List Of 5th Gen Custom PID's?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by VelvetFoot, Oct 22, 2025 at 12:42 PM.
  1. VelvetFoot
    VelvetFoot Member
    313
    79
    New York State
    2026 Prius
    Is there a list of 5th gen custom pid's floating around?
  2. ChapmanF
    17,883
    If no one has already, it should be constructable from a searchable gen 5 Repair Manual, by searching for the string "DATA LIST / ACTIVE TEST".
    The string will match multiple times (probably a couple dozen times or so), once for each ECU in the car that has live data to supply, and you will find the PIDs from that ECU in a table immediately following under the heading "DATA LIST".
    At least, that's the way the gen 3 manual is organized, so probably will work in gen 5, unless they've changed the headings slightly or something, in which case a slight adjustment might be needed.
    Those tables will not give you the PID address / bitfield / arithmetic conversion information that you would need to actually program a scan tool to retrieve the values. Those details are what scan tool manufacturers have to either license from Toyota or try to reverse-engineer. But they'll tell you what all PIDs are available and what they mean, which you can compare to any scan tool's list to see if the coverage is complete.
  3. VelvetFoot
    VelvetFoot Member
    313
    79
    New York State
    2026 Prius
    I thought these custom PIDs might be out in the wild now, at least some of them.
