Car Scanner Pro app for Diagnostics
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A.J, Oct 10, 2025.
  1. rjparker
    9,952
    6,140
    Part of the problem is individual pdfs don't provide all the information needed. Online the links work; in the pdf they don't. Wiring diagrams spred over many pages of a pdf don't make it easy to trace circuits and find parts locations which are in another pdf; online is easier. Theory of operation is another abbreviated document; the whole Toyota TIS scheme is setup for trained and experienced techs who don't need routine details. On top of that changes are not available in some early captures floating around the ether.
    As a result many independent shops use alternate sources from places like Alldata. Which still charge.
    priumium likes this.
  2. ChapmanF
    17,872
    A lot of what you'd want for theory-of-operation is covered in the New Car Features manual, which is also available on TIS, and is quite thick, not abbreviated very much. It's the thing the repair manual assumes you've already read, so you know what the different pieces are there for and how they do it.
    People just don't as often make big PDFs of that to share around.
    Beyond that, there's a whole humongous library of technician training course materials on TIS, for questions you might still have even after reading New Car Features.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    So, when you put it in neutral, what RPMs do the MGs show?
  4. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    When mine showed state of charge on the hybrid battery (in my Gen 5), I was surprised to learn that the charging rate in the CHG mode was only about 15 amps, (probably to preserve fuel economy). Hard braking delivered nearly 200 amps regen power.
    Unfortunately, that feature seems to have been removed from Car Scanner.
  5. ChapmanF
    17,872
    MG2 shows the RPM directly related to the car's road speed, according to the final drive ratio and the MG2 reduction ratio.
    MG1 shows the RPM you can find on the nomograph by plotting a line between the engine RPM and the ring gear RPM (for which you can use the MG2 RPM reduced by the MG2 reduction ratio, or the wheel RPM increased by the final drive ratio).
    There is no change in those RPMs from the instant before you put it in neutral. (After that instant, of course, they will continue to vary according to the car speed and engine RPM, always according to the math above.)
    Whatever those RPMs are whenever you decide to shift again from neutral to another selection, there is no RPM change at that instant either.
  6. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    Fact or wishful thinking?
  7. ChapmanF
    17,872
    Well, I don't know what Car Scanner Pro would show, not having used it, but are you thinking maybe it would show different RPMs than Techstream, and Scan Gauge II, and Autel AP200, which I have used, all unanimously show?
    And if you could find an app, whether Car Scanner Pro or anything else, that did show you different numbers than the math with the transmission's gear tooth counts will tell you, how would you explain the numbers shown by such a hypothetical app?
  8. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    I know this has you triggered, but I don't believe a Prius can coast in neutral without computer/electric assist. OK?
  9. ChapmanF
    17,872
    Whatever you want to believe is OK for you.
    Anyone who has spent a moment coasting a Prius in neutral with the power for any "computer/electic assist" turned off has likely reached a different conclusion. I certainly did.
  10. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    What convinced me was while I was in a car wash, it asked me to put the car in neutral. As the engine came on and off, the drag on the drive train remained the same. This would be impossible without computer assistance.
  11. ChapmanF
    17,872
    You've owned a couple generations of Prius—which one was this where you're saying the engine came on and off while the car was in neutral?
    What you think the car wash experience tells you about how neutral works seems to depend on your armchair reasoning about what is or isn't "impossible without computer assistance".
    You'd get a great reality check on that by just getting out of the armchair and taking the simple step of rolling a Prius in neutral, with no power for any "computer assistance", and learning what anyone else learns who does that. It seems you still, while hijacking yet another thread to rehash the same topic, have yet to do that.
    This is the same pattern as in the thread where you thought the 12-volt battery in your car had to be AGM, and from post #66 on page 4 of that thread clear through post #150 on page 8, you refused everyone's suggestion to just go in your car and look, while dismissing what people who had looked were telling you ... and then you finally went and did look, in post #153, and that's when you learned the same thing they'd been telling you for 87 posts.
    At this point, so that this thread about the Car Scanner Pro app doesn't end up completely hijacked into another thread about how Paul thinks neutral works, I'd suggest these ideas for traffic flow:
    Post here if it's about the Car Scanner Pro app, and its features and limitations.
    If anyone reading this thread is curious for more about how neutral does or doesn't work, and how Paul's ideas on that contrast with the 'consensus', there are existing threads for discussion of that; here's one of those.
    Brian1954 likes this.
  12. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    I'm easily convinced with the right evidence. So far I haven't seen it.
  13. Paul Gregory
    2,048
    528
    Alberta
    2024 Prius Prime
    XSE
    You're rolling through a carwash in neutral. Suddenly the engine comes on, and there is no detectible lurch in the drive train. If it were a simple matter of the transmission freewheeling, there would be some backlash as the engine engages. There should also be some drag due to the rare earth magnets in the motors. This does not happen; it's undetectable to me at least. This is why the Car Scanner would be relevant to this question; it would show what is actually happening when you shift into neutral. The only way that this could be accomplished is for the computer to eliminate the torque in real time, proactively with the electric motors.
  14. ChapmanF
    17,872
    In the moments when the car is cranking the engine to start it, or bringing it to a stop, the car always does use coordinated torque at both MGs to minimize the lurching of the car.
    Outside of moments when the car is cranking the engine or bringing it to a stop, there's no need for such shenanigans.
    The most interesting part of your post is where you say "Suddenly the engine comes on" while your car is in neutral. You haven't yet said what generation that was. You've had both a gen 3 and gen 5, right? Which one starts or stops the engine while in neutral?
    Car Scanner is only one of many scan tools that can retrieve and display values from the car's ECUs. If you're interested in "what is actually happening when you shift into neutral", the PIDs that are available for you to peruse include MG1 and MG2 and engine RPM, and MG1 and MG2 torque.
    If you do peruse them, whether with Car Scanner or any other suitable tool, you'll see that "what actually happens" at that moment isn't very much. Things were spinning at certain RPMs the instant before, and they're spinning the same RPMs the instant after. The torques go to zero, as the word 'neutral' conveys. Following that moment, the RPMs will either gradually pick up (if you are rolling downhill) or drop off (uphill or flat).
    The gear ratios that always connect those RPM readings with the engine RPM and axle RPM are things you can look up. They're fixed values for any given Prius model and trim. You won't see the RPMs depart from those relationships.
  15. priumium
    priumium Junior Member
    70
    Sweden
    Why? Toyotas IP is the physical car and the firmware/operating system. It’s not the repair manuals. If so, why would Haynes sell repair manuals? They are not paying Toyota.
    I do understand and know of this opinion, but it’s just so cliche American... The focus is only to protect companies upstream revenue dynamics, not ever on the rights of the consumers to fix their own, owned product. That has been bought for many dollars.
    According this line of reasoning any repair should only be allowed to be done at dealerships..?
    #35 priumium, Oct 21, 2025 at 11:32 AM
  16. ChapmanF
    17,872
    Are you thinking Toyota finds a lot of skilled technical writers and editors and technically-literate Japanese-to-<your language here> translators who are eager to work for free?
    I guess it's possible that AI translation might be getting good enough for them to shed some of that second expense, and maybe it won't even be very long before they can get sound troubleshooting procedures and such written by AI with access to the diagrams and firmware. I doubt they are there just yet.
    I had a cool experience the other day. I had pulled up a datasheet PDF in Chinese for a certain electronic component, and with two taps on my phone I was looking at the same PDF with the Chinese replaced with English in the same layout.
  17. priumium
    70
    Sweden
    The same translator as for Dark Souls, we love em.
    The point is, who are these repair manuals written for..?
    Dealerships.
  18. priumium
    70
    Sweden
    What public available source told you @ChapmanF to use lithium soap grease for the brake glide pins..?
    #38 priumium, Oct 21, 2025 at 11:49 AM
  19. priumium
    70
    Sweden
    These are very valid issues and I fully agree. The PDF file format is very complex postscript code generated to show graphics and text correctly on any screen, and unless made very anal/properly they fail to link and they fail to refer or even use citations.
    It’s however not my main point; repairs should not be forced to be performed by ”mechanics” - if I want to try and learn (and fail), it should be my prerogative as a consumer who bought a very expensive machine to have access to information of how to keep it running myself.
    #39 priumium, Oct 21, 2025 at 11:58 AM
