Battery after changing brakes pads take more time to load...
Discussion in 'Gen 3 Prius Main Forum' started by Dawiddd, Oct 19, 2025.
  1. Dawiddd
    Dawiddd New Member
    Polans
    Hello friends,
    I got a 2013 toyota prius 3gen, 5 day ago my mechanicien change my brakes pads all of them, since i feel like my batery need more time to charge... It's charging but it's taking a lot longer than before! Like i ride this car for a long time, and i realy feel that "gap" between before and now, and my ratio switch from 4,8L/100KM to 5,5L/100km. i ride everyday doing 50km-300km. do you have some advice? something to look? Is it normal? i put 2 screen, one with the higher temp is 2 month ago, and the other one is 2 day ago can you read something?
  2. Tombukt2
    12,924
    2,322
    What's the total mileage on that battery the original . ? Maybe is to e for new . Green lines in pictures .
    Dawiddd likes this.
  3. Dawiddd
    Dawiddd New Member
    Polans
    it's 147.000 km i thought baterry is in good shape, it load to the maximum
  4. bisco
    51,882
    check all the wheels, make sure the brakes aren't dragging. are you comfortable with the mechanics prius knowledge?
    Dawiddd likes this.
  5. Tombukt2
    12,924
    2,322
    Blocks 2 And 10 look low.
  6. Dawiddd
    Dawiddd New Member
    Polans
    To be honest i am a noob, i knew to look for a car with the smallest voltage diff most of the time it's a sign of a good shape, my EGR is clean, i bought this car 3 month ago and i can do literaly 2km on the batery alone, so i think the battery is in good shape but like i said i am a newbie. Can you explain me what do you mean by " make sure the brakes aren't dragging"? i would be thankfull for any advice
  7. bisco
    51,882
    the wheels should spin freely when you jack the car up off the ground. if it feels like they are binding, a brake caliper may need work.
    you can also try putting it in neutral at about 20mph to see if the car glides freely.
    another way to test is take a drive for a few miles, and feel all the wheels. if a brake is dragging, that wheel will be warmer than the others.
    Dawiddd likes this.
  8. Dawiddd
    Dawiddd New Member
    Polans
    Thanks you for all suggestion, i finally got the answer it was.... my 12v battery, i think my car was loading the (big)battery slowly than before because maybe the battery was always trying to recharge the 12v battery. Like i just change the 12v battery and my main battery is loading faster just like 2 week ago, so my feeling was right that something is not ok, this car won't stop to amaze me. Thanks you for all message guys this group is amazing
