Idle issue after Gen3->Gen4 engine swap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ilkehylke, Oct 22, 2025.
  1. ilkehylke
    ilkehylke Junior Member
    Finland
    Hello,
    I recently did the engine swap procedure on my 2011 Prius. The car runs and drives, but when idling or pressing the gas pedal when in P the idle is unstable (it sounds like you're lightly tapping the gas pedal repeatedly).
    When driving, I didn't notice this behaviour flooring the gas or under normal acceleration, but the engine is pretty quiet when normally accelerating anyway.
    The engine was taken from a 2016 XW50 and the engine code on it is X2ZR-Y22. The mechanic also had to replace the thermostat housing with a 16331-37100, because the one on the new engine didn't fit.
    As far as I know, they reused everything from the old engine, including the EGR. Or at least I pretty clearly told them to.
    What would be the cause of this issue? How to fix it? Is driving the car like this a stupid idea, or just a minor annoyance?
    51,899
    i thought using the gen4 egr or something was a problem?
    #2 bisco, Oct 22, 2025
  3. ilkehylke
    Finland
    Would that be the cause? As far as I know, they modified the Gen3 EGR and installed it.
    I know that using the Gen4 EGR can cause problems, but I didn't find anything actually detailing what kind beyond the vague claim of "driveability issues".
  4. Mendel Leisk
    41,412
    He's saying it's still got 3rd gen EGR, I think.
  5. bisco
    51,899
    i'm basically saying that there have been problems, but maybe they have been sorted, idk.
    everything i can find talks about cooling, not rpm's.
  6. bisco
    51,899
    looking around, there seem to be a lot of causes of fluctuating rpm's. maybe start with a hybrid battery health test.
    but not knowing the history of the gen 4 engine, it could be any of the likely suspects.
    have you checked all the vacuum hose connections? idk what would throw a dtc, and what wouldn't.
    strange-engine-behaviour-like-revving-while-stopped-at-light.194305
  7. ilkehylke
    Finland
    Funny that you mentioned this, because there were a multitude of issues with the shop, and the whole process took around three months because of that.
    I should probably mention that there was a transmission issue (DTC C2303) which another mechanic managed to fix by straightening some pins to my understanding.
    Anyways, for whatever reason, the hybrid battery actually got discharged during the engine swap and the car didn't start even after fixing the transmission. They charged the cells and it starts now, this being the only problem that remains.
    I'm interested if the car is drivable like this without causing permanent damage, while I try to sort out this problem because in the long run it probably won'g be good, even if it was a minor issue.
  8. bisco
    51,899
    i'm no expert, but i can't see how driving it would be a problem. i wish i could be more definitive than that.
    if you search, you'll find people talking about all the usual gas engine suspects.
    plugs, coils, throttle body, o2 sensors, vacuum hoses and etc.
    ilkehylke likes this.
  9. ilkehylke
    Finland
    Okay, thanks. I'll update this thread when I get the issue resolved.
  10. ilkehylke
    Finland
    Quick update about the car. I did another quick test drive, but after a while of driving home I get a check engine light. The engine also warms up way quicker than it did before the engine swap, in just a couple of minutes of driving.
    I checked the DTCs with a reader and the code in question is P0401. Supposedly EGR flow is insufficient.
    I also checked fuel trims while in P and pressing the gas pedal lightly, STFT showing 20% and LTFT 8%.
    Could it still be a vacuum leak or is it something else? Is the car safe to drive, now that there's an actual DTC? To my knowledge, you can usually drive around with a yellow CEL, but given that the engine in the car is not the original, I don't know if I should trust it.
  11. Mendel Leisk
    41,412
    Post some pics of the EGR components? This was a pro shop that did the engine swap, I gather, not DIY?
  12. bisco
    51,899
    i still think you can drive it
  13. ilkehylke
    Finland
    I'd say the shop is in the middle. Not a dealership (they'd probably say hell no) but not someone's garage with power tools either.
    Here are the images. If they suck, tell.
  14. ilkehylke
    Finland
  15. Mendel Leisk
    41,412
    That might be a gen 4 EGR system. Pics of my 2010:
    Versus yours:
    BTW: is there some technical reason you can’t post pics in Priuschat? They’re much easier to view.
  16. ilkehylke
    Finland
    I googled the part number on the sticker on the valve assembly, which seems to be for the 3rd gen. Is the EGR different from that?
    Also, no special reason. I just don't know how to (do I need to create an album or something?)
  17. Mendel Leisk
    41,412
    There’s something odd in your pics. The pipe between EGR valve and intake manifold for example, seems to flair out the diameter just beyond the flange connecting to the valve. Maybe. Or I’m losing my mind.
    there WAS a revision to the valve.
    posting pics directly (albeit with some down sample) is very easy here. On a phone, choose this:
    Then choose “Photo Library”, and select picture(s) to attach.
    A personal computer is similar, plus if you’ve got an image in clipboard, just use paste function.
    If you subsequently don’t want it in the body of the text, just attached, delete the pasted image, it’ll still be attached.
    Yeah I’m not sure if it’s gen 4 EGR. Tip off would be at the connection to exhaust: the exhaust manifold has pipe that runs sort of back to front to mate up with the EGR cooler, and to connect to gen 4 cooler it requires some heat-and-bend adjustment. It’s hard to see, way back there with wiper in place. If that connection looks “factory”, ignore me. ;)
