Why Not to use SuperTech Coolant in your Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Nov 26, 2019.
  1. anonymous
    anonymous Member
    177
    99
    US
    From the manual:
    On the label of the cheapest SuperTech coolant concentrate:
    And from what I have read, I believe it is a hybrid organic acid technology coolant. So it seems suitable for use in a Prius and is the cheapest coolant I am aware of (especially when using concentrate; $9.88 plus up to $1 for distilled water makes two gallons, while two gallons of pre-diluted Zerex or genuine Toyota coolant would cost around $30 or $50, respectfully). Since I was doing a full coolant flush while doing head work, I decided to try it, thinking it should work perfectly fine.
    Well once I filled the system I found a problem...
    The coolant is the same color as the reservoir!! You can barely see it! :ROFLMAO:
  2. anonymous
    anonymous Member
    177
    99
    US
    BTW. I remember SuperTech coolant used to be green. While I was getting the coolant I saw most of the bottles had a new label, but there were some left with the old label. Next time I saw they were gone.
    I thought they just changed the label but apparently they changed the formula as well. Information on the back is slightly different too. Here's the old label vs the new label.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I thought they use Phosphates? Just reading up on the Prime manual just now it excludes all those as well but does NOT mention "no Phosphates".
    moto g(7) power ?
  4. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Question: why (why?) go on the cheap for a product (an IMPORTANT product) that will go 100,000 miles INSIDE your cooling system?
    Why?
    Danno5060, mikey_t and Mendel Leisk like this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I have a couple reasons I've done this in the past. 2017 Alfa Romeo Guilia lease I did not want to buy yet another spec coolant, (just to top off on a 27 month lease,) when I already have maybe 8 different types (I believe 12 gallons/partial gallons) from the other cars we've had in my lifetime. 2018 Honda Clarity PHEV-. Had a burning smell driving in hybrid mode on the way to a birthday party on Saturday. Sunday morning when I had a chance to check what was wrong I found the HV battery coolant somewhat low, and dealers closed I went to AutoZone for some coolant. (I ALMOST made the mistake of non-phosphate enhanced coolant but rechecked what I was holding and swapped it with the phosphate enhanced stuff).
    moto g(7) power ?
  6. anonymous
    anonymous Member
    177
    99
    US
    Because I'm cheap, and I'm confident that this coolant is perfectly suitable for this cooling system and any more expensive coolant is just a waste of money. But there is only one way to find out for sure and I am willing to experiment.
    qmanqman likes this.
  7. Mendel Leisk
    41,863
    I stick with Toyota Super Long Life, because I can't be bothered to exhaustively check the compatibility of something else. Following the Canadian schedule for me, it's going to be once every ten years. Ten, even twenty bucks difference, cheap price to avoid the uncertainty.
    #7 Mendel Leisk, Nov 26, 2019
    Bbonez and mikey_t like this.
  8. bisco
    52,351
    you're not cheap enough mendel.
    we'll be revoking your frugal club membership card.
    #8 bisco, Nov 26, 2019
    qmanqman and Mendel Leisk like this.
  9. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    I have never understood the logic in spending tens of thousands of dollars on any vehicle...only to cheap out maintaining said vehicles.
  10. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    While shopping at Walmart, you can by the legit Zerex (Valvoline) equivalent to SLLC for $12.48/gallon. That's not as cheap as the "universal" concentrate, but less likely to result in easily avoided disaster.
    jzchen likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I do believe the Asian manufacturers use a P-HOAT formula, (phoshpate enhanced):
    Engine Coolant &ndash; Choosing the Right Type for Your Car | Valvoline&trade;<br />
    That said a little top off may not hurt...
    moto g(7) power ?
  12. Ormonddude
    Ormonddude Junior Member
    Daytona Beach
    Because a 2004 - 2009 has a Book Value of 4k or Less and tends to start blowing coolant pumps all the damned time so a Affordable Option is More than Reasonable at this Point - Get it - Money Good?
  13. Mendel Leisk
    41,863
    I bought a 4 liter bottle of Toyota Super Long Life Coolant in April of this year, for $22.95 CDN (at dealership parts counter), the 55% pre-mix Toyota Canada sells. You'd need at most a couple of those bottles, to change both the engine and inverter circuit. And that's every 5 years or 50k miles (after the initial change)
    Presumably the cheaper stuff IS cheaper than that? How much? A buck per bottlle?
  14. Danno5060
    Danno5060 Active Member
    394
    201
    Wyoming
    That Toyota coolant has worked out pretty well for me so far. I've changed it around 100K miles in my Gen 2 and Gen 3. It looks factory fresh in the electrical part, and maybe just a little faded in the ICE part. I'm just not willing to try something new, when that stuff works.
    I've got a GM where I'm thinking what if I use the Toyota stuff rather than that Dex-Cool crap.
  15. BiomedO1
    4,089
    2,139
    SacTown, Ca
    FWIW; Looks can be deceiving; need to test glycol concentration and PH level to make sure it's still good (within specs.).
  16. qmanqman
    qmanqman Active Member
    439
    152
    CO
    I've never understood throwing away money for no reason whatsoever. Would you just take ten $1 and toss them off the porch into the wind just because? It's why we DIY. Do some research, figure out what is and what is not and then buy the cheapest thing that does the job. I did this a few years back and did an ATF change in the Prius with Valvoline Max-LIfe Multi-Vehicle ATF.
    #16 qmanqman, Oct 23, 2025
  17. qmanqman
    439
    152
    CO
    I'm like you bro. BTW what were you able to learn from your experiment?
  18. frodoz737
    4,719
    2,517
    33
    Yea...what would a "Top Wrench" know? Don't listen to me. :rolleyes:
  19. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    I agree with this sentiment. You are safe with the OEM installed fluid. It's only a few bucks, whereas using the wrong product can destroy the engine and cause thousands in damage. Be safe. At the minimum, make sure any non-OEM meets the minimum specifications (a dangerous task if you don't understand the specs).
  20. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    If it's a reputable brand and claims to be equivalent to Toyota SLLC it very likely really is. The only significant difference is the price.
