Brakes Pulsating and Hesitating on 2005
Discussion in 'Gen 2 Prius Technical Discussion' started by dcwenger, May 16, 2025.
  1. dcwenger
    dcwenger Junior Member
    63
    Canyon Lake, CA
    Hello All,
    I have a 2005 with a little over 300,000 miles that has recently begun pulsating when braking and sometimes does not stop properly. When slowing down, sometimes it doesn't slow down like it should unless I press firmly on the brakes. This is my 5th Prius and I know how they're supposed to drive, so I know something is wrong. I took it to the dealer a couple days ago and was told the reason for my issue is that the lower control arms were bad and one engine mount was worn and that that is causing the hesitation in the brakes. I went ahead and had the work done and then drove it home, but it is still having the same issue. I thought sure it was the actuator or something related to the braking system. I took it back to the dealer today. They adjusted the rear brakes and suggested I look at the rotors and calipers if I have any problems, but said the issue was fixed. It is not fixed. It is still doing the same thing and I can absolutely guarantee this is NOT a hardware issue. There are also no warning lights and I am not getting any codes other than a P0420, which I will deal with later. Dealer said it is not the actuator.
    Someone on the below Reddit thread () described something similar and said his local mechainc said it was the "swoop sensor" and after the shop replaced it, it was fixed. I have no idea what that is and have never heard of it, but I think he meant "speed sensor". That would make sense because that is what it feels like, but again, there are no lights or codes. I did a Google search to see if the speed sensor could be bad without lights and it said "that it is possible. I am stumped now because the dealer has no idea and doesn't notice, but I have driven these cars (including this one) enough to know how it is supposed to brake and now I cannot drive it because it is not safe. I had to really keep my distace on the SoCal freeway on the way home from the dealer today and had a couple close calls. Please help if you can. Thanks.
    #1 dcwenger, May 16, 2025
  2. Tombukt2
    13,198
    2,386
    So with four or five cars under your belt yes you should know how they drive and you had no beep no tones no lights and the lights do work when you boot the car? I wonder if anybody has attempted to simply bleed the brakes have you ever seen the reservoir down or low I have a couple of mine I have four too and have replaced several actuators right here I have also bled the brakes on a couple that have come here and that fixed it hardware I've replaced every piece on a few cars and almost nothing on a few at 500,000 almost no noticeable difference in vehicles other than some vibration from the 500,000 and the cars with the new parts and I mean struts control arms lower ball joints brakes and links etc and you still have some noise just from near 500,000 mi I guess but nothing like you're describing here with your braking it almost sounds like there's air in the system maybe even the brake fluid won't match the pH that it needs to be at generally.
    BiomedO1 likes this.
  3. dcwenger
    63
    Canyon Lake, CA
    Update:
    In May of this year, I took it to a major hybrid repair shop in SoCal who also told me the same thing as the dealer. Eventually I was able to convince them that the actuator was the issue and they changed it with a used one with a one-year warranty. It worked fine for about 3 months, but the symptoms came back. The shop insists there is nothing wrong with it and that it's just me. That is BS, as I own several and have been driving them for years and know what it's supposed to feel like when braking. I don't think the shop wanted to do the warranty It work. It also has new brakes and drums. The Gen 2 loaner car felt fine to me and there was a noticeable difference. My car doesn't feel safe to me. Has anyone else experienced this and/or has any suggestions? I understand that there isn't always a code when these symptoms appear. TIA.
  4. BiomedO1
    3,937
    2,069
    SacTown, Ca
    It sounds like air in your braking system and it was replace by a 'used' part with unknown miles and how long was it stored and under what conditions. Do you do a brake fluid flush every 3-5 years? If you don't, there's usually a lot of sediment at the bottom of your reservoir. That stuff gets sucked into your braking system and can reap all kinds of havoc in your electronic ABS system. The old manual systems are less temperamental and sludge doesn't seem to bother them that much. I flush out those old systems in trucks and SUVs the braking improves immensity; but those are much larger and heavier vehicles.
    I'd have someplace do a full brake fluid systems flush and see what happens.
    FWIW; brake pulsation is usually warped rotors.
    #4 BiomedO1, Oct 19, 2025
  5. Tombukt2
    13,198
    2,386
    Man let me tell you I put break actuators from cars that look like mad Max mobiles in my cars . Especially if it has the magic part number with the right suffix or prefix or whatever it is and usually getting for near free. I can do this job in about 2 hours flat I can also get air out without fancy tools if needed. Sounds like you may in fact have an air problem . I would personally bleed the back brakes first. See if ya get big shots of air do it until fluid streams out under pressure . Drive it . Still feels funny . Take out the blue ABS relays and bleed fronts manually like 30 yrs ago. Ride again ?
  6. dcwenger
    63
    Canyon Lake, CA
    I agreed to a used one with the warranty. When I took it back last week, they said the entire system had been bled. The also tightened the e-brake (way too tight).
    I have been told by other mechs that the pulsating is the ABS system. I can have the rotors turned, but if it worked for 3 months, the issue wouldn't return if the rotors were bad all along. I just want it fixed and am frustrated by all these so-called "experts" not being able to fix the issue.
  7. dcwenger
    63
    Canyon Lake, CA
    Just to clarify, AFTER I returned and they kept it for a few days, they said they checked it out and bled the system before I picked it up.
  8. Tombukt2
    13,198
    2,386
    And now still problem . And no dash lights of orange color?
  9. dcwenger
    63
    Canyon Lake, CA
    Yes, it's still a problem. CE light is on, but only for P0420. Nothing related to brakes. I've read and heard that is can be an issue even if there are no codes.
  10. BiomedO1
    3,937
    2,069
    SacTown, Ca
    Are you sure they put in the correct ABS unit? The car care nut found the wrong unit installed in a Lexus; they also had intermittent braking issues after a dealership replace it with the wrong series unit - it fits, but sometimes that isn't enough. Use your VIN to pull up the correct ABS unit and compare to what you have currently installed. I hope you kept the old one.
    Unless you have a OBD2 unit that's capable of reading ABS codes, off that specific ECU, you won't find them. OEM's don't like shade-tree mechanics messing with their braking systems. Gun shy from the law suit a few decades back.
  11. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    The only problem with that is, any notation that might be stamped or labeled on the outside of the part might be an engineering number and not a part number. They use the same nnnnn-nnnnnn format, which trips up a lot of people. So accurately identifying part numbers is not the easiest endeavor.
  12. dcwenger
    63
    Canyon Lake, CA
    No, I am not
    No, I am not sure they replaced it with the correct unit and no, I did not get the original one back. The turnaround time for it was really fast as well, so I'm skeptical that it was even replaced. After it was supposedly replaced a few months ago, I had to take it back right away, as it was still not working properly and I was getting a code. Like I said above, it worked fine for about 3 months, but then the symptoms returned. This is one of of the largest (if not THE largest) hybrid repair shops in SoCal. I won't mention the name, but for anyone nearby that wants to guess, it is very close to one of the major airports. Needless to say, I am disappointed and won't return for service on my Prii.
    Unfortunately, I don't have a code reader that is sophisticated enough to get the data from the ECU.
    #12 dcwenger, Oct 21, 2025
  13. BiomedO1
    3,937
    2,069
    SacTown, Ca
    Well, if the braking system fluid wasn't all flushed out and you have got high moisture content in that brake fluid - the time line would seem to fit and you've got air/steam in your brake fluid lines. Ask anyone who has done any track racing. As the brake fluid heats up, the water within begins to boil, (the brake fluid won't), the steam creates air pocket that compresses a lot easier than liquid and the brakes gets mushy.
    How does the brake fluid look??? I do my own maintenance, so I use that as a gauge to how thin my pads are. If it's really low, my pads are close to needing replacement or I've sprung a leak. I can usually tell if I have a leak without looking at the fluid reservoir, but these new ABS systems makes that a lot more difficult, simply from feel.
    #13 BiomedO1, Oct 21, 2025
  14. PriusTech
    PriusTech Active Member
    253
    112
    Reno
    I'm guessing you already answered your question
    CAR-PART can locate used parts nationwide. They sometimes list mileage and they usually have pics with the VIN # and you can look up the mileage with STAT.VIN. If you can't afford new find a low mileage used.
  15. dcwenger
    63
    Canyon Lake, CA
    Thanks. I'll look into it. I do a lot of my own maintenance, but I wasn't sure I could do this one without a lot of frustration (and throwing tools), so I opted to have it done by a shop instead. Not sure if I want to attempt this one.
  16. PriusTech
    253
    112
    Reno
    Some shops will let you bring your own parts. Or you can give them the source and they will mark it up. Low mileage is key when buying used
  17. pasadena_commut
    pasadena_commut Senior Member
    2,747
    820
    Southern California
    Maybe try another mechanic? Canyon Lake and vicinity may not have the biggest selection. Riverside and San Bernardino will have more, and they aren't that far away.
  18. BiomedO1
    3,937
    2,069
    SacTown, Ca
    The problem with bringing your own parts - the shop will ONLY warranty the labor. He would still be stuck in the same situation. The part worked for 3 months, so it would be difficult, if not impossible to blame incorrect install as the root cause of his current problems. That's the gamble with used parts, especially a part that is weak and has a known high failure rate.
    Honda automatic transmissions had a similar issue in late 90's early 2000s. A friend of mine went through 3 in three years, but got well over 100K miles out of the original. I told him about the know issues and warned him that he was throwing good money after bad. He was too cheap and prideful. Gave him $500 for the car on the 3 blown used tranny. I rebuilt it correctly using the OEM modification/rebuild kit; which cost the same price of a junk yard tranny. My niece is still driving it around with over 300K miles on it. Nothing but basic maintenance, after the transmission rebuild. The only major thing was the required timing belt replacement. Did H2O pump and idlers too.
    Sometimes it's less aggravating and time consuming to spend a little extra to get it done right......
    Just my 2 cents....
    #18 BiomedO1, Nov 2, 2025
