter for now. You'll need the larger filter area because of the stuff it knocks loose. It'll test the built-in bypass valve, if it gets clogged so proceed with caution and watch that engine oil lamp.
    Good Luck.....
