Red triangle, limp mode, P2122, P2138, B2271, C1378
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DMAndy, Jul 17, 2024.
  1. DMAndy
    DMAndy Junior Member
    74
    Maidenhead
    Active
    Well, it turns out you were right, it wasn't the gas pedal. Having driven about 500 miles without any problems, I got the red triangle with the same symptoms yesterday.
    I didn't have my Techstream with me, and needed to make it home, so disconnected the battery for a few minutes and was able to make it home.
    So now it's either an ECM or a wiring problem.
  2. DMAndy
    74
    Maidenhead
    Active
    In case somebody stumbles upon this thread wondering if there was a conclusion. It looks like there was. It seems when I originally took out the hybrid ecu, then put it back again, I didn't connect the harness properly. It seems to be working fine now. Another shout out to @ChapmanF, he was right yet again.
    Brian1954 likes this.
  3. Tombukt2
    13,258
    2,393
  4. ChapmanF
    18,429
