Help troubleshooting unknown sound needed
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by dbogs, Oct 17, 2025.
  1. dbogs
    dbogs New Member
    CT
    2022 Prius
    Hi Everyone-
    I just upgraded from an ’07 Prius to a 2022 XLE (Gen 4), and when I put the car in reverse I hear a subtle but odd sound I never heard in my older model. It’s a continuous low-level, almost like a throaty hum electrical buzz echoing inside a tube. It’s not loud or intrusive — just noticeable (my 07 doesn’t do that )
    I hear it coming from front way under center of dash, or back of engine compartment when car is put in reverse and continues while backing up. Also hear it a little of it, like 50% loudness, at times going forward very slow, 18mph or less. Anyone else experience this in their Gen 4 Prius? Is it normal — inverter, brake actuator, or something else? My wife thinks it the sound of the electric motor that’s moving the car - maybe- but even if so-- should I be hearing that??
    I just got this car- and I have 7 days to return it. So your input is really needed and greatly appreciated for sure!
  2. Tideland Prius
    16,668
    Is it the Vehicle Pedestrian Notification System?
    Tande and BiomedO1 like this.
  3. dbogs
    dbogs New Member
    CT
    2022 Prius
    OMG- that's it! I feel like an idiot. It's just such an unusual sound and my 07 just beeped . After your response I looked on youtube for posts of the sound and there it was - one person called it "the ridiculous noise". It is an odd sound. I never suspected it would be a warning sound. Thank you!!
    Tideland Prius likes this.
  4. rjparker
    10,987
    6,888
    Exactly. The noise maker to warn people you are moving in ev mode. Recent hybrids are louder than gen2 or 3 which often required you to be in a drive through next to a wall to hear it.
  5. BiomedO1
    4,506
    2,361
    Left Coast
    Yep; Pedestrian Notification System and internal reverse beeper. Someone who didn't know what they were doing, most likely stuffed or siliconed those speakers/noise generators shut. You can't remove them because that'll trigger the CEL
    When you throw the car into reverse, there should be either a single beep or a consistent warble while in reverse. If it doesn't do that, someone has been messing with it. The OEM settings allows you to reduce the warble to a single beep. Again, somebody, not an authorized OEM tech has been messing with it.
    Ditto with the Pedestrian warning system - speaker in near the car horn. Activates in forward motion below 25-30 mph
    Hope this helps.....
  6. dbogs
    dbogs New Member
    CT
    2022 Prius
    Thanks guys- you have allayed my fears!
