Straight Talk - Head Gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rubia, Oct 25, 2025.
  1. Mendel Leisk
    41,425
    Put a vertical strip of masking tape on the reservoir, mark the level with a sharpie.
    rubia likes this.
  2. rjparker
    10,138
    6,300
    It is kind of amusing when the op states many times no diy is possible but people keep suggesting it. However diagnostic methods on a gen3 Prius can be different and a smart owner may want to understand the options before paying a shop. I would certainly go to a recommended hybrid shop when possible.
    An early head gasket "rattling" symptom is very loud, sounds like metal to metal contact, causes the car to shake violently and initially convinces people the engine is blown.
    Until it smooths out seconds later and drives great for the rest of the day and sometimes for days to weeks without repeating. If it is a head gasket severe rattling will occur at some point.
    There are egr based shudders and stalls possible but those are caused by a sticking open egr valve, not a clogged egr system. No metal to metal rattling. A Toyota Techstream scanner can run an egr step test while monitoring intake manifold pressure.
    An egr flow blocking test can be done by any shop without a Techstream scanner. Video below.
    Some owners want to do something. Maybe "preventative" or "parts cannon" spark plugs, egr system cleaning, ignition coils or fuel injectors when the first few items are indecisive. Those owners typically throw away $1,000 to $2,000 in this kind of blind part changing. Resist the temptation when the car runs smooth after the rough start. If the problem continues when running most shops have techniques to isolate a bad plug, coil or injector.
    Based on your description you are not there yet.
    A borescope inspection of the cylinders performed by someone who has seen a hg problem on one of these engines is the best diagnostic for a gen3 head gasket problem BEFORE it is bad enough to lose coolant or fail a combustion gas in coolant test.
    Again you are unlikely to be there yet.
    Egr block flow test
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses.
    Car Care Nut HG Borescope at 660s
    Finally, gen3s and high mile reliability issues are real and exceed most other Toyota's in frequency and cost. Brake Boosters, Inverters and Hybrid Batteries are other expensive concerns and those things along with head gaskets are what Tom was talking about. Sometimes it is hard to be comforting when you are talking about a vehicle needed as a lifeline.
    #22 rjparker, Oct 26, 2025
    rubia likes this.
  3. Mendel Leisk
    41,425
    It doesn't hurt to understand the process, even if you don't execute it personally.
    CR94 and rubia like this.
  4. bisco
    51,901
    you can call toyota customer service and try pleading your case nicely. sometimes they help and sometimes not.
    but first, you will need a misfire trouble code and dealer diagnosis
    rubia likes this.
  5. ChapmanF
    18,160
    A Prius owner who has had all of two, non-clattery, rough cold starts, in isolation, followed two days later by a cold start that wasn't rough at all, isn't a person who needs a misfire trouble code or a dealer diagnosis or any of this conversation, but seriously needs a relaxing funny movie and some chocolate.
    rubia, Brian1954 and m.wynn like this.
  6. bisco
    51,901
    nevertheless, i wouldn't buy another gen 3, or recommend one to anyone who wasn't a serious diy'er.
    we don't know what percentage of head gaskets blow, and i would still clean the egr circuit, do 5k oil changes and check/change the coolant more frequently than toyota suggests
    rubia likes this.
  7. bisco
    51,901
    then i'd put on the funny movie
    rubia and Mendel Leisk like this.
  8. OptimusPriustus
    OptimusPriustus Active Member
    333
    141
    Finland
    Having witnessed egr stuck open i can say that it does not sound metal-to-metal. It’s even worse :DAbsolutely horrible rattle.
  9. ChapmanF
    18,160
    Yes, the design of the Prius transmission guarantees that a misfiring engine from any cause will sound like an earthquake in an anvil factory.
    The classic story to that point is this one about a Prius whose owner let it go for scrap price because of the terrifying clatter, over what turned out to be one spark plug.
    rubia likes this.
  10. Mendel Leisk
    41,425
    Due to untimely flooding of cylinders with (oxygen depleted) exhaust gas I’d gather, failing to ignite the fuel.
  11. ChapmanF
    18,160
    Exactly. Too much EGR is a cause of misfiring and, like any cause of severe-enough misfiing, will give you the anvil-factory earthquake sound.
  12. rubia
    rubia Junior Member
    22
    Oh, you don't know the half. It's been a hell of a year... for five years running. Got a movie for that?
  13. rubia
    rubia Junior Member
    22
    This is awesome, really appreciated. Yeah, I don't want to throw money at a looming issue. I want to either save money for a new engine or a new car. But I do like being proactive and gathering info in the meantime, so this is instructive in a great way for me. Again, much appreciated.
  14. rubia
    rubia Junior Member
    22
    Checked the coolant yesterday and it seems fine. I don't think I've touched it in eight years and it look over halfway full but I'll mark it and see how it goes.
  15. ChapmanF
    18,160
    Might consider changing that coolant. The EGR system is not the only possible cause that has been bandied about on PriusChat to explain the incidence of head gasket issues, and old corrosive coolant is another one that has been suggested.
  16. rubia
    rubia Junior Member
    22
    It looks pretty good but there might be an advantage to flushing and refilling, I guess...?
  17. Mendel Leisk
    41,425
    Initial intervals aside, Toyota recommends 5 years or 50k miles, whichever comes first. With their Super Long Coolant (pre-mixed). For both engine and inverter.
    rubia likes this.
  18. ChapmanF
    18,160
    Coolant test strips exist, for the empirical crowd.
    rubia likes this.
  19. rubia
    rubia Junior Member
    22
    UPDATE from the mechanic: no codes; spark plugs, etc looked good; they test drove, no issues. He said the borescope test would be advantageous if the shuddering issue became more prominent or consistent but since it seems to have only been a one-off (or one-and-a-half off), for now, there's nothing much to do. (Except find a bag of money [- or a job -], hoard it, and wait for the next repair.) I'll keep a close eye on coolant and in general.
    Thanks, all, for the input and advice.
    Brian1954 and bisco like this.
