Front end hood dent—sensors not working
Discussion in 'Gen 4 Prius Main Forum' started by Bohemiana, Oct 15, 2025.
  1. Bohemiana
    Bohemiana New Member
    Arizona
    Ug! I barely hit the car in front of me and bent my front hood right at the sensor area. No damage to the other vehicle because it was their trailer hitch. Now my cruise control and some other warnings aren’t working. I don’t care about what it looks like as far as touch up paint etc. Is this a dealership-only repair to the sensors?? A body shop quoted $3k for the physical repair but I don’t think they know how to fix the sensors. Plus, it’s an old scratched up car but I want cruise control, etc
  2. Tideland Prius
    16,597
    Yeah looks like the radar sensor behind the emblem is out of alignment. The body shop will need to straighten that part and then the dealer will calibrate it.
    You can open the hood and see the radar sensor. It's a black rounded square unit.
  3. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    The body shop may have the capability to calibrate the sensors. I had a minor scrape repaired at a local shop (one the dealership recommended) and they had the capability to calibrate my sensors. I can believe that estimate looking at the damage. That section is going to need to be replaced.
  4. Bohemiana
    Arizona
    Thanks! Actually, you gave me the idea to just call our usual mechanic because they have the ability to re-calibrate but they will see if they can do it without fixing the body damage. The car has a lot of scratches and all the film is pealing off the black panels so we really don't want to invest a couple thousand in body repair to make it look nice--we just want sensors back and we will drive it until it's so old it just dies, like we usually do with our cars.
    Doug McC likes this.
  5. stoneboyindc
    stoneboyindc New Member
    Bethesda, MD
    2022 Prius
    L Eco
    I am curious to know how a car reports that the front sensor needs to be re-calibrated. Did the information panel show any error message to indicate that the sensor needs to be re-calibrated?
  6. Misterman74
    Misterman74 New Member
    25
    Fresno
    2018 Prius
    Junk yard front end. That skewed sensor is more than likely beyond "calibration " sorry to hear that sucks
