New Rotors with Brake Job?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Philtration, Oct 7, 2025.
  1. BiomedO1
    3,505
    1,822
    SacTown, Ca
    Rebuilt or new calipers are $100+ per unit. They should flush out the braking system with new DOT3 brake fluid while they're at it and manually adjust the rear shoes. The difference in braking performance is astounding, when all brake fluid is replaced, because you really don't notice the very slow denigration of braking power over the years. It makes a noticeable difference in larger, heavier cars.
  2. Mendel Leisk
    41,334
    I'd leave them be. I've never needed to replace a brake caliper, did have one rotor failure, other'n that never touched them either. Maybe more road salt in your area though.
    Do a brake fluid replacement sometime, if you haven't. Toyota USA says nothing about brake fluid replacement; Toyota Canada says tri-yearly or 48k kms (30k miles), whichever comes first.
    I believe for gen 2 Techstream is a must-have for brake fluid replacement? Dealership would be safest.
    priumium likes this.
  3. priumium
    priumium Member
    104
    26
    Sweden
    Make sure those pads and the glide pins are moving smoothly. Calipers should hold if well greased with silicone and rotors you can possibly ignore, unless warped (very uncommon) or have a very hard crust at the top.
    Got a great tip from a Swedish rust lord to coat any rust prone parts of the rotor with a thin layer of ceramic grease. Looks better aswell. This trick has prevented new rust on those surfaces that the pads do not touch for years for me!
    Note, it’s not officially condoned…
    I personally prefer TWR painted rotors (Toyota OEs are also painted) since they don’t rust as easily in any northern hemisphere scenario - if you wish to replace them.
    #23 priumium, Oct 19, 2025
  4. pasadena_commut
    pasadena_commut Senior Member
    2,588
    767
    Southern California
    Sure, change the fluid, mostly to avoid corrosion, but it won't make any difference in normal braking.
    Recently changed the brake fluid on our 2007 and our 1998 Accord and the brakes feel the same in both. New and old fluid, and water too, are basically incompressible, and that is 99.9% of what brake fluid does. The only way that it should matter is if the old fluid is heavily contaminated with water and then it would boil at a lower temperature than new DOT3 in very heavy usage.
    priumium and Tombukt2 like this.
  5. priumium
    priumium Member
    104
    26
    Sweden
    ^^ So true, just check for water in fluid with a basic tool and only drain when this is above 2-3%.
  6. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    Replace the brake fluid with DOT 3 high temp. DOT 4 won't last long like DOT 3 and Prius is not high performance car so DOT 3 is fine. Also use Genuine OEM brake pads (~$70 ones, not their cheap ones) with coated rotors to avoid the noise/rust issues. Check the brake lines (rubber) on all wheels. If rotted or cracked, replace them. Good luck.
  7. Mendel Leisk
    41,334
    Recent purchase, Toyota DOT3 fluid was $8.09 CDN through our nearby dealership. DOT3 is the spec'd fluid. Is there such a thing has high temp DOT3?
  8. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    this one -> Prestone DOT 3 Brake Fluid 32oz . I used this on the Prius and the Odyssey. They claim it is high temperature. I tried DOT 4 on the odyssey and seems it absorbs moisture faster than DOT 3. This is ~12 for 32 oz at autozone. Enough for complete flush in most cars.
  9. pasadena_commut
    2,588
    767
    Southern California
    I'm struggling to come up with a scenario where the higher boiling point in the brake fluid would matter in a Prius. Most of the braking is from regen and it is only purely mechanical at very low speeds. The only cases I could come up with would be when going down a very long steep grade having a pack failure or a transaxle failure equivalent to getting stuck in neutral, both of which would disable regen braking.
  10. Mendel Leisk
    41,334
    Even Toyota says you can use any DOT3, but I’m just bright enough to go with Toyota branded, a lead pipe cinch to be compatible. :)
  11. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    The price difference was negligible compared to regular DOT 3.So i opted for it
  12. Philtration
    Philtration New Member
    Walla Walla
    Thanks everyone for all of your comments!
