1. Duhkote
    Duhkote Junior Member
    Hoping someone might be able to help me with this.
    About a month ago my '06 felt like it lost all power... moments later the dashboard lit up and the car would not accelerate or start. I ended up replacing the 12V battery and the car ran fine afterwards. Didn't have my actual code reader but all we could read was P3190 at the time.
    After nearly a month of driving with no issues the same thing happened, this time I was able to get codes P0A0F and P3190. Took it to my mechanic who thought it was the fuel pump but when he tested it everything was fine (good pressure and volume). He says he added some ether to the car and it started up just fine, no issues since (he's had the car for 2 days now). Car has been driving fine and completely normal.
    His next leading theory is the throttle body is on its way out, but even he said he wasn't 100% on that diagnosis. And replacing it will end up being a $750 job for something we're not certain about. Anyone else have any other idea what it could be? Planning on taking the car back and driving it around until it happens again, but it is scary feeling like I'm driving a ticking time bomb...
    TIA!
    51,678
    how many miles on her?
    you may need a better mechanic. those codes are simply pointing to an engine problem, like any gas engine.
    a good mech will go through a checklist, starting with the low hanging fruit and working their way up.
    here's some help, and there's more on the net if you're interested:toyota-prius-p0a0f-and-p3190-no-throttle-response-solved
    watch
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,029
    1,958
    NJ-USA
    I would clean the throttle body bore and blade (also clean the MAF sensor), then drive the car while monitoring short and long term fuel trim.
    Ideally, fuel trims should stay close to 0%. If there's a large deviation (say greater than +/-15%), then the ECM is trying to correct for some fault. There are different trims for different driving conditions: idle, cruise, accel, etc.
    Brian1954 likes this.
