No Heat
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 20, 2025.
  1. qmanqman
    qmanqman Active Member
    433
    150
    CO
    It was in the low 50s this morning so I turned on the "Auto" function and set the temp to 70 which usually warms the interior up. Only cool air blew from the vents.
    We recently replaced the "coolant flow control valve" and had to add some coolant at the time but I never follow up checked it so I'll do that this evening. Any other thing to look at when diagnosing a problem with no heat?
  2. ChapmanF
    18,349
    A coolant control valve can get stuck in a position that cuts off coolant flow through the heater core, so that can be a cause.
    The air mix door can get stuck in a position that cuts off air flow through the heater core, so that can be a cause.
    For people of typical flexibility, it isn't too hard to peek under the dash and see if the air mix door moves.
    qmanqman and BiomedO1 like this.
  3. qmanqman
    433
    150
    CO
    Thanks pal. This is my daughter's car and I've been driving it for the past few weeks. She just informed me that it's been doing this for years so I'm gonna guess it's probably not the flow control valve since it's been replaced twice in the last two years and once about 3 months ago. Gonna check the blend door.
    #3 qmanqman, Oct 20, 2025
  4. BiomedO1
    3,891
    2,038
    SacTown, Ca
    also check the heater core lines going through the fire wall. Both should be warm, if coolant is circulating throughout the heater core. If both hoses are warm, I'd look at the blend doors.
    If one or both lines are cool to the touch; you have no coolant flow. At this point, you'll need to troubleshoot why coolant isn't flowing. Coolant bleed issue, control valve issue, clogged heater core, coolant pump issue.
    Good Luck....
    qmanqman likes this.
  5. qmanqman
    433
    150
    CO
    Haven't been able to look at anything yet. Google AI tells me that another item to look at is a faulty thermostat. I don't always believe Google AI so I thought I'd ask y'all.
  6. BiomedO1
    3,891
    2,038
    SacTown, Ca
    The engine coolant thermostat controls coolant flow into the radiator - up front. Your heater core is behind that loop, so you get heat even when that thermostat is closed.
    FWIW; the car would be overheating too if that thermostat is stuck closed - especially over the summer months. If your talking about the heater core, that's the coolant control valve that you already replaced. You still need to check it. That plastic valve can be easily jammed up by internal coolant debris. There isn't a filter on your cooling system...
    #6 BiomedO1, Oct 21, 2025
  7. ChapmanF
    18,349
    In cold weather, a faulty thermostat that fails to close can impair your cabin heat performance, by making the engine take a long time to reach, or never reach, normal operating temperature.
    But if you have a scan tool and you can watch the coolant temperature and it's coming up to 85 or 90 ℃ in a reasonable time, then that's not the issue.
  8. BiomedO1
    3,891
    2,038
    SacTown, Ca
    Wouldn't that throw something like a P0128 or temperature sensor issue?
  9. ChapmanF
    18,349
    P0125 and P0128 are both codes that can be set if the ECM doesn't think the engine reached normal operating temperature soon enough, on two drives in a row. So yes, a thermostat sticking open might well be something you'd catch by seeing one or both of those codes.
  10. qmanqman
    433
    150
    CO
    Thanks guys. How do you check the coolant control valve for being stuck?
    F°WIW as I drove today it was 50° F outside temp. I set the Auto function with 72° interior temp (which turns on the A/C and sets the flow to the feet.) . I turned off A/C and got nothing but cool air. Then I cranked up the temp to "High" and set the flow to be in the dash (which turns off the Auto function.) Immediate warm air for about 3 seconds and then cool again for a minute or so. It would repeat this pattern all the while I drove. Warm air for a few seconds and then cool air for a minute or more . . . over and over. It's trying to give me heat but something is not allowing it.
  11. Brian1954
    Brian1954 Senior Member
    2,314
    925
    South Central PA, USA
    The first thing you should do is check the coolant level in the radiator. Remove the cap on top of the radiator. The coolant level should be all the way up to the top. If coolant is not at the top, add coolant to fill it up.
    There have been many instances reported on this Gen 2 forum about no heat. Many times, the coolant level is low in the radiator.
    VelvetFoot and BiomedO1 like this.
  12. BiomedO1
    3,891
    2,038
    SacTown, Ca
    That sounds like a blend door issue, where the controls keep trying to switch to what you want. But you need to test and rule out the other issues before ripping apart your dash. You can save a lot of money by pulling one out of a junker; but that plastic is going to be old and brittle too - so you may end up doing the job two or three times.:( What we do to save a few bucks....o_O
    #12 BiomedO1, Oct 21, 2025
  13. qmanqman
    433
    150
    CO
    Yup, that was supposed to be item #1 yesterday but I failed. Just looked and I can't see coolant.
    #13 qmanqman, Oct 21, 2025
    Brian1954 likes this.
  14. BiomedO1
    3,891
    2,038
    SacTown, Ca
    Yep, didn't mention that because I'm assuming that had already been checked. But we all know what's being said when we make assumptions.o_O:(:rolleyes::whistle:
    If any of us could see the car, I'm sure one of us would've pointed that out.o_O:D:rolleyes::ROFLMAO::LOL::whistle::sleep:
    #14 BiomedO1, Oct 21, 2025
  15. Brian1954
    2,314
    925
    I am 95% sure that you will have heat after adding coolant to the top of the radiator.
  16. qmanqman
    433
    150
    CO
    Ya me too. I'm probably more like 99.7% sure LOLLL
  17. BiomedO1
    3,891
    2,038
    SacTown, Ca
    You'll need to monitor the coolant level for the next week or so - show your daughter how to do that.
    Once the coolant level is to the top of the radiator, you can just use the ENGINE coolant bottle markings to keep track of coolant levels. Whenever you empty the engine coolant bottle, you always have to check the level at the radiator because you've broken the coolant transfer with an air pocket. People who simply refill an empty coolant bottle will think they're OK on coolant, when they are NOT. The only exception is the flow through coolant bottles. Those will have a 1.5+ inch heater hose attached to them.
    DO NOT REMOVE RADIATOR CAP WHEN ENGINE IS WARM OR HOT......
    That's also a great way to pop the head gasket without warning lights, since the coolant isn't touching the coolant sensor. Hopefully there wasn't any damage.
    @Brian1954 Great Call
    #17 BiomedO1, Oct 21, 2025
  18. pasadena_commut
    pasadena_commut Senior Member
    2,725
    813
    Southern California
    Put a mark with a Sharpie half way up the overflow tank in a location that is easy to see from the passenger side while looking over the fender. With the car parked on flat ground fill the radiator and the overflow tank to the mark. Drive the car for the day, park it in that flat spot, and check the level in the overflow tank the next morning. If there is air in the system it will go down a bit. Top off only in the overflow tank (unless completely empty, then in the radiator too). Do this a couple of times and any air will work itself out.
    If the coolant keeps falling for more than a couple of days, or falls more one day than the previous, then there is a leak somewhere.
    Pray it isn't the blend door. PITA to get to that on this car.
  19. qmanqman
    433
    150
    CO
    That was it. About 1.5-2 qts low and now there's tons of heat. Thanks guys and sorry to have bothered y'all before checking step 1 first.
    Brian1954, BiomedO1 and VelvetFoot like this.
  20. BiomedO1
    3,891
    2,038
    SacTown, Ca
    Keep and eye on it for the next few weeks; the system will be pushing out air bubbles - so you may have to add more a couple of times before it stabilizes.
