ABS Sensor or worse?
Discussion in 'Gen 2 Prius Main Forum' started by DJLand, Feb 28, 2025.
Tags:
  1. DJLand
    DJLand New Member
    Ontario
    Four Touring
    Hi All,
    Longtime lurker, new member. Thanks for the earlier help! We own a 2008 Touring bought from the original owner in 2011 or so, now with 360k kM (225K miles) which has been mostly great, only serious problems being the Inverter cooling system pump which has failed twice over the years. We're on our 4th 12V battery and replaced the traction battery two years ago. We live in Ontario, Canada but winter in southern Mexico where the car is now, in the middle of its third trip south, hopefully headed back north in a month or so.
    Last summer up north it needed a new driver's side front bearing which was done at a local garage. After that the ABS/VSC/! lights came on and would go on and off sporadically. Never spotted a pattern. After consulting here and having the bearing garage look at it it seemed the LF ABS sensor was the problem. Replaced it, problem continued. Other than the lights on the dash there seemed to be no major effects. I got an OBD cable and a copy of Techstream working on an old laptop and confirmed that it seemed to that ABS sensor was the problem. Ran out of time up north and punted the problem down the road, not too worried.
    Our gas mileage was about 10% worse than usual up north and has been getting worse and worse down here. This is mostly shortish trips under 100kph with the AC working hard but we're now burning like 1.5x the gas we used to. That sucks but isn't the end of the world, but I'm a bit concerned that the ABS sensor failure has led to the braking system working overtime leading to the bad mileage and rapid wear on the front brakes and the actuator, which would be hard to replace down here. Driving wise I haven't had any real issues and haven't heard the actuator system making weird noises, or maybe I'm used to them? Probably unrelated but with the bad roads and speed bumps here the strut assemblies in the front need replacing and the undercarriage and frame surfaces just behind the front wheels hit speed bumps pretty firmly some times.
    So my questions:
    1) Is there something that the garage could have done wrong in the bearing replacement that started all this, like a misalignment of the ABS sensor and the teeth of the gear it senses, that has led to the original and replacement ABS sensor both failing to work consistently. Something I can fix?
    2) Is there some way to easily figure out the problem Dr Prius or Techstream? I have both here though neither is bulletproof in operation.
    3) If I choose to drive the 5000 km north as is with the poor fuel mileage are we in mortal danger?
    4) Is there a thread on here that covers this topic exhaustively that I have not yet found? If so, thanks for the referral.
    Thanks much for any assistance or links.
  2. Aegean
    Aegean Active Member
    462
    204
    Alexandria VA
    Obviously the hub replacement created the ABS sensor issue. If the sensor has been replaced since then, maybe the issue is the sensor plug or wiring. Did the mechanic stretched it?
    The gas mileage is probably an unrelated issue. Maybe your HV battery is now getting worse. Was the traction battery replaced 2 years ago with a brand new OEM or a rebuild with old modules?
  3. Brian1954
    Brian1954 Senior Member
    2,162
    841
    South Central PA, USA
    The first thing you need to do is run a health check with Techstream and report all the trouble codes that are found.
    The lower fuel mileage may be caused by the regenerative braking not functioning due to the trouble codes that you have.
  4. DJLand
    DJLand New Member
    Ontario
    Four Touring
    Thanks for the ideas. Aegean, I replaced the FL ABS sensor myself, the wiring did not seemed stressed, and the fact that the symptoms did not change with the new sensor makes me suspect the sensor itself isn't the problem. The HV replacement battery was OEM from Toyota so I don't suspect it though I will run Dr Prius one day soon.
    Brian I think you are right that there is/was something wrong caused by the bearing replacement but can't tell what. I do see regenerative braking / HV battery charging happening on the Energy screen so that doesn't seem to be it.
    I got techstream working today and the codes were the same as last fall:
    C0205 Front Speed Sensor LH Circuit
    C1236 Foreign object is Attached on Tip of Front Speed Sensor LH
    Confirming the problem is related to that sensor.
    I jacked it up and put new brake pads on the right and then left. The old ones were down to maybe 30% but I had new ones handy and the disks seemed ok. Not sure if we ever replaced them before, even after 360k km. Took a look at the sensor and the gear inside. Replaced the LF pads and the sensor situation looked similar. I did scrape the mounting surface and filed the seating end of the sensor a bit to hopefully get a fraction of .001 inches closer to the gear.
    I had my wife drive out to the highway, looking with techstream at the wheel speed values and they seemed fine. After a few minutes the three dash lights ABS VSC Brake came on again and I found in techstream how to clear them and did, the lights went out but don't know if they will return as they have so often.
    I'm encouraged that 1) no worse or new trouble codes came up 2) the brakes, regeneration, etc seem to work normally even with the bad sensor problem and 3) I can get techstream running even while the car moves, to clear codes, possibly turn off traction control, and read the wheel speeds (and so much else) on the go. I'm feeling OK about the Actuator which seems to behave normally.
    Not clear why the mileage is bad but maybe it will get better on highways north. If gas in the US stays cheap another 6 weeks it won't be too big an expense.
    Thanks again, and I welcome any more advice / speculation / commiseration.
  5. DJLand
    DJLand New Member
    Ontario
    Four Touring
    I had my wife drive out to the highway, looking with techstream at the wheel speed values and they seemed fine. After a few minutes the three dash lights (ABS VSC Brake!) came on again and I found in techstream how to clear them and did. The lights went out but don't know if they will return as they have so often.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    My thought right now is that there could be damage to the toothed tone ring on the axle. That's the ring the sensor "reads" to produce the wheel speed signal. Might be cracked or have a damaged tooth.
    Ideally I would want to use a scope to see both front wheel speed signals. How is the left side different from the right. That should flush out what's going on.
    Since you cleaned the sensor mounting face, that would eliminate "rust jacking" from reducing signal amplitude.
  7. rjparker
    10,099
    6,263
    Not likely causing the braking system to work hard and nearly impossible to cause rapid wear unless your regen was not working at all.
    LH Circuit means a wiring or sensor break or short, likely intermittent. Foreign object is exactly that, a piece of metal causing interference. The hub needs replacement again. Was the first replacement oem?
    Clearing codes fixes nothing.
    The problems with the speed sensor wiring and foreign object probably were caused by the replacement part and the mechanic.
    You risk loss of abs function at a bad time which can cause longer stopping distances and swerving.
    The reduced mpg could be low octane gas and ac use. Lost regen could be real at times.
  8. DJLand
    DJLand New Member
    Ontario
    Four Touring
    I jacked up and supported the car, removed the sensor and slowly spun the wheel. Indeed at least one tooth of the tone ring gears is bent and some others seem damaged, from when the bearing was replaced.
    Can the tone ring be replaced separately or only with the drive shaft and CV joints?
    Thanks.
  9. DJLand
    DJLand New Member
    Ontario
    Four Touring
    Fixed. I had to buy a replacement left drive axle. There's two YouTubes about it and it went OK. I needed to buy a 30mm 12-point socket also. Using it and a breaker bar and a 8 foot pipe we were able to get the nut loose. Then ramps and jacks and jackstands to get the wheel well off the ground. I got the 3 17mm nuts and bolt off, and the axle out of the bearing assembly. Levering the old axle out took a long time but it finally came. Luckily I had a bucket handy as about 2 quarts of ATF followed. The new axle looked about 2 inches shorter than the old one but they are made to extend do it fit ok eventually. I screened and reused the ATF out of my bucket plus some Ford ATF I had around and it still wasn't full so I got another quart and a new fill plug gasket since. I'm getting an oil change this week so I'll have them add enough to fill it while they have it on a lift. Finally those three ABS/Brake/ traction control lights are staying off. Si stupid that it was dassuage to one tooth of the ABS tone ring caused all of this.
  10. DJLand
    DJLand New Member
    Ontario
    Four Touring
    By the way it's at 387k km now and headed back to southern Mexico in two weeks. I hope it makes it back to Csnada pushing 400k in April.
  11. Brian1954
    2,162
    841
    It is a very bad idea to use Ford ATF in the tranaxle of your Prius. Only use Toyota's recommend tranaxle fluid for the Prius. You should drain the tranaxle fluid and fill it with new Toyota fluid!
  12. DJLand
    DJLand New Member
    Ontario
    Four Touring
    Well, we will see. What's in there is about 90% Toyota ATF. Changed a few months ago. And topped up today with more Toyota ATF. At $17 and quarter I'm not throwing it all out. I had to suppose putting a bit of Ford fluid in when it was low was better than nothing.
  13. ChapmanF
    18,089
    If the Ford fluid is also used in transmissions that contain 500-volt wiring and is known not to degrade their insulation, it might be ok.
  14. Brian1954
    2,162
    841
    It is your car. Do whatever you want. If you encounter problems with the motor/generators in the future, then it will be time to junk the car.
    #14 Brian1954, Oct 24, 2025
