Prius Tire Valve Cap
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Oct 29, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,483
    2,594
    Paramount CA
    @Hammersmith, you could put the bottom line on this. What are the official part numbers for the OEM Gen 4 and Gen 5 tire valve caps? There are several part numbers. They seem to be for different model years.
    The dealer lost my OEM tire valve cap today while replacing a tire. :(
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    2021 Prime seems to be 90942-05039. 90942-05038 would also work as it was superseded by 05039.
    Technically, the gen5 doesn't seem to have an orderable valve cap(you can only order the whole valve). I suspect 05039 would work on it, though. The valves for the spare tires are the same between the gen4 and gen5, so I have to suspect all the valve caps are uniform. 05039 is compatible with 37 models and over 1000 variants from 2003-2025, so that's probably the entire Toyota/Scion lineup over that span.
    Gokhan likes this.
  3. Gokhan
    6,483
    2,594
    Paramount CA
    The only confusion is that there is also the 90942-A5002, which looks identical to the 90942-05039. Do you know the difference? I know my car specs the 90942-05039. Could it be that they are identical or there is a subtle difference such as one of them having an O-ring seal inside?
  4. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm working on it. I wonder if it's something as simple as color.
    Gokhan likes this.
  5. Gokhan
    6,483
    2,594
    Paramount CA
    No, they are both black, I think.
  6. Gokhan
    6,483
    2,594
    Paramount CA
    OK, I think the 90942-A5002 might be cheapo ones vs. the 90942-05039 being made by Pacific. Mine came with Pacific-made ones.
  7. Gokhan
    6,483
    2,594
    Paramount CA
    Here is the Pacific Japan web page:
    Products | Valve Products | Technologies & Products | Pacific Industrial Co., Ltd.
    And this their catalog:
    https://www.pacific-ind.co.jp/eng/product/valve/pdf/productguide_valve.pdf
    PVC25 is the correct tire valve cap for my car, and it has an O-ring seal inside according to the drawing, unlike the cheap Xtra Seal cap the dealer gave me today.
    Perhaps the two parts are identical after all. They look slightly different colors in these pictures (mine is black), but perhaps that’s the lighting. Or perhaps they are both made my Pacific but in different factories.
    90942-05039:
    90942-A5002:
    #7 Gokhan, Oct 29, 2025
  8. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Makes sense. I believe a letter at the start of the second five digits often denotes an outside supplier(outside meaning not the ones used in the factory). AZ is an economy part(often found in brake pads - don't use them), WA is for BMW, WB is Mazda, YYZ for maintenance items. So 05039 is the factory part, while A5002 is a locally sourced part that conforms to the OE standard.
    Gokhan likes this.
  9. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's more likely that they're both made using the same specs(provided by Toyota) but by different companies. They might look identical simply because Toyota gave them the design and said make this for us.
    Gokhan likes this.
  10. Gokhan
    6,483
    2,594
    Paramount CA
    Well, tomorrow I am getting three more tires and the service guy promised to give me four new Toyota tire valve caps. I will also check with the parts department to see what they actually have.
    Sadly, my tires are still like new, but I got five nails in about a year and decided to keep spare tires in the garage. They also have discontinued the Dunlop Enasave 01 A/S (the manufacturing date on the ones I have been getting is the 41st week of 2022) and I wanted to get them before they were gone. Slightly over $600 total for four tires installed with a two-year new-replacement road-hazard warranty.
  11. Mendel Leisk
    41,830
    Two pages on valve cap part numbers? Must restrain self…:confused:
  12. VelvetFoot
    VelvetFoot Active Member
    1,146
    453
    New York State
    2026 Prius
    On a side note, don't buy fancy metal ones like I did for my MINI.
    Some kind of reaction took place with the AL(?) stems on the TPMS sensors and they became welded. Managed to break out 3 of 4.
    Gokhan likes this.
  13. Mendel Leisk
    41,830
    Yes, corrosion.
    and a PSA: any time you’re getting new tires, especially at Costco (if you’re not a fan of green valve caps), take the current ones off, put em in your pocket.
    Templeton and VelvetFoot like this.
  14. Gokhan
    6,483
    2,594
    Paramount CA
    You need to be careful when getting tire valve caps for TPMS sensors.
    Two rules:
    • No metal caps allowed
    • Must have a rubber bushing inside to form an airtight seal
    I would refrain from cheapo aftermarket ones, though there are acceptable once satisfying the criteria above. See the technical drawing of the OEM Japanese Pacific tire valve cap PVC25 on the previous page.
  15. Gokhan
    6,483
    2,594
    Paramount CA
    Green means nitrogen fill.
    Yes, it is a good idea to take them off at service, and I do that, but I thought at least the dealer would have common sense.
    It was a good thing I declined the courtesy car wash because the TPMS sensor would go into the carwash with no tire valve cap. It is not to mention the harsh brushes.
  16. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Galvanic corrosion, didn't even think about that. There's no TPMS sensor in the spare though, they have normal rubber valve stems.
  17. Gokhan
    6,483
    2,594
    Paramount CA
    The spare tire probably comes with the OEM Japanese Pacific tire valve cap CL shown in the brochure screenshot on the previous page. It is made of resin and has a rubber bushing like the PVC25 TPMS cap, but it is a lot larger and has a lot shorter thread and doesn’t have a lip inside.
  18. Gokhan
    6,483
    2,594
    Paramount CA
    And an interesting observation: A small nonthrough hole on the top of plastic tire valve caps seems to indicate the presence of a rubber bushing.
    Metal caps naturally always come with rubber bushings, but they should not be used with TPMS sensors. TPMS sensors use the small cylindrical plastic caps with rubber bushings and long threads (not the large plastic caps with short threads intended for valves without TPMS sensors) pictured on the previous page.
  19. mingc
    mingc Member
    73
    56
    Portland, OR
    2023 Prius
    XLE AWD-e
    The small non through-hole and the protrusion on which it sits work very nicely as a tool to depress the valve to let air out. I assume that they were designed for that purpose.
    Gokhan likes this.
  20. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Misread this, didn't realize they were talking about caps. :barefoot:
    VelvetFoot likes this.
