Codes P3190, P3191 after replacing EGR cooler, egr switch, intake manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FrugalBeeotch, Oct 24, 2025 at 11:40 PM.
  1. FrugalBeeotch
    FrugalBeeotch Junior Member
    People's Republic of Seattle
    2013 Prius Plug-in
    I spent 9 hours replacing the egr system and the intake manifold. When I started the car, it said there's a problem with the hybrid system, and threw P3190 and P3191.
    Any idea what I did? I'm a little deflated. I thought I could do this. I clearly made a mistake.
    I left it at the diy garage overnight.
  2. ChapmanF
    17,898
    The codes are less specific than you probably hope: they're telling you the engine didn't start. (P3190 means it produced less than a fifth of the torque expected, i.e. didn't run well at all, and P3191 means that happened while trying to start it.)
    The problem could easily be something quite simple. An obvious way to start is by double-checking that you've reconnected everything that had to get disconnected to do the job.
  3. FrugalBeeotch
    2013 Prius Plug-in
    Yeah. I did some of that last night before the shop closed. I'm going back this morning. Maybe fresh eyes will help me spot the problem.
  4. FrugalBeeotch
    2013 Prius Plug-in
    I had left a vacuum hose disconnected. I fixed that, but it's still throwing the codes.
  5. Brian1954
    Brian1954 Senior Member
    2,064
    803
    South Central PA, USA
    Does the engine run for more than 30 seconds when you start the car?
  6. ASRDogman
    ASRDogman Senior Member
    7,488
    3,881
    Clear the codes, and start again...
    How is it running? Smooth or rough?
  7. FrugalBeeotch
    2013 Prius Plug-in
    It wasn't before I connected the vacuum hose. Then it ran until the hybrid battery was sufficiently charged, and when it shut off the engine it sputtered briefly until the engine was off.
  8. FrugalBeeotch
    2013 Prius Plug-in
    It runs smoothly until I need to stop, then sometimes it sputters to a stop. When I was pulling in the driveway, it sputtered hard. No check engine light or error codes.
  9. ASRDogman
    7,488
    3,881
    You should recheck everything, slowly. If it was running okay before the work, and not after,
    something is not connected correctly.
  10. Mendel Leisk
    41,118
    Did you replace everything? With new or used" Definitely hang onto everything removed.
