Is Prius Gen 4 more reliable than Gen 3?
Discussion in 'Gen 3 Prius Main Forum' started by Mamalucy, Oct 20, 2025.
  1. Mamalucy
    Mamalucy Junior Member
    22
    Culver City, CA
    Original owner, Bought 2010 early Gen 3 having some problems. 122,500 miles, wondering if better to get a newer Prius Gen 4. Don't care for the newest model.
    Any thoughts? Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    12,794
    5,180
    Pacific Northwest, USA
    Yes
    But problems are limited to head gasket and piston rings...
    You can put a Gen 4 engine in a Gen 3 Prius and solve everything.
    Mamalucy likes this.
  3. Tombukt2
    13,038
    2,336
    Seems like a lot of hybrids are all of a sudden coming down the pike it's going to be interesting for sho. Even Lamborghini is going all hybrid.if I can figure out battery situation for gen1 volt it's one the better cars on planet . Easy to find cheap.
  4. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Why would you get a newer car? What's wrong with the one you have now?
    And you don't like the way it looks, WHY would you spend money on it?
    If your car is paid for, and you like it, WHY get rid of it?
  5. Mendel Leisk
    41,516
    Not sure about that. Getting 4th gen EGR to work in gen 3 is not easy, and afterwards many experienced overheat issues, resorted to modding thermostat.
    If our 2010 ever gets to that juncture, say failed head gasket and runaway oil consumption (which I suspect is pure cargo cult now…), the shopping list would be (gen 3) short block, engine overhaul gasket kit (Toyota, including head gasket), and replaced head bolts.
    And continue to clean the (3rd gen) EGR system periodically.
  6. bisco
    51,996
    overall, gen 4 has about the same reliability, if you don't count the brake actuator, egr circuit and head gasket.
    it has some different issues, but nothing too major. beware the leaky exhaust coolant heat exchanger on early models
  7. BiomedO1
    3,664
    1,897
    SacTown, Ca
    This all depends on the honesty and experience of the mechanic you take the car to, especially if you don't know anything about cars. As a general rule, things usually start breaking around 150K miles on any car. This is where your mechanic's honesty and experience comes in. A smart and honest mechanic can usually get the job done, so that the repair will last - not necessary the cheapest. A shady, dishonest mechanic may also fix the problem, cheap but the repair will only last the warranty period he/she gives you.
    It comes down to; pick your poison - Cheap short term solution or slightly more expensive long-term solutions.
    Statistically speaking, the gen4's seems to have a better track record than the gen3's, but that may be because they are newer with less wear and miles on them....
  8. bisco
    51,996
    well, you've got about 9 years on the gen 4. iirc, gen 3 issues started cropping up well before that
    Starship_Enterprius and Mamalucy like this.
  9. Mamalucy
    22
    Culver City, CA
    Hahaha, thanks for your feedback!
  10. Mamalucy
    22
    Culver City, CA
    Thanks!
  11. Mamalucy
    22
    Culver City, CA
    Thanks! Have an honest independent mechanic. But the costs to fix are accelerating.
  12. Mamalucy
    22
    Culver City, CA
    Hahaha thanks!
  13. rjparker
    10,166
    6,319
    Gen4 is far better than gen3. A redesigned engine eliminated head gasket issues independent of overheating which is common on gen3. Redesigned egr pulled exhaust gasses after a cat rather than before and increased the egr cooler size. Redesigned cylinder cooling evened out cylinder temperatures. Brake booster failures common in gen2 and 3 are rare on gen4. Inverter problems are unheard of a gen4 but so typical on gen3 a class action win extended Toyota's already long 15 year warranty to 20 years. Even with a warranty, sudden inverter stranding is no fun, ask how I know.
    Excessive oil burning in gen3s is real; the gen4 redesign solved that as well.
    Lithium hybrid batteries were available in some gen4s, never in North American gen3s. Regardless, hybrid battery expense can be expected in any hybrid, therefore newer is better.
  14. ASRDogman
    7,607
    3,915
    Yes, but still cost less than a new car.
    And you can learn how to do a lot of those jobs. Labor is usually the most expensive part.
  15. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    Gen 4 is likely the most reliable Prius ever. I'd be afraid to try a Gen 5 until some time has passed.
  16. bisco
    51,996
    i'd go with gen 2, but it depends on how you define it i suppose
  17. rjparker
    10,166
    6,319
    Gen2 burns oil as they age but generally keep running. Any hybrid that is twenty years old will turn into money pits.
    douglasjre likes this.
  18. Mamalucy
    22
    Culver City, CA
    Thank you!
    ETC(SS) likes this.
  19. ETC(SS)
    7,180
    ^ That.
    (It's also the least attractive - but that's subjective.)
  20. Mendel Leisk
    41,516
    I especially loath the all-white interior upholstery (not in all), Darth Vader iPad front-and-center, copious use of piano-black.
