How far did you get on "empty?"
Discussion in 'Gen 3 Prius Fuel Economy' started by Paul Gregory, Apr 5, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    Coming back from B.C. one night, the low fuel indicator light came on at Field B.C. I zeroed the trip out of curiosity, and we got all the way to just past Cochrane AB, before it sputtered to a crawl. The odometer was at 180 kms (112 miles). It was still able to move on electric power, but at a reduced speed. I opted not to push it to the very limit, so I put in the gasoline I had on board, and made it to the next gas station.
    I have run it completely to a stop unintentionally after running out of fuel. It was a bad situation, because I couldn't even raise the windows. I didn't want to leave it by the roadside with the windows down, so I had to rely on a stranger to bring me gasoline. Don't ask me how far I got on electric power alone, but it was a lot less than I expected.
  2. ASRDogman
    ASRDogman Senior Member
    7,656
    3,940
    It's never good to run out of fuel, in any car....
    When the light starts flashing, you SHOULD get gas. Note how much
    fuel you put in, probably around 9.5. And you know if for some reason you
    HAD to drive, you have about 2 gallons to do it on. Which should be enough
    to get to any fuel station...
    The fuel also cools the fuel pump. When it gets too low, it's not being cooled as well.
    Khezekiah and Extricator like this.
  3. bisco
    52,100
    this is a gen 3 forum
    Khezekiah likes this.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    We can’t even go pass a mile on EV, what are you even taking about?!
  5. fuzzy1
    10,524
    There are other threads about intentionally testing range to fuel starvation for Gen3 liftback and 2017-ish Prime. Is your 'testing' (deliberate and/or unintentional) about either of these models, or is it about your 2024 Prime? If for either era Prime, this belongs in a different forum here on PriusChat, not in this Gen3 non-plug-in forum.
    Depends on where one is going. Eastbound from Field, he has only 16 miles to get to Lake Louise. Sounds like he got past Banff and Canmore too, almost to Calgary. Westbound, about 35 miles to Golden. But the next section, 90+ miles from Golden to Revelstoke, might require more than 2 gallons during winter weather.
    South of the border, we have several places without fuel service even longer than that, so one might need to turn around and backtrack. One section I have pictured in other threads, will need 3 gallons one-way in good weather, more in lousy winter weather.
    It is cooled by fuel flowing through inside the pump, not from a bath outside. Cooling ceases at about the same point as fuel starvation.
  6. ASRDogman
    7,656
    3,940
    Gasoline does not flow through the electical part of the fuel pump...
  7. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    I just don't believe that the fuel pump will overheat when you run out of fuel. I just don't.
    I only did the test once, no harm in finding out how far you can actually go after "empty."
    VelvetFoot likes this.
  8. ASRDogman
    7,656
    3,940
    Believing or not believing does not change facts.
  9. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    Exactly. So where's your evidence that the fuel pump overheats when you run out of fuel?
  10. VelvetFoot
    VelvetFoot Active Member
    874
    311
    New York State
    2026 Prius
    I tried to break a personal best tank miles once on my VW TDI diesel.
    Much harder to prime a diesel on the side of the road, lol. At least mine was. I recall a lot of cranking was involved.
    I think now there's a transfer pump in the tank, so it shouldn't be as much of a problem, but I haven't been following.
  11. bisco
    52,100
    i'm still not sure what car we're talking about (n)
  12. ASRDogman
    7,656
    3,940
    It doesn't matter..... People are going to do what they want.
    It's not worth the effort, they just want to argue.....
  13. Mendel Leisk
    41,661
    I'd take making the best mpg, over stretching a tank. The latter is likely to inconvenience you, possibly damage something.
    My strategy: if the gas gauge is at or below half, and there's a convenient Chevron, I'm filling up. Almost invariably it's the same station, same pump. Quit pumping the first time it cuts off.
  14. VelvetFoot
    874
    311
    New York State
    2026 Prius
    It had a 15 gal tank as I recall. I was trying to break 900 miles. I don't remember if I succeeded. :)
  15. Mendel Leisk
    41,661
    Pure numerology. :rolleyes:
    that said, I did get the wife to snap a pic when odo hit 100k kms. :)
  16. bisco
    52,100
    as an old member once said, i fill up at e when alone, at 1/4 with my wife, and at 1/2 with my mother in law :cool:
    BiomedO1 likes this.
  17. BiomedO1
    3,805
    1,978
    SacTown, Ca
    that is one old wise bird:p:D:LOL::ROFLMAO::whistle:
  18. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    The fuel pump (inside the fuel tank) is cooled by the fuel in the tank. If there is no fuel in the tank, the pump will overheat, unless there are electronics that shut it down to prevent overheating. That's my story and I'm sticking to it. ;)
  19. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    I wouldn't be the first one to run out of fuel, but if it would be so poorly designed as to burn out, I'm sure Toyota would have issued warnings.
  20. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    From what I observed, the system shut down when the engine stopped due to running out of fuel.
    It would make no sense for the fuel pump to keep running dry.
