Splicing Headlight Wiring Connector Issues
Discussion in 'Prius v Main Forum' started by Gahzoo, Oct 27, 2025.
  1. Gahzoo
    Gahzoo Junior Member
    2012 Prius V wagon. 354k
    - Replaced passenger side headlight bulb with 100w H11 generic from Amazon.
    - Bulb soon failed with evidence of burning around base, as well as "welding" itself to connector.
    - Mechanic had to replace connector by splicing and crimping into existing wiring harness.
    - Car now will occasionally throw a bunch of lights on dash. Scan for code, no code stored. Clear code anyways to turn off extra lights on dash.
    - Car will also now turn off ECO mode, which I always leave on.
    In short, I know my car and how it normally operates. Is it reasonable to conclude given the electrical systems in a Prius V, that any electrical modification will cause all kinds of potential related chaos? I'm guessing, yes!
    - Had a similar issue recently with spliced wires for an aftermarket fan. What a nightmare. Issue solved when replaced with OEM.
    - In other words, these cars are highly sensitive to splicing of wires. I'm convinced that my only solution is to replace entire headlight wiring harness with the OEM part. Thought/opinions are welcomed. Thank you!
  2. rjparker
    10,130
    6,292
    If you have aftermarket LED bulbs in those sockets they can cause interference.
  3. Gahzoo
    Never had that issue before, however from now on anything electrical for my Prius will be OEM, ONLY!
  4. rjparker
    10,130
    6,292
    There are led bulbs with built in filters and there are plug in filters as well. The splices on those circuits (eg non-comm) are not the issue.
    Brian1954 likes this.
  5. Gahzoo
    Ok, thank you.
    Gonna' try just replacing the bulb with OEM, first. Fingers crossed!
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    I would examine the mechanics work first.
    The wires are of a very small gauge.
    If he or she used crimped connectors the connector may have high resistance and causes a fault and a voltage drop.
    In this case, solder connections covered with heat shrink tubing is a much better long lasting option.
    Gahzoo likes this.
  7. Gahzoo
    Good suggestion. Ty
  8. Air_Boss
    Air_Boss Senior Member
    4,197
    1,182
    New Yawk
    A 100w halogen lamp capsule could easily melt the lamp holder base if not also the wiring, especially if corrosion was present.
    Gahzoo likes this.
  9. ChapmanF
    18,146
    This is a FPS (frequently-posted situation) on PriusChat, because there are so many code scanners out there that don't show all the codes from a Prius. If there are warning lights on and the scanner you're using won't show you the codes that tell you why, a better scan tool is needed for the next time the lights come on.
    That would be too much to conclude on the evidence you've supplied. You've been getting some trouble code or codes starting after the work was done, and because of the scan tool you're using, you don't know what code(s) yet. The likeliest situation is that the codes are being set because their normal detection conditions have been triggered and they mean what they normally mean, and that finding out what codes they are will get you valuable clues into the situation. The fact that you don't yet know what the codes are does not, by itself, turn the situation into "chaos".
    I haven't noticed them to be any more finicky than anything else in that respect. But see below about headlight splicing specifically
    You're in for some sticker shock with that approach. Unless they wired the v radically differently from the gen 3 liftback, there is no separate "headlight wiring harness" for you to replace. Those circuits are part of the Engine Room Main wire harness, which runs throughout the engine bay, includes the fuse box, penetrates the firewall in two places, and connects to other items and harnesses at multiple locations accessed by removing the dash top. On top of the price of the harness itself, it's a laborious replacement.
    Caution: the link I gave above is to a part number for a 2012 v engine room main harness. But there are probably several different part numbers for that depending on the car's exact trim and options. If you choose to go that route, you need to be very careful to get the exact right one.
    Careful when splicing gen 3 headlight wires:
    Although I'm not in the "car is super finicky, mods will cause chaos" camp, I still do recommend checking the mechanic's splicing work very carefully and being prepared to redo it.
    That's for a whole different reason: if the v is like the gen 3 liftback, Toyota used aluminum wiring there.
    There are very specific instructions and materials for splicing to aluminum wiring. Improper copper-to-aluminum splicing was a notorious factor in house fires in ~ 1970s USA.
    You can read more about that issue in the gen 3 harness here and here (and in the posts that follow those).
  10. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Don't know about aluminum wiring.
    I have soldered a lot of Toyota wiring and found that it is copper and solders just fine.
  11. ChapmanF
    18,146
    Most of it is.
    So that's why when they go out of their way to alert you to a specific circuit being aluminum and give you training material on how to splice it safely, that counts as new information worth paying attention to.
    Gahzoo likes this.
  12. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Only, I don't think that the wires are aluminum unless they have a copper outer coating.
    Small gauge wires need to be of heavier gauge to carry the same amperage of current. Stranded wires, if coated with an outer layer of copper would have the same "halo" effect as solid copper strands.
    Unless you provide proof, I don't see any advantage for using small gauge aluminum wiring.
    Aluminum for heavy high voltage long distance transmission lines us another matter.
  13. ChapmanF
    18,146
    There are a few kinds of 'proof' one could 'provide' here.
    As far as 'proof' that there's "any advantage" to Toyota using aluminum anywhere in their harnesses, I don't think I'm the person to ask. I trust that discussion took place among Toyota engineers, or they wouldn't be using aluminum in their harnesses.
    As far as 'proof' that they do use aluminum anywhere in their harnesses, to me it is proof enough that they say so, on page 138 of the training course book for their T623 Electrical Circuit Diagnosis course (available under the "Technical Training" tab on techinfo), from which I took the illustration and caution that you see above in post #9.
    As far as 'proof' that the gen 3 low-beam headlight circuit (at the very least in 2010–11 liftbacks, which were the cars covered by T-SB-0204-12) might be one circuit where they used Al, to me it is proof enough that the splicing instructions in that TSB expressly specify the crimp tool 09042-2C100 and crimp sleeve 82999-52010, exactly as specified in their training literature for splices to aluminum (and different from the tool and sleeves specified for non-aluminum splices), and that the low-beam circuit's insulation looks like the color they use to distinguish circuits using aluminum (see, again, post #9 upthread).
    I'm not aware of any other case where they've specified those Cu-Al-specific crimp sleeves and tool for non-CuAl splicing. I suppose the sleeve and tool would make a perfectly serviceable Cu-Cu connection, but Toyota specifies their other, more common, sleeves and tool for that.
    So, absent some goofier explanation (could the person assigned to write T-SB-0204-12 have looked at the insulation color and thought "that's the color we've been using for Al wire, so I need to specify the Al-specific crimp sleeve and tool" when it's really just a Cu wire with that color code by chance?), the most straightforward interpretation points to Al being used there.
    KMO and Gahzoo like this.
  14. Gahzoo
    UPDATE:
    Pics of lights on dash and mechanics splice job. Thoughts? Opinions ? IMG_20251103_180814154.jpg IMG_20251030_101922241.jpg IMG_20251030_101922241.jpg
  15. rjparker
    10,130
    6,292
    Clearing codes which turns off dash warnings means there were codes but your code scanner could not read them.
    Personally I like soldered and heat shrink covered splices but crimp connectors are fine unless the load does not work or the crimp connectors get hot.
    Be sure you have standard h11 halogen headlight bulbs, not "h11" plug compatible led bulbs. Some led bulbs are known to radiate electrical interference to a vehicle's communication networks.
    There is a simple way to rule out your headlight bulbs, wiring or your mechanic's splices as a source of your issue. Turn them off and reset (clear) codes. With the headlights off drive the car and see if the issue remains cleared.
    If they do come back, find a scanner or shop that can read hybrid codes.
  16. ChapmanF
    18,146
    Codes or no codes, I would at least get some self-fusing silicone tape (Rescue Tape is one brand) and tightly wrap it around both splices, half an inch beyond each end and ending in the middle, Toyota's standard instruction for completing any splice that's not dry inside the cabin. It's unrelated to your codes probably, but will prevent the splices becoming issues later on from being open to weather like that.
    Going a little beyond that, I'd consider cutting those splices out and replacing them with the Toyota crimp sleeves 82999-52010, crimped with the 09042-2C100 crimper (which is a Lobtex AK15A), and then wrap the splices with self-fusing silicone tape. I would consider that because there was a technical service bulletin Toyota issued that involved splicing in the headlight circuit, and it expressly specified those crimp sleeves and that tool, which are the ones Toyota specifies for crimps involving aluminum wire. I do not guess they would have expressly specified those without a reason.
    Gahzoo likes this.
  17. Air_Boss
    4,197
    1,182
    New Yawk
    In addition to the points about the potential for LED lamp RFI, this assumes the problem is in the splice, and not in the connection to or the lamp base/holder itself.
  18. ChapmanF
    18,146
    My post started off "codes or no codes" because I don't really have an opinion on whether the splices have anything to do with the issues reported in the OP.
    It's just that the photo in #14 shows splices that definitely need attention to avoid becoming problems in the future, whether or not they are contributing to any issues reported now.
    Air_Boss likes this.
  19. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Not ideal, but a better option would have been the proper sized red butt connector.
    I would have also coated the wires with gray aluminum wiring antioxidation compound before insertion and crimping.
  20. ChapmanF
    18,146
    For whatever reason, even though butt connectors are what you mostly find at the corner auto store, Toyota is all-in on parallel connectors instead.
    The difference is in how the two ends being spliced go together. In a parallel splice, the two stripped ends overlap each other, as in the top of this picture. They are both inserted into a metal crimp sleeve that's just that long (the plastic covering is longer), and when you crimp, you crimp the sleeve and both wire ends all together.
    A butt connector has a bit longer sleeve, with a dimple/gap in the middle so neither wire can go more than that far in. You poke one wire in from one end, and the other from the other end, and they both stop at the dimple in the middle so there is no overlap, it's more like the two ends are just butted together (hence the name).
    After crimping, you've basically crimped one wire to one end of the sleeve, and the other wire to the other end, and the electric current gets from one to the other by being carried by the sleeve.
    I don't really know why butt connectors became the ones much more in stock at corner auto stores.
    (The photo above happens to show a butt connector—you can see the middle dimple/gap in the last step after the heat shrinking. It's also the fancy kind that heat shrinks and has sealant goo in it. Still, the top part of the photo is good for showing how the wires are positioned in a parallel crimp.)
    If you go to Toyota and buy their splices with the part numbers shown in the wiring diagram, those are parallel-splice sleeves. You can also get near-identical ones from TE Connectivity, cross-referencing the numbers using this post.
    Toyota Service Information and Where To Find It | PriusChat
    #20 ChapmanF, Nov 5, 2025
    Georgina Rudkus likes this.
