Tow Hook Cover
Discussion in 'Prime Main Forum (2017-2022)' started by Prius C 2013, Oct 27, 2025.
  1. Prius C 2013
    Prius C 2013 Junior Member
    Irvine, CA
    2020 Prius Prime
    I'm trying to find out the part no. for the tow hook cover for my Prius Prime 2020 metallic blue color. One of them went missing recently. I wonder if it's replaceable by itself. Does it come painted?
    And we'll be traveling to Yokohama and Okinawa Japan. Do you think we can get this particular part in Japan now that Prius Prime is no longer sold in US? I know in Japan they called it Prius PHV(Plug-in Hybrid). Anybody had any experience purchasing parts directly from Japan?
    Thanks,
    Dennis
  2. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    Sounds like something that would be easy to 3D print.
  3. TinyTim
    TinyTim Active Member
    387
    238
    Seattle
    There is a left and right tow hook cover. Make sure to get the correct cover. Best place to find them is the Toyota Parts website through the Toyota dealer network.
    Prius C 2013 likes this.
  4. Mendel Leisk
    41,923
    Phone a local-to-you Toyota dealership parts department? They should be able to sort it out; it’s their job.
    it might come unpainted.
  5. Prius C 2013
    Irvine, CA
    2020 Prius Prime
    Please give me some step-by-step directions on how to do so.
  6. Rugged_Rowan
    Rugged_Rowan New Member
    Southeast
    2025 Prius
    They only come unpainted, I ended up having to find one for my 5th gen, somehow it wasn't connected to the j hook and came loose and lost it on the highway. I ordered mine from paintedoemparts.com . you can check that out.
  7. Mendel Leisk
    41,923
    3rd gen tow hook covers are on like the hinges of hell. Maybe there were complaints, who knows, at any rate, it's seems like from 4th gen on they're much more prone to fall off. Maybe install with a few dabs of silicon caulk, just enough to secure it better.
  8. Prius C 2013
    Irvine, CA
    2020 Prius Prime
    They only come unpainted, I ended up having to find one for my 5th gen, somehow it wasn't connected to the j hook and came loose and lost it on the highway. I ordered mine from .... you can check that out.​
    Guess what? Thanks for your timely confirmation. Now that I know why all the ones I found online is unpainted. And I can assure that since we have a 2020 prius prime, it's only about slightly less than 5 years old. Every time we saw the tow hook covers dangling and put it back or both of them back in place. But after we recently had our bumper replaced at a shop, a few months went by, we found out the right cover went missing a week or so ago. So that tells me the shop did not install the hook cover carefully and hooked properly. That resulted in this incident. It is only a couple months ago. There is no way that it fell off without a reason.
  9. TinyTim
    387
    238
    Seattle
    The car wash ate my Gen 4 tow hook. My Prius is blue and I didn't bother painting it. So I have a black and a blue tow hook but the blue is dark and you can't really tell. You may want to get the left and right as a pair. That way they will match if you have a light color Prius.
  10. notspam3
    notspam3 Member
    96
    52
    Toronto
    2024 Prius Prime
    XSE Premium
    1. Go to the dealership after hours
    2. Find the part you are looking for on a vehicle on the lot
    3. Retrieve part
    4. Measure all the part's critical geometry on your Coordinate Measuring Machine, generate a point cloud
    5. Generate continuous curves of the various part profiles using point cloud data
    6. Use the curves to loft solid model components
    7. Assemble solid model components into a single solid model
    8. Export a scale STL model file of your finished part
    9. Use the STL file to generate a 3D printer file with suitable parameters
    10. Test print your part
    11. Next day see if the part fits on your car. If yes Bonus! If not, go back to step 6 and start again
    12. Go back to the dealership and replace the borrowed part
    13. When you part shrinks after being exposed to heat and sunlight, or shatters when hit by a stone or insect, or just disappears one day and you notice it, now you can 3D print a new part! Just like new! Stick it to the man!
