What product can I use on new headlights, to prevent future fading & yellowing & keep them cl
Discussion in 'Fred's House of Pancakes' started by ski.dive, Oct 21, 2025.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I just installed brand new headlights
    What product can I use on new headlights, to prevent future fading & yellowing & keep them clear?
  2. fotomoto
    fotomoto Senior Member
    5,635
    3,812
    So. Texas
    A garage.
  3. qmanqman
    qmanqman Active Member
    428
    146
    CO
    3M Protective Film. I bought a roll a couple years ago for just this and use a spray coating instead.
  4. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    The biggest problem I see is parking with the headlights facing into the sun. I've seen cars parked in one direction all the time and the paint fades faster on the sunny side. Gen 2's also have a problem with the plastic chrome coating inside the headlight deteriorating. I haven't seen any specific coating to protect, but one of the ceramic waxes might help. Griots is highly rated and does well on YouTube comparison tests.
  5. Tombukt2
    12,940
    2,322
    Nothing that's what's going to happen out in the elements then make a cleaner . If you keep up with it they'll never yell ow
  6. Mendel Leisk
    41,400
    Dang, beat me to it.
    From the gen 2 Owner's Manual:
    I wait in vain, for the glass headlight revival. :(
  7. rjparker
    10,130
    6,293
    The best solution is new headlight assemblies every 5 years or when they start getting hazy.
    The best new headlight add on is a clear high quality uv blocking ppf film, combined with some good led low beams. The ppf should be professionally installed and top of the line. This kind of uv blocking film has been tested as true uv blocking where all the liquids and sprays fail uv testing and don't last more than a year.
    The liquids are good at smoothing out sanding marks created by traditional restoration techniques, which do work for a year. I would never use one of the restoration kits on a new headlight.
    #7 rjparker, Oct 21, 2025
  8. VelvetFoot
    VelvetFoot Active Member
    618
    217
    New York State
    2026 Prius
    I know this is a Gen3 forum, but with the new skinny, recessed led setup on the Gen5, is this problem now a thing of the past?
  9. ASRDogman
    ASRDogman Senior Member
    7,569
    3,903
    If they keep using plastic, no....
  10. rjparker
    10,130
    6,293
    It takes about five years to get hazy, so you can let us know.
    VelvetFoot likes this.
  11. Tideland Prius
    16,553
    Threads merged
    Brian1954 likes this.
  12. ETC(SS)
    7,139
    or? ........
  13. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    Cover them when the headlights are not in use.
    bisco and Brian1954 like this.
  14. bisco
    51,893
    mine were fine after 11 years in the garage
