Walmart Coolant
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 22, 2025.
  1. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Is Walmart's red coolant compatible with the Gen 2?
    I've Googled and Googled and have gotten 8 different answers.
    1. OK in the engine but not the inverter.
    2. OK in both
    3. Not OK whatsoever
    on and on
    I've read there are HOAT, POAT, and PHOAT coolants and for the life of me can't figure out what's what.
  2. BiomedO1
    4,163
    2,180
    SacTown, Ca
    When in doubt; use the OEM coolant........
    'Ya feeling lucky punk' (Clint Eastwood).......... If you put the wrong stuff in there, that could be a costly mistake. I'm also wondering if what someone tells you on a forum is any better than Google AI???? Clearly there's a lot of confusion out there and how do you know someone isn't just "parroting" something else they've read, that may also be WRONG??? If your confused; I sure other people out here are too.
    Food for Thought.....
  3. Tombukt2
    13,455
    2,418
    The Asian red at Wally is fine I have I've 300K with it in 4 cars .
  4. Mendel Leisk
    41,924
    Toyota doesn't insist you use their coolant, just cautions (in Owner's Manual), that if you use an alternate, it should meet certain criteria (long laundry list of of do's and don't ensues). The best I can say about that list, is that I understood "some" of the words.
    Accordingly, I stick with the Toyota coolant. For gen 2, is it "Long Life Coolant", or has that been updated to "Super Long Life Coolant"? Replacement interval is shorter with the former, IIRC.
    Classic Car Guy likes this.
  5. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    Buy the red coolant from Walmart and use it without much risk. I used OEM coolant in the 19 years I own the Prius but it did not protect better any cooling system parts. In 200k miles, I have replaced 4 water pumps, 2 inverter coolant pumps, 1 three-way valve. What more protection did the OEM provide over aftermarket coolant?
  6. PriusTech
    PriusTech Active Member
    262
    120
    Reno
    The quality / applicability of anything but the original factory fluid is a question that can't be answered, nobody knows for sure if it's as good as factory, but we do know it's more likely that it's not. For the best price buy it from one of the many dealers that sell online, or get a price there and ask your dealer to match it.
  7. VelvetFoot
    VelvetFoot Active Member
    1,234
    483
    New York State
    2026 Prius
    Do test strips work?
  8. Mendel Leisk
    41,924
    If a pump’s going to fail, how much difference is a coolant brand, or condition, going to make? I’d speculate if there was any difference it’d be minor.
    Aegean likes this.
  9. Classic Car Guy
    Classic Car Guy Active Member
    466
    127
    Northwest, USA
    Make sense on the coolant.....
    Question... When do you change the Toyota coolant? I had mine service 100,000 miles (Dec 2018). I also changed the 3 electrical pumps including the inverter, 1 mechanical water pump, belt and thermostat.
  10. Mendel Leisk
    41,924
    I’d follow the Toyota guidance, for miles/months. That said, for us it’s been months, by a country mile.
    Danno5060 and Classic Car Guy like this.
  11. Classic Car Guy
    466
    127
    Northwest, USA
  12. Hayslayer
    Hayslayer Active Member
    466
    265
    Prestone makes a pink Toyota/Lexus P-HOAT coolant labeled OEM that is about $25 at our local AutoZone. Think it's item/part #AF7030
    OEM by Prestone Toyota Lexus Pink Ready to Use Antifreeze/Engine Coolant
  13. qmanqman
    439
    152
    CO
    Someone does although that someone has to be a chemist . . . or Google AI
    Q1: is walmart's Super Tech OE Red Antifreeze compatible with the hybrid cooling system of a 2007 Prius
    AI Overview
    No,
    Walmart's Super Tech OE Red Antifreeze is not compatible with the hybrid cooling system of a 2007 Prius. The Prius uses a specific, high-voltage non-conductive, long-life coolant that is different from the standard "OE Red" or "Asian Red" coolants.
    • Prius coolant requirements: The 2007 Prius requires a "Toyota Super Long Life Coolant" or a similar long-life hybrid organic acid technology (HOAT) coolant that is non-silicate, non-amine, non-nitrite, and non-borate.
    • Super Tech OE Red limitations: While some Super Tech "OE Red" products are designed for Asian vehicles, they do not meet the specific requirements of the Prius's hybrid high-voltage components and are not a suitable substitute.
    • Hybrid cooling system risks: Using the wrong coolant can cause a failure in the hybrid system because the Prius's coolant for the inverter and other components is designed to be non-conductive to prevent damage from the high voltage.
    • Recommended action: To avoid damage, only use the specified Toyota Super Long Life Coolant or an equivalent that meets the same specifications.
    Q2: is walmart's Super Tech OE Red Antifreeze compatible with the engine cooling system of a 2007 prius
    AI Overview
    Yes, Walmart's Super Tech OE Red Antifreeze is compatible with the 2007 Prius engine cooling system
    , as it is specifically formulated for Toyota vehicles, including a phosphate-enhanced organic acid technology to match the original coolant chemistry. This type is designed to provide extended life protection for cars requiring a red or pink, silicate-free coolant.
    • Correct Formulation: The Super Tech OE Red Antifreeze is designed to be a direct replacement for the original Toyota coolant, using the same type of technology (phosphate-enhanced organic acid technology).
    • Extended Life: It provides long-lasting protection, with a claim of up to 5 years or 150,000 miles.
    • Meets Standards: It meets or exceeds the ASTM D3306 and D4985 standards for corrosion protection.
    • Recommended Use: It is recommended for use in Toyota, Lexus, and Scion vehicles that require a red or pink extended-life coolant.
    That first bullet in Q2 directly contradicts the AI answer for Q1. LOL . . . can't trust computers.
    PriusTech, Aegean and fragglestickcar like this.
  14. qmanqman
    439
    152
    CO
    My daughter's 2007 has 323,525 miles on it and I bet the coolant has never been changed. Although I may have done it sometime in the past 7 years and just don't remember. Coolants are amazing.
    Mendel Leisk and priumium like this.
  15. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
  16. BiomedO1
    4,163
    2,180
    SacTown, Ca
    Do a litmus and glycol test to see if it needs to get done; cross that bridge when you need to.
    IMHO: I'd probably stick to OEM, since the REAL question here is inverter coolant. Rather than have two different coolants, I wouldn't chance putting an unknown into the inverter cooling system. But that's just me....
  17. qmanqman
    439
    152
    CO
    I hear ya bro. When google AI responded with "NO" I about shit my pants. I think she put a tiny bit of that in there. I'm thinking I'll do a drain and fill on it.
    BiomedO1 likes this.
  18. BiomedO1
    4,163
    2,180
    SacTown, Ca
    You need to tell her to ONLY top-off with distilled water, if she can't find the right stuff. Regular drinking water, if distilled isn't available. Deal with the glycol concentration imbalance before the next long freeze.
    I've dealt with a few gelled cooling systems in my day; so that's a very expensive lesson to learn. The other is a silent killer, eating away at the internals of rubber and gasket components - Not changing your coolant.
    Hope this helps.....
  19. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Many tumble driers (yep, those household machines) here in Sweden have a collection unit for the condensed water. This is almost flawless distilled water. I use it for many tasks, it’s free and when water is gas and then cooled, it will not consist of any pollution as chlorine etc.
