Hitting noise coming from back seat area, when start the car. 23 prius
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Aug 23, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    1,131
    447
    New York State
    2026 Prius
    I wonder if you may have the rear seats folded down, any mods to the below deck foam, not using the luggage screen, etc.
    Anything that might enhance sound transmission.
  2. TGTGUUD
    TGTGUUD Member
    96
    72
    San Francisco
    2024 Prius
    My 24 LE does exactly the same thing since day one. Now it has 27K miles. I assumed it was normal...Let me know if it turns out to be something bad. Thanks.
  3. BiomedO1
    4,019
    2,109
    SacTown, Ca
    That's part of the emission control system and Federally mandated warranty for 8 years or 100K miles; longer if your car is registered in a CARB state.
    I'd look at that TSB to see if they messed with that unit on the recall. Make sure this is properly and specifically documented; so if that part fails just outside warranty; you may be able to get it repaired for free.
    Good Luck......
  4. priusasa
    priusasa Member
    100
    51
    2023 Prius
    So it was normal.
    I went to the place in the morning. Few hours later I went to check, they said they didn't find where the sound is coming from... Even though I told him exactly where it was coming. I showed him the part's picture.. Anyway, car had to stay 1 more day and they gave me some new generation prius for just 1 day. Which is very good service. Then I realized the Same sound is coming from 5k mileage prius... Slightly less. So I think it's normal.
  5. bisco
    52,286
    wow, that pounding sound is horrible. can't believe they all do that
    PrimeDan likes this.
  6. TGTGUUD
    TGTGUUD Member
    96
    72
    San Francisco
    2024 Prius
    Thanks! Good to know. I think I saw the Car Care Nut saying the knocking noise is normal with newer hybrids, but can’t remember which video.
