Inside smells really bad
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by cool_prius, Mar 26, 2025.
  1. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I bought one from Wallyworld for like $45 for a different project that worked great. I believe the brand was pro breeze? It's literally the smallest one they sell in store.
    When I do my filter service I like to treat the system with a short spray of Ozium into the cabin filter slot with the fan on high before I put the new filter in. I'll let it run for 5 minutes after with the windows down just to air it out a bit. I think this is the same stuff as the small can included with the Toyota kit. My other Toyota sits longer and tends to get funky faster, but I have gotten the wet dog smell in the Prius once or twice before. Carbon cabin filters are cheap, replace them often. I do them every 5k.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,211
    583
    Alberta
    2024 Prius Prime
    XSE
    I have an ozone generator that works quite well for removing odors from a room.
  3. Mendel Leisk
    41,807
    I've change the cabin filter on our '10, once.
    That said, I'm "somewhere", west coast Canada, maybe a lot less dust in the air.
  4. mingc
    mingc Member
    70
    Portland, OR
    2023 Prius
    XLE AWD-e
    We get a lot of pollen in the Pacific NW. I'm always surprised at how dirty my cabin air filter gets. Conversely, I was surprised at how clean my engine air filter was after the horrible forest fires in 2020, when we had the worst air quality in the world where I lived, for 10 days.
    #104 mingc, Oct 27, 2025
  5. VelvetFoot
    VelvetFoot Active Member
    1,117
    433
    New York State
    2026 Prius
    Remember this one?
    I think Jerry drove a BMW in this episode.
  6. Trollbait
    12,652
    Crystal cat litter can be used instead of Damprid. You need to supply a container, but an old sock will do. It can be regenerated in a 200F to 250F oven for an hour.
    VelvetFoot likes this.
  7. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    I spoke too soon.
    During a cleaning I pulled up the rear all weather mats and noticed that under them they had speckles of condensation on the bottom of the mats. Weird because my back seat doesn't get used except for groceries and nothing spills in my car EVER.
    The REAR PASSENGER SIDE FOOT AREA where it meets the plastic housing for the HV battery had a visible amount of moisture.
    This moisture was not just on the carpet but had wicked up the plastic a bit as you can see in the picture.
    This was noticed on the 2nd. I cleaned it up and have been checking it since. Visible moisture has not been present since then BUT squeezing my fingers between the carpet and the HV battery housing you see in the picture results in wet fingers (heh). So there is moisture collecting under there, source unknown.
    My first assumption was the shark fin on the roof. I pressurized the cabin, air on high with external intake selected, you can feel with the door cracked that it's pushing air out the door. I shut the door and took a bottle of water + dish soap and sprayed around the shark fin. No bubbles. Rinsed and repeat to be sure, still no bubbles. So with that I don't believe the point of ingress is the shark fin.
    I also took a borescope and tried to see if I could maneuver it to see anything useful. I think I saw some rust but can't be sure. My next step will be to remove the back seat cushion and visually inspect.
    What I ask of you, if you have the wet dog smell, is to check the same area for moisture in your car during or a day after it rains. Remove your rear floor mats and check between where the carpet meets the plastic housing of the HV battery.
  8. VelvetFoot
    1,117
    433
    New York State
    2026 Prius
    That is indeed a bummer.
    I've read of missing body plugs the dealer didn't put in related to shipping.
    You've looked in the spare tire well, under the foam? At least it's easy to get to.
  9. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    Trunk area is dry. It's where my amplifiers live. Never noticed any water back there in any capacity and I've been in and out of there in all sorts of weather cleaning up or redoing wiring, different configs, etc. But the next extended reprieve from the rain I will double check.
    Btw they are mounted on carpeted plywood which is attached to the trunk via an industrial adhesive. I am very much against destructive modifications due to the liability it would incur for warranty work. No cut wires, no holes drilled. Only hole I've put in the car is in a small easily replaceable part of the dash for a gain knob for my amp, part #5540647170C0.
    #109 soft_r, Nov 5, 2025
  10. VelvetFoot
    1,117
    433
    New York State
    2026 Prius
    I'm thinking of a similar rubber plug like in your picture.
    Perhaps some weatherstripping on hatch or rear doors?
    How definitive was that pressure test?
    There's always a smoke test...just kidding.
  11. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Might be the stinkin' payments? Like the new car smell, hate the stinkin' payment.
    PhoS likes this.
  12. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I think it could creep down there from the door seal. Make sure it's pressed fully on the seam, I noticed it gets dislodged somewhat easily when I was running my amp wires. I checked mine after seeing your post, it has been dumping here intensely for weeks and I didn't find any moisture in mine luckily.
  13. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    Door seals checked and tested, all dry.
    Pulled the small plastic trim panel at the bottom of the door that hides the body wiring, that's all dry.
    I lifted the seat cushion and didn't see water on the top level of the HV battery area but couldn't see the below level where the trim meets carpet due to obstructions.
    I retested the shark fin AND this time included the black plastic runners that go front to back on the roof of the car, nothing generated bubbles.
    Next move is figuring out how to remove the entire plastic cowling from around the HV battery which will give me a full look at the problem area. At a glance I'll need to remove the seat cushion again and remove both door floor plastic trim panels (very easy they pop right up). After that, will just have to figure it out. Will post pics of findings when I do.
    PhoS and VelvetFoot like this.
  14. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    Cowling came off pretty easily. Lift seat cushion, lift foot trim door panel, remove 2 plastic push clips, then just pull semi-gently as the standard clips let go.
    ZERO signs of water intrusion. Not a single drip line showing where water may be coming in. o_O:(
    Going to leave the cowling off and see what future rainy days bring. But yeah, I'm starting to think this is condensation buildup rather than a leak.
    I also removed the rear overhead light and fed my borescope where I could, no rust or water lines seen.
    I fed it down the C-pillar and it all looked super dry as well.
  15. VelvetFoot
    1,117
    433
    New York State
    2026 Prius
    Could that umbrella have been involved? :)
  16. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    Lol I knew someone was going to bring that up, but no. I have not used that umbrella yet this year. It sits back there waiting for its time.
    Plus the moisture was coming from between the carpet and cowling.
  17. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    No payments. Paid in full. The part that bugs me is the fact that a brand new car is giving me problems.
    #117 cool_prius, Nov 13, 2025
